09-28-2014, 13:53 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | MT6261 test with Infinity CM2MTK World 1st :) Code: Card found: S/N ******* Chinese Miracle II [MTK module] v 1.01b Operation : Check / Read Info [ v1.01b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : EFC1B4618B995BC946E9710B8E80CCBC BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.01b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : EFC1B4618B995BC946E9710B8E80CCBC BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Reading Flash Conent now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin FileVersion : MAUI.11C.W13.52.MP.V2.F1 Saved to : C:\Documents and Settings\Administrator\Desktop\mtk\Read_out\FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin Done! Elapsed: 00:00:14 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.01b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : EFC1B4618B995BC946E9710B8E80CCBC BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003B7000-0x003FDFFF , LEN : 0x00047000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:16 Reconnect Power/Cable! Code: Load File File_Info : FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin FileVersion : MAUI.11C.W13.52.MP.V2.F1 Load File Ok Operation : Flash [ v1.01b ] ======= Flash Files set for flashing : [ MCU ] : FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : EFC1B4618B995BC946E9710B8E80CCBC BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 File_Info : FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin FileVersion : MAUI.11C.W13.52.MP.V2.F1 Flash now Erase region , wait ... Write data , wait ... Write : FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin Done! Elapsed: 00:00:42 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.01b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 [ERROR] : DONE BB_CPU_SN : UNKNOW [ READ ERROR ] BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6261 SW : MAUI.11C.W13.52.MP.V2.F1 HW : Spice M-5408 IMEI[1] : 000000000000000 IMEI[2] : 000000000000000 Update IMEI[1] to : 911347506087165 Update IMEI[2] to : 911347506087173 Done! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Reset User Code Code: Operation : Reset UserCode [ v1.01b ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : EFC1B4618B995BC946E9710B8E80CCBC BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Backup exists , skip Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following 13 Users Say Thank You to pradeep_kus For This Useful Post: |
09-28-2014, 14:16 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | i think its new beta virsion in official virson 6261 not suporte http://forum.gsmhosting.com/vbb/10580621-post11.html see above |
09-28-2014, 14:29 | #5 (permalink) | |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Code: MT6261 test with Infinity CM2MTK World 1st :) | |
09-28-2014, 16:33 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Software is here: http://forum.gsmhosting.com/vbb/f296...-more-1863390/ |
The Following 3 Users Say Thank You to InfinitySupport For This Useful Post: |
09-29-2014, 18:49 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Released for public use: http://forum.gsmhosting.com/vbb/f296...orted-1863765/ |
