01-30-2020, 07:50 | #196 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Will upload in near two days. | |
01-30-2020, 09:23 | #197 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2301015 Status: Offline Sonork: 100.1668279 Thanks Meter: 10 | Serial No: 8F5737E0 my dongal old versions only working . spd. mtk . ast all old versions only. team can't fix. format computer change computer virus guard stop 4-5 computer change . not working . infinity best working perfect . other all dongal box working . team email send but can't team fix. team my fault always repeated . but new pc format computer its working but not working . new activate buy. not any do this. my money lost and go time 1year activate . this can't fix refund please . |
02-12-2020, 16:34 | #199 (permalink) |
No Life Poster Join Date: Jun 2004 Location: burkina faso Age: 51
Member: 70259 Status: Offline Thanks Meter: 53 | cm2mt2 & cm2sp2 not open cm2mt2 & cm2sp2 not work after make last update can not open those 2 soft. all other soft work fine need help to make work again CM2MT2 AND CM2SP2. PS FLEXY HUB not install try into 3 pc same thanks |
02-13-2020, 10:42 | #200 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | Any solution for this model sir Mi play Mi M1901F9E Operation : Identify [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM64) MODE : BOOTROM PORT : 64 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 51E8055A9C5D9C2BDC897214F87662BE10A9AC9966CB720B11 4E0EABDCAE6A4D AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! |
02-13-2020, 10:49 | #201 (permalink) |
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | This is another info Sir.. Operation : Identify [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM64) MODE : BOOTROM PORT : 64 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1924 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 51E8055A9C5D9C2BDC897214F87662BE10A9AC9966CB720B11 4E0EABDCAE6A4D AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Need DA and auth file....... |
02-25-2020, 08:13 | #203 (permalink) | ||
Xiaomi require account to flashing from this device, or service ones and NO mi-cloud lost status. | ||
02-25-2020, 22:30 | #204 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | New version CM2MT2 v2.08 released https://www.infinity-box.com/support/?r=100102 |
