08-06-2008, 14:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | nokia 1325 cdma connect in pinfinder cable type: HF 4 pin (L4A) platform: MSM: Qualcomm CDMA, 3G searching adapter at COM3... adapter found, version: 2000 pins: 4, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. detecting pins... detected baudrate: 115200 result: Rx:1 Tx:4 time required: 5 sec Power On ! |
The Following User Says Thank You to Imrankhan For This Useful Post: |
09-14-2008, 12:51 | #5 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 194285 Status: Offline Thanks Meter: 53 | my pinfinder showing this software version: 1.14 cable type: HF 4 pin (L4A) platform: MSM: Qualcomm CDMA, 3G searching adapter at COM3... adapter found, version: 2000 pins: 4, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. detecting pins... detected baudrate: 115200 result: Rx:3 Tx:4 time required: 20 sec Power On ! |
error in connection in nokia sets | HUM | Nokia Hardware & Hardware Repair | 14 | 01-09-2015 07:36 |
~~ Nokia 1325 ORIGINAL_FLASHER & flash file~~ | king_of_rajasthan | Nokia CDMA | 25 | 08-14-2011 12:45 |
problem in nokia 1325 | ranagaurav | Nokia Hardware & Hardware Repair | 1 | 07-22-2009 18:37 |
nokia 2505 CDMA connecting with auto pinfinder ? | gsmsikar | Infinity-Box | 22 | 03-04-2009 15:31 |
n68 connects with pinfinder,but cant connect in chinese miracle | GOODNESS | Infinity-Box | 13 | 07-24-2008 21:33 |
