Old 03-16-2016, 14:41   #1 (permalink)
Member: 942210
Sonork: 1511
Thanks Meter: 91
PreLoader : NOT Active [ Erased ] 6572 nand
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x10000000
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1
DEV RID : A201493A6AB713FE1DE19647A1A35208
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
i flash the og firmware with og tool flashing done but set is not power on
plz help me argent
phone problem press the data button then set hang
Old 03-16-2016, 15:01   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Find exact firmware version written on phone back sticker and flash phone with spft.
Br.
Infinity Box Support Team.
Old 03-16-2016, 15:08   #3 (permalink)
Member: 942210
Sonork: 1511
Thanks Meter: 91
i flash the set same firmware ver on written phone back sticker
phone sw ver v13K
http://firmwarefile.com/intex-aqua-3g
Old 03-16-2016, 18:40   #4 (permalink)
Member: 1948608
Thanks Meter: 1,744
phone sw ver v13K
Intex Aqua 3G Stock Firmware ROM (Flash File)
Erase Bad Blocks with Physical Format/Readback by Sptool and than Full Flash Again.
Old 03-17-2016, 04:56   #5 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
phone sw ver v13K
look here and follow process ur set alive
http://forum.gsmhosting.com/vbb/f781...-tool-1992409/
The Following User Says Thank You to sneha For This Useful Post:
Old 03-17-2016, 06:44   #6 (permalink)
Member: 942210
Sonork: 1511
Thanks Meter: 91
Thanks sneha follow with your process my set is alive
but cm2 imei not write
Operation : Repair Security [ v1.43 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
NAND Flash not supported yet in that mode!
Old 03-17-2016, 07:09   #7 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Hello,
Use AT:Temporary mode.
Br.
Old 03-17-2016, 07:37   #8 (permalink)
Member: 2205304
Thanks Meter: 52
Yes, we are aware such feature exists on SPFT.
@Team, can we have Erase bad block function [NAND] on CM2 ?
Page generated in 0.15852 seconds with 8 queries
