Old 08-27-2009, 15:52   #1 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Problem with Spice S600
Hello to all,
I have a problem with Spice S600 phone.
I download the flash file frm support area & try to flash this file on the phone.
Phone take flashing OK & power up the phone but when i go to profile it show all ringtone empty.
Also format the phone but same...!
Here is the both operation Log
Flashing Log
Loading data, wait...
[Infinity Box] MModule v2.82
S/N: 1101:0112
Wait...
Device: Aiko-17G
Done
Device: Spice-S600
Loading file v.02...
Spice-S600_P50017.05161210D.E1_G16_HW_Oct2004_15ST_May-29-2006_En.B0M.bin loaded
==== log: [8/27/2009 7:46:07 PM] ====
COM3 [VCP0] selected
module  v2.82
Device: Spice-S600
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6217:8A00]...
CPU: MT6217
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
ffs address can not be detected, value from database assigned: 00880000/00780000
detect device identification#2...
detect device identification#2 finished
sim-lock status: unknown
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: Spice-S600__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Spice-S600__ffs_20090827-194708.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Area: Firmware
Write: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 343 sec
Remove/Install battery now !
Format Log
module  v2.82
Device: Spice-S600
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6217
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
.damaged firmware
.damaged hardware
Write ...
Write Done
Finalization ...
formatting...
flash: 98004900000002:6EECFA00000000
Finalization Done
Finished, time used: 59 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
After flash & Format phone still same......Not show any ringtone in profile not even default tones
Thankx in advance.
Old 08-30-2009, 15:51   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Infinity Team where r u ?
I am waiting for u r answer.
Old 08-30-2009, 16:47   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Try to flash with the other given file on support.
Old 08-31-2009, 15:33   #4 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Thankx for the reply.
I flash the set with another version but same.....!
Infinity team I am waiting for u r reply...!
Check my first post & check today's post. 4 day's passed but even u not post any single reply for me
Old 08-31-2009, 22:28   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Did you tried to flash phone with repair eeprom files ?
What was the problem with phone before flash ?
Old 09-01-2009, 14:47   #6 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Before flash the set phone is infected with virus (Restart some time not too......but work fine) that's why i use to format ffs the set.
Phone took ffs complete bet after power on the set profile is empty.
Then i decided to flash this set (i flash the set with both version uploaded in support)
Also i can't find eeprom file for this set in support area.
After flash the set phone is same condition before i flash.
Old 09-01-2009, 15:00   #7 (permalink)
Member: 130995
Hello,
Support area -> \flashfiles\Spice\S600\repair_eeprom
Support area -> \flashfiles\Spice\S600N\eeprom
spice s600 success fully repaired by flashing with infinity & flash file at sopport s sabby_singh Infinity-Box 2 11-02-2011 16:22
spice s600 charching problem akhil111 Spice 0 05-12-2008 08:46
Spice S600 charging and mass storage problem..Solution Plzz rk_grover77 Spice 3 05-12-2008 08:46
spice s600 hang problem jay k sundrani Infinity-Box 1 08-23-2007 14:34
spice s600 charging & unknown device problem gsmsikar Infinity-Box 1 04-18-2007 09:35
Page generated in 0.21727 seconds with 9 queries
