08-21-2017, 19:34 | #91 (permalink) |
Crazy Poster Join Date: Sep 2014
Member: 2253968 Status: Offline Thanks Meter: 1 | Searching... Card-Reader: FT SCR2000 0 HWID: 0102885803EF1292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.70 [8/21/2017 19:25:14] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0102885803EF1292 === Process started: 8/21/2017 19:25:15 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 pls help me out yellowboss and infinity best i cant do my business without my infinity best.. thank u |
08-21-2017, 22:17 | #92 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) Then make this: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
08-22-2017, 06:36 | #93 (permalink) |
Junior Member Join Date: May 2017
Member: 2715217 Status: Offline Thanks Meter: 0 | hi i done step by step but when i want to reset password it ***** an error:Account has no valid recovery e-mail. Contact to support ! my sn :748B734A even sm account shows this error onglw with samsung activation is not found plz help me |
08-22-2017, 06:39 | #94 (permalink) | |
08-22-2017, 08:18 | #96 (permalink) |
Member: 2715217 Status: Offline Thanks Meter: 0 | Dongle with SM Activation is not Found ! and when i want to Update Firmware with infinity Dongle manager V1.70 showes this Error : Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! what shall i do ? thank you |
08-22-2017, 12:04 | #97 (permalink) | |
08-22-2017, 14:48 | #98 (permalink) |
Insane Poster Join Date: Sep 2012 Location: Dubai Sharjah
Member: 1811141 Status: Offline Sonork: 1673027:zobi Thanks Meter: 6 | Dear team ? Dongle firmware version outdated error after update that is my s/n Serial No (S/N): D869BD6B please solved that probleam thanku |
08-22-2017, 19:42 | #102 (permalink) | |
What is your Support Validity Date ? How to check - http://www.infinity-box.com/doc/?r=17 If support is expired please contact to any seller and renew support. | |
08-22-2017, 19:57 | #105 (permalink) |
Freak Poster Join Date: Dec 2005 Location: gem-flash team
Member: 212136 Status: Offline Sonork: 100.1580104 Thanks Meter: 165 | === DongleManager [Infinity] v1.70 [22/08/2017 20:56:56] === Searching... Card-Reader: FT SCR2000 0 HWID: 0201A97D1D041292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 0000A97D Firmware version: 0000.00 === Process started: 22/08/2017 20:56:57 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... hang here |
