01-24-2017, 10:28 | #166 (permalink) |
No Life Poster Join Date: May 2014 Location: Georgia in Gori Age: 34
Member: 2188828 Status: Offline Sonork: WOW Thanks Meter: 66 | Thanks |
01-24-2017, 11:35 | #167 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
01-24-2017, 15:34 | #171 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | Card found : B8CE797D , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 08003A93 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 856E6D48A1E7962FADCEEF16E846F0B0 ID_BLOCK_L : 44383FC9A14DB1A98EEB01708B5A984C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D3000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:16 alcatel 4060a but frp still on |
01-24-2017, 15:44 | #172 (permalink) | |
01-24-2017, 15:57 | #173 (permalink) |
Member: 455304 Status: Offline Thanks Meter: 417 | Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 08003A93 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 856E6D48A1E7962FADCEEF16E846F0B0 ID_BLOCK_L : 44383FC9A14DB1A98EEB01708B5A984C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D3000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:19 Reconnect Power/Cable! did that also before still lock if customer bring back phone ill send file |
The Following User Says Thank You to shawn4life For This Useful Post: |
01-25-2017, 16:15 | #176 (permalink) |
Insane Poster Join Date: Apr 2009 Location: Jamaica
Member: 1008787 Status: Offline Thanks Meter: 16 | Hello team i am trying to remove frp on a coolpad 3622a, this is what i got when i try to use qlm module to remove it: Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0703AFF7 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 4D8624FA506DF80E2119874580BB8B19 ID_BLOCK_L : 7CA3042E25A75A5E34AAF79063491E0C Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Could you supply me with any help to remove please? |
01-25-2017, 17:22 | #177 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Molakalmuru (KARNATAKA) {INDIA
Member: 1891452 Status: Offline Thanks Meter: 29 | Infocus M370i Infinity Team plz support this model Card found : CF166680 , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 016CA9FE ID_BLOCK_I : 009600E1 ID_BLOCK_L : 8B7D17EF4ED4C1CCBB90606DAAF10149 ID_BLOCK_L : 275EE04B4CD7078C01ECA11E149B95B6 Use CM2 Internal Loader Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! |
01-27-2017, 07:28 | #178 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,976 | New version released - http://forum.gsmhosting.com/vbb/f296...tures-2185891/ |
02-23-2017, 02:24 | #180 (permalink) |
Insane Poster Join Date: Mar 2013 Location: morocco Age: 46
Member: 1898834 Status: Offline Sonork: abdelhakim.ch Thanks Meter: 14 | huawei nova msm8953 the just connected as hs-usb qdloader 9008, no fastboot and no recovery. and infinity doesn't detect it, is there any solution please! |
