Old 11-05-2007, 11:17   #1 (permalink)
Member: 381241
Thanks Meter: 13
Imobile 100 and Imobile 313
Try to read Eeprom and Full flash from Imobile 100 Everything OK.But Imobile 313 NOT. See logs.
COM4 [VCP0] selected
Device: IMobile-100
Checking data, wait...
Action: read flash
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 00BF:7353
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20071104-193633.B1E.bin
loading data...
data loaded
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20071104-193635.B1E.bin
backup critical area Done
Check memory...
Reading [flash]...
file saved: backup_flash_20071104-195211.B1X.bin
Completed
Finished, Remove/Install battery now !
Time used: 962 sec
Device: IMobile-313
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 80FA:8000
Connecting Done
Check free space...
Check parameters...
loading data...
error: source buffer too small: 00000000 instead of 0000000A
Check memory...
Completed
Time used: 33 sec
Old 11-05-2007, 11:34   #2 (permalink)
Member: 381241
Thanks Meter: 13
Reset usercode Imobile 510 Show Error But Work. Usercode clear.
See logs. Suggestions Wellcome.
Device: I-Mobile 510
advanced flash detection active
Action: user code
unlock method: standard
Boot...
Connecting, wait...
Initializing[6226:8A02:8A01]...
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
460800
Set baud Done
Identification...
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [standard] (or higher) generation
protocol ver: 04
ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN
ver. sw2: 7S-7311-THS0-0-R1N
ffs offset/size: 00E00000/00200000
warning: invalid identification, ask/rpl calculation reqired
error: rpl file not found: D:\Program Files\InfinityBox\MModule\id.._ARIMA26_05C_PCB01_G PRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN_FFFFFFFF_.rpl
warning: unknown identification structure: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN_FFFFFFFF
error: ASK file can't be created, user action required:
1. download latest software from support area and try again !
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read detailed information" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN]]...
file saved: backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1N.BIN]_20071029-120959.B0E.bin
Identification Done
Manipulation...
detection procedure, wait...
detection procedure completed
Manipulation Done
Finalization...
Finalization Done
Write...
flash: 98004900000002:457BB500000000
Write: eeprom
error: error# 000000E4
error: flash write error: 00FF4000:00002000
Write Fail
Finished, time used: 126 sec
Old 11-05-2007, 12:50   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
We will check Imobile 313 opeations ASAP.
1. use latest software from support area
2. use "read codes" function
Old 11-06-2007, 12:01   #4 (permalink)
Member: 381241
Thanks Meter: 13
Thank you InfinitySupport for your suggestions. I will try later.
Old 11-07-2007, 07:06   #5 (permalink)
Member: 381241
Thanks Meter: 13
For references : Imobile 510 Read code Work.
==== log opened: [7/11/2007 12:46:47] ====
Application: D:\Program Files\InfinityBox\MModule\MModule.exe
Loading data, wait...
[Infinity Box] v1.66
S/N: xxxx
Done
Action: read codes
unlock method: read codes
Model: I-Mobile 510
19200
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: 7S-7311-THS0-0-R1N
Version: FP
imei: 35970100704xxxx
connection Ok
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 2525
Finished, time used: 9 sec
coral 100 and 200 mose1 Infinity-Box 4 07-10-2008 07:50
Mp4 Imobile Change And He Say Wrong Batery freedomqn SpiderMan 1 07-07-2008 20:43
how to unlcok sharp TM-100 and what cable to use?? tsarkh VygisToolbox 1 02-10-2008 11:41
8120 GDFS problem sw. 100 and 104 NetFreak Blazer 11 06-08-2005 21:10
ı need t 100 and e 700 pin out kenwood Samsung Flashers, Software, Firmware. 1 12-13-2003 22:41
Page generated in 0.22932 seconds with 9 queries
