help [at] infinity-box.com |
now it shows error dongle blocked |
Cracked softwares, team viewer... ( it worked well before even when cracked softwares was there) |
The probleme started when i inserted a multimedia hard drive and installed drives.... After that the probleme started. " Memup " i installed setup and drivers... Help please i need infinity to work again because i use it alot |
i tried even to install it on another windows but same error ... what is happening ? whats the probleme ? |
@Aymen2net update dongle firmware now |
plz solve my problem. --------------------------------------- warning. dongle misconfiguration. -------------------------------------- === DongleManager [Infinity] v1.70 [6/13/2019 14:41:18] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0103866B20281292 Box/Dongle found: [BEST] Serial No (S/N): EDC8866B Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 30 "UK Edition" status: Off Last launched Application: 0031 v.0127 => Activations: - 00: Infinity-Box/Dongle v.0136 - 03: [BEST] v.0122 Diagnostic Key: 7F33EC86B5E64345 |
Please HELP... === DongleManager [Infinity] v1.72 [27.06.2019 13:28:54] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000127C57D314082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): DB7527C5 Firmware version: 0137.02 Box/Dongle misconfiguration Diagnostic code: 5A "UK Edition" status: Off Last launched Application: 0030 v.0137 => Activations: - 00: Infinity-Box/Dongle v.0137 Diagnostic Key: 7F77B5FC191C3862 При запуске любой программы пишет "Dongle misconfiguration"... Уже не знаю что делать |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
card config errr === DongleManager [Infinity] v1.72 [7/13/2019 21:21:10] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000019E50EFE4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): B4D119E5 Firmware version: 0137.02 Box/Dongle misconfiguration Diagnostic code: 5A "UK Edition" status: Off Last launched Application: 0036 v.0137 => Activations: - 00: Infinity-Box/Dongle v.0137 - 07: #7 Diagnostic Key: 7FCF0BF2BBD9139E === DongleManager [Infinity] v1.72 [7/13/2019 21:23:28] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000019E50EFE4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): B4D119E5 Firmware version: 0137.02 === Process started: 7/13/2019 21:23:30 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
warning. dongle misconfiguration. === DongleManager [Infinity] v1.72 [7/14/2019 17:03:16] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000C4B81A224082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 331DC4B8 Firmware version: 0136.02 === Process started: 7/14/2019 17:03:18 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
