12-18-2019, 14:53 | #49 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Finally Mobicel Rebel Privacy DONE wit MT2 Operation : Reset PrivacyLock [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : MT6570_INFINITY | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 7001004D363237303401031473C3646B EMMC: VEN : KINGSTON | OEM : 01 | DEV : M62704 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE2000000 [ 3.53 GB ] CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D6A2D5A5465D025CA96CE2DFBF70361 DA : USB : HIGH-SPEED Boot done! Backup sensetive data [ 10 ] Backup path : Backup\MT6570__D6A2D5A50465D025CA96CE2DFBF70361\ [3] Read : NVRAM [16] Read : NVDATA [2] Read : PROINFO [7] Read : LK [15] Read : NVCFG [4] Read : PROTECT1 [5] Read : PROTECT2 [0] Read : PRELOADER Backup done! Process Block #2 Process Block #3 INFO : PrivacyLock reset done! Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to -Mosin- For This Useful Post: |
12-18-2019, 15:16 | #50 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
12-18-2019, 15:38 | #52 (permalink) | |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | honor 3c h30-u10 mtk 65824 Quote:
Operation : Write Flash [ v2.07 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :12 [FL] : Set : preloader_huawei82_wet_jb5.bin [FL] : Set : MBR [FL] : Set : EBR1 [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : secro.img [FL] : Set : logo.bin [FL] : Set : EBR2 [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x325E6390 [ 805.90 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1812 | Manual : Enabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064324738AA03030485A16C7F DAInf: 4 : 2 : 135 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 90014A4838473264040303AA7F6CA185 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6582 EMI : SRC : preloader_huawei82_wet_jb5.bin EMI : CNT : 0004 EMI : [00] : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [02] : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [03] : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER DA : EMI : Failed to get EMI info from selected source! DA : Failed to configure DA! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! | |
The Following 2 Users Say Thank You to bilal khan12345 For This Useful Post: |
12-18-2019, 15:48 | #53 (permalink) |
Member: 2266425 Status: Offline Thanks Meter: 58 | PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064324738AA03030485A16C7F DAInf: 4 : 2 : 135 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 90014A4838473264040303AA7F6CA185 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6582 EMI : SRC : preloader_huawei82_wet_jb5.bin EMI : CNT : 0004 EMI : [00] : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [02] : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [03] : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER DA : EMI : Failed to get EMI info from selected source! DA : Failed to configure DA! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
12-18-2019, 15:57 | #54 (permalink) |
Member: 2266425 Status: Offline Thanks Meter: 58 | h30-u10 after unlock bootloder flash tool method flash ok but still restart on logo Operation : Write Flash [ v2.07 ] Repartition : Disabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :10 [FL] : Set : MBR [FL] : Set : EBR1 [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : EBR2 [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x325AA2A4 [ 805.66 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064324738AA03030485A16C7F DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847326440303AA7F6CA185 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G2d EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : FB2F7E739B095DAFDC6D1B4F5E06AE68 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x62383331313564343937326462396534 [FL] : Flashing now ... Write : MBR Write : EBR1 Write : UBOOT Write : BOOTIMG Write : RECOVERY Write : LOGO Write : EBR2 Write : ANDROID Write : CACHE Write : USRDATA [FL] : Flashing finished! Done! Elapsed: 00:01:26 Operation : Write Flash [ v2.07 ] Repartition : Enabled Flash Verify : Enabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Enabled Files :12 [FL] : Set : preloader_huawei82_wet_jb5.bin [FL] : Set : MBR [FL] : Set : EBR1 [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : secro.img [FL] : Set : logo.bin [FL] : Set : EBR2 [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x325E6390 [ 805.90 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064324738AA03030485A16C7F DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847326440303AA7F6CA185 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G2d EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : FB2F7E739B095DAFDC6D1B4F5E06AE68 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x62383331313564343937326462396534 [FL] : Pre-Erase [FL] : Whole Flash Erase enabled! Erase : 0x0000000000000000 : 0x00000001D2000000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : MBR Write : EBR1 Write : UBOOT Write : BOOTIMG Write : RECOVERY Write : SEC_RO Write : LOGO Write : EBR2 Write : ANDROID Write : CACHE Write : USRDATA CHK : 0x00000200 : 0x08EA : MBR CHKSUM : FAIL : 0x0000000000000000 : MBR Error : Post-Flashing failed : Verification of region failed! Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Reconnect Power/Cable! Last edited by bilal khan12345; 12-18-2019 at 16:05. |
12-18-2019, 19:09 | #59 (permalink) |
Major Poster Join Date: Jun 2013
Member: 1954072 Status: Offline Sonork: lekaz Thanks Meter: 3 | Operation : SP Unlock [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1912 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: FE014E50314A39354B120E6EBE0B43DD EMMC: VEN : MICRON | OEM : 4E01 | DEV : P1J95K EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00200000 [ 2.00 MB ] USER : 0x1D3000000 [ 7.30 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1B173E23E8F2C8B54422F77EEBF1094C DA : USB : HIGH-SPEED Boot done! Error : SPLock identification failed! Send log and report.log (if exists) to support! Include device info also! Reconnect Power/Cable! Movitel_M9103 MT6739__sanmu__M9103__8.1.0_O11019__g1839ph_v2_gs_ yfzn_y05mt_goMovitel_M9103 MT6739__sanmu__M9103__8.1.0_O11019__g1839ph_v2_gs_ yfzn_y05mt_go |
