Old 07-18-2008, 05:36   #1 (permalink)
Member: 816811
Question about the "COM" port on MT6225
Hi everybody on this forum.
I receive my infinity-box today. I'm starting with backup and reflash some chinese phones.
A lot of cables inside the package from my reseller, but neither of them worked.
I have a lot more from ipmart, but the same, neighter of them work.
Before start the process to find and build a custom cable, I'm trying with the original USB phone cable . I start connecting this cable (directly to my PC) and selecting "COM port" option on the phone, as showed in the following picture (from infinity-box)
http://www.infinity-box.biz/download...phone_menu.jpg
When I use the option "Read General information" on Chinese miracle application, I get the following:
Loading data, wait...
[Infinity Box] v2.36
S/N: ***x:***x
Wait...
Device: Autodetect 6205-6227 NOR
Done
COM1 ready <-------------------Note: COM1 is the USB-COM port
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6225, E03
Hardware version: ************
Software version: ************
Software date: ***x.xx.xx
Barcode: ************
imei: ***************
Finished, time used: 4 sec
so, It was wonderful!
but when I press the "Read detailed information" on chinese miracle software, I get this:
Power off phone now !
COM1 [USBSER000] selected
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Remove/Install battery now !
Similar messages when I try other options (read flash)
My question:
Can I read the firmware with this COM port?
Thank you very much in advance.
I'm considering the language editor.
Old 07-18-2008, 11:50   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you can only read General information via USB cable.
this is done by AT commands.
all other operations need to put phone to boot mode, which is only possible with serial cable.
so to start repair phones you must assemble cable.
The millionth question about the volume of the earpiece. geoffois iOS Application, games & media area 1 10-17-2009 09:52
Simple clarification of the large number of questions about the best hamada-almasry MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-12-2009 18:56
Question about rj-45 port of box svchost NSPRO 5 01-28-2009 14:23
cuple of questions about the clock and other stuff on gx30 cduuffo13 Sharp 0 10-24-2005 15:07
Question about Firmware 124-04 on 501 Junior Flasher Alcatel & TCL Old Models 0 01-01-2002 14:20
Page generated in 0.16031 seconds with 9 queries
