Old 04-25-2008, 08:30   #1 (permalink)
maheshsaiganesh's Avatar
Member: 289913
Thanks Meter: 125
ZTC 8188 succesfuly format
use L18A cable
software version: 1.07
cable type: 1x18 (L18A)
platform: MT6205, MT6217-MT6228
searching adapter at COM59...
adapter found, version: 2000
pins: 18, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6226
result: Rx:14 Tx:13
time required: 112 sec
Power On !
COM59 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:E541:FC04
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.0DF58BE5.[NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086061_600_V002 7.BIN_882F39B7].rpl
identification#1 detection finished
device-id: 0DF58BE5
identification#1 protocol ver: 04
ver. sw1: NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086061_600_V002 7.BIN
ver. sw2: 086061_600_V0027, 48C6D077
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086061_600_V002 7.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\ZTC 8188
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _0DF58BE5_NEOTEL26_06B_PCB01_GPRS_MT6226_S01.08606 1_600_V0027.BIN_882F39B7_20080425-125059.B0X.bin
Finished, time used: 374 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-25-2008, 08:35   #2 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
Nice Bro .......... Pinfinder ROCKS............
ztc k700 no format omkarvitekar Infinity-Box 6 07-15-2008 21:19
ZTC N82 can't format bachirDraria Infinity-Box 21 07-15-2008 20:40
ztc 268 ok formating infinity aleem26 Chinese Models & Cloned Phones 1 06-30-2008 19:14
need good eeprom for ZTC-8188 chinese urgently mughalG Infinity-Box 1 05-27-2008 16:21
ztc 8188 pinout needed kasim Infinity-Box 3 05-14-2008 15:00
Page generated in 0.17853 seconds with 9 queries
