Old 08-21-2017, 19:34   #91 (permalink)
Crazy Poster
Member: 2253968
=== DongleManager [Infinity] v1.70 [8/21/2017 19:25:07] ===
Searching...
Card-Reader: FT SCR2000 0
HWID: 0102885803EF1292
Select Token Type: instead of Autodetect
=== DongleManager [Infinity] v1.70 [8/21/2017 19:25:14] ===
Box/Dongle type selected: [BEST]
=== Process started: 8/21/2017 19:25:15 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to http://www.infinity-box.com/support/?r=2
pls help me out yellowboss and infinity best
i cant do my business without my infinity best.. thank u
Old 08-21-2017, 22:17   #92 (permalink)
Member: 148515
Thanks Meter: 19,534
Searching...
Hello,
What to do:
1. Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - http://www.infinity-box.com/support/?r=6
OR
1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
Then make this:
2. Run DongleManager
3. Update Dongle firmware
- DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries
- DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle !
Old 08-22-2017, 06:36   #93 (permalink)
Member: 2715217
hi i done step by step but when i want to reset password it ***** an error:Account has no valid recovery e-mail. Contact to support ! my sn :748B734A
even sm account shows this error onglw with samsung activation is not found
plz help me
Old 08-22-2017, 06:39   #94 (permalink)
Member: 148515
plz help me
How to get Username and Password - http://www.infinity-box.com/support/?r=22
Old 08-22-2017, 06:40   #95 (permalink)
Member: 1578597
Thanks Meter: 35
https://www.youtube.com/watch?v=fnWGtdsKV-M
100%
Old 08-22-2017, 08:18   #96 (permalink)
Member: 2715217
Dongle with SM Activation is not Found ! and when i want to Update Firmware with infinity Dongle manager V1.70 showes this Error :
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
what shall i do ? thank you
Old 08-22-2017, 12:04   #97 (permalink)
Member: 148515
you must read current thread from first to last post. result?
Old 08-22-2017, 14:48   #98 (permalink)
Member: 1811141
Sonork: 1673027:zobi
Thanks Meter: 6
Dear team ?
Dongle firmware version outdated error after update that is my s/n
Serial No (S/N): D869BD6B
please solved that probleam thanku
Old 08-22-2017, 15:45   #99 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 468
after activating and update box firmware, repair option is not available in cm2 mtk and spd
Old 08-22-2017, 15:45   #100 (permalink)
Member: 2715217
uffff i do it but cm2qualcom dosnt work ! i installed 10 drivers but it dosnt show anything in edl mode ! how ever ufi supports it ! what to do ?thanks
Old 08-22-2017, 17:53   #101 (permalink)
mohamed183's Avatar
Member: 212136
Sonork: 100.1580104
Thanks Meter: 165
pls i need help
Old 08-22-2017, 19:42   #102 (permalink)
Member: 148515
Originally Posted by zohaibjee86 View Post
Dear team ?
Hello,
What is your Support Validity Date ?
How to check - http://www.infinity-box.com/doc/?r=17
If support is expired please contact to any seller and renew support.
Old 08-22-2017, 19:45   #103 (permalink)
Member: 148515
Here is thread regarding SM activation.
Do you have any problem with SM software ?
Old 08-22-2017, 19:47   #104 (permalink)
Member: 148515
Originally Posted by mohamed183 View Post
pls i need help
Please copy/paste text but not pictures.
Old 08-22-2017, 19:57   #105 (permalink)
mohamed183's Avatar
Member: 212136
Sonork: 100.1580104
Thanks Meter: 165
=== DongleManager [Infinity] v1.70 [22/08/2017 20:56:56] ===
Searching...
HWID: 0201A97D1D041292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): 0000A97D
Firmware version: 0000.00
=== Process started: 22/08/2017 20:56:57 ===
hang here
Page generated in 0.26587 seconds with 9 queries
