09-17-2008, 11:25 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 698672 Status: Offline Thanks Meter: 62 | how to know the flash file of china phone? 6300flash_20080916-233026.B0M.bin |
09-17-2008, 12:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, make search in support area by required model name or by firmware version. Also do not forget to check \\flashfiles\\ChineseMiracle\\_doc folder |
09-18-2008, 01:46 | #3 (permalink) | |
Member: 698672 Status: Offline Thanks Meter: 62 | Quote:
there are many kinds of firmware in support area, how do i know the right firmware and version of this phone? thanks for your kindly support | |
09-18-2008, 02:48 | #4 (permalink) |
Member: 698672 Status: Offline Thanks Meter: 62 | before the phone was hang up, after format the phone was dead here is the logs in complete mode === log: [9/17/2008 6:39:40 PM] ==== COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:4FB0D70 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:FFFFFF00000000 Finalization Done Finished, time used: 177 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
09-18-2008, 07:49 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Do not make "whole flash chip" format. Now restore original phone backup and make "format" in "safe" mode. If problem still exist make "format" in "complete" mode. |
How can I know the flash size of BB5 phones? | adam345 | Universalbox | 1 | 02-24-2009 08:44 |
how to know the card id of a Cruiser-06 dongle ? | gsmsikar | Cruiser Suite | 1 | 11-12-2008 11:29 |
How to know the FW version of phone | Warluck02 | UST Pro II | 1 | 09-30-2008 08:11 |
how to know the flash files of dead phones | sanjubhai | Chinese Models & Cloned Phones | 4 | 05-08-2008 09:03 |
how to know the original ver. of v25 ? | makona | x1x to x45/x50 | 2 | 01-12-2001 07:27 |
