12-22-2007, 19:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Algeria
Member: 220195 Status: Offline Thanks Meter: 49 | ZTC N82 can't format log opened: [22/12/2007 18:50:26] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.12 S/N: 06C3:010C Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM25 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #02 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #03 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00310000 Detected eeprom/ffs address is non-standard: 00310000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00310000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 004F0000 ffs chip: 00 eeprom/ffs area: 00000000:00310000-007FFFFF reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 71222-185409.B0E.bin flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error error: error# 0000FF3B error: flash erase error: 00310000 Write Fail Finished, time used: 191 sec Remove/Install battery now ! When I want to flash it, I don't know what flash I must choose because my backup doesn't give me the references of the flash |
12-23-2007, 08:59 | #3 (permalink) |
Member: 220195 Status: Offline Thanks Meter: 49 | Thanks for you answer I have tested all Speeds, but the problem is the same When I ty to flash with the support flash : error and the fone blink log opened: [23/12/2007 08:43:06] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.14 S/N: 0XXX:XXXC Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... CM_ZTC-N82_Nokia-N82_2x6pin_E00_2003[1].07.30i_MAUI.05B.W06_8m_En_w_eeprom.B0M.bin loaded Languages: En COM10 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #02 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #03 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 230400 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00320000 Detected eeprom/ffs address is non-standard: 00320000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00320000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 004E0000 ffs chip: 00 eeprom/ffs area: 00000000:00320000-007FFFFF reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 71223-085023.B0E.bin flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished Area: Firmware flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error Write: Firmware error: error# 0000FF3B error: flash write error: 00300000:00002000 Write Fail Finished, time used: 404 sec Remove/Install battery now ! |
12-24-2007, 07:10 | #5 (permalink) |
Member: 220195 Status: Offline Thanks Meter: 49 | Hello; I have tried safe and complet format I have tried all speeds I can read eeprom and flash I can't write all that, before even to write this theard The fone was in good state, while manipulating the menu, the fone blink What's : chip detection error ? I have selected, in chinese module : - other cloned - Nokia cloned - unknow cloned because I can't found ZTC N82 |
02-04-2008, 21:25 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello pes! please check with multimeter where is located your GND pin. if it is in position "3" then your pinout is: N82 dual sim 20 pin connector keyboard top 1...........20 3 Gnd 9 Rx 13 Tx |
02-05-2008, 12:09 | #8 (permalink) |
Freak Poster Join Date: May 2004 Location: Macedonia Age: 54
Member: 65593 Status: Offline Thanks Meter: 17 | in the telephone if keyboard is top conector is: 20............1 there its 3 gnd its correct when 9rx & 13tx ....telephone power but the program recognized nothing. please help |
02-05-2008, 13:28 | #10 (permalink) |
Member: 65593 Status: Offline Thanks Meter: 17 | nothing new...I try to change rx tx but still not new. @infinity help Is it possible to gnd itd 17 if keyboardtop 1.................20 but in my case is 20............3...1 and 3 is gnd best regards, pes |
02-22-2008, 22:28 | #15 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: in my mind Age: 43
Member: 204662 Status: Offline Thanks Meter: 91 | Quote:
Ztc N82-1 Successfully Formatted With Infinity | amit_varietymob | Infinity-Box | 5 | 07-22-2008 08:06 |
ztc k700 no format | omkarvitekar | Infinity-Box | 6 | 07-15-2008 21:19 |
ztc 268 ok formating infinity | aleem26 | Chinese Models & Cloned Phones | 1 | 06-30-2008 19:14 |
ZTC 8188 succesfuly format | maheshsaiganesh | Infinity-Box | 1 | 04-25-2008 08:35 |
ztc n82 (989) 2x6 pin out. | andr3_jc | Various | 2 | 02-23-2008 21:41 |
