09-05-2015, 06:18 | #24976 (permalink) |
Freak Poster Join Date: Jun 2015 Location: PAKISTAN Age: 47
Member: 2418725 Status: Offline Sonork: 100.1679834.ANDROID BOSS. Thanks Meter: 166 | Voice Xtreme V15 Read Factory File & Nvram File Voice Xtreme V15 Read Factory File & Nvram File Code: Operation : Read Flash [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 84 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393010138D89046187 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 11010030303447393010138D89046187 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Xtreme_V15 ProdName : Xtreme_V15 ProdModel : Xtreme_V15 Device : Xtreme_V15 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_hexing72_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / hexing72_cwet_kk / EMMC FW Size : 818 MiB Scatter saved to : C:\Users\ANRID BOSS MOBILE\Desktop\Voice V15\MT6572__Xtreme_V15__Xtreme_V15__Xtreme_V15__4.4.2__ALPS.KK1.MP7.V1\ All done! Done! Elapsed: 00:03:51 Reconnect Power/Cable! Operation : Read NVRAM [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 84 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393010138D89046187 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 11010030303447393010138D89046187 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_P4_1_wg_n Read Ok, MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_P4_1_wg_n_eMMC.spnv saved Done! Elapsed: 00:00:24 Reconnect Power/Cable! BR. ANDROID BOSS |
The Following 4 Users Say Thank You to ..ANROID BOSS.. For This Useful Post: |
09-05-2015, 06:49 | #24977 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Qmobile i10 Code: Operation : Flash [ v1.28 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201A2B7E08091F3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201A2B7E08091F3 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : lcsh82_wet_hz_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000001CEA80000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lcsh82_wet_hz_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:18 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:38 Update RomInfo done Done! Elapsed: 00:04:23 Reconnect Power/Cable! |
09-05-2015, 07:33 | #24978 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | micromax canvas gold read pattern lock Code: Chinese Miracle II [MTK module] v 1.28 Operation : Read PatternLock [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010042574243335202972BB68781CD DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 15010042574243335202972BB68781CD [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1535 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 2586 Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
09-05-2015, 08:09 | #24979 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile_A120_ Dead Recovery Time Only 03:08" Successful, Done .:: BY ::. ..::: Chinese Miracle-2 MTK:::.. Code:
The Following User Says Thank You to kabul For This Useful Post: |
09-05-2015, 08:51 | #24980 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Rm-969 Code: registered to: SAEEDULLAH_KHAN Connect phone on selected interface... Core : v2.10 , MTKx FlashEngine : v8.1 Verify files ... MAUI : RM-969_ROM_eMP_20.14.11 VIVA : RM-969_VIVA_eMP_20.14.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_20.14.11_001 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.14.11_001 JMPT : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_20.14.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 26 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 8EAAC23BE0C6471D8531837A586B3886 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_20.14.11 SecureDecrypt : RM-969_VIVA_eMP_20.14.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_20.14.11_001 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.14.11_001 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_20.14.11_001 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 === Backup Enabled Reading RPL backup... Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info : IMEI : 353057069697020 BBUID : 8EAAC23BE0C6471D8531837A586B3886 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 353057069697020_MTK.mtsec === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_20.14.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_20.14.11_001 Write : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.14.11_001 Write : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_20.14.11_001 Write : RM-969_VIVA_eMP_20.14.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_20.14.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_IJ_eMP_20.14.11_001 [VERIFY] DONE : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.14.11_001 [VERIFY] DONE : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_20.14.11_001 [VERIFY] DONE : RM-969_VIVA_eMP_20.14.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:40 Reboot phone Ok Connect phone on selected interface... |
09-05-2015, 08:54 | #24981 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | QMobile A900i Read FFw Done Code: Operation : Read Flash [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42015CC0C6BA7123 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42015CC0C6BA7123 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobile ProdModel : A900i Device : QMobile AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_gionee82_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : spdata.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / gionee82_cwet_kk / EMMC FW Size : 1199 MiB Scatter saved to : C:\Users\Luckey1\Desktop\MT6582__QMobile__A900i__QMobile__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:05:59 Reconnect Power/Cable! |
09-05-2015, 09:13 | #24982 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Infinity Chinese Miracle SPDCM2 X2 Music Qmbile SC7715 Nand Format Success No Dead Risk to reset user code Code: Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 55 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Br GSM City |
The Following 2 Users Say Thank You to Muhammadsaqib11 For This Useful Post: |
09-05-2015, 09:49 | #24983 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Samsung Galaxy Grand Neo GT-I9060 (Dual Sim) Samsung Galaxy Grand Neo GT-I9060 (Dual Sim) Mobile Facotory Firmware + NVRAM Reading done. (Easy Backup) Logs:- Code: Operation : Read Flash [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D029A014E61304D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_hexing75_jb.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : EBR2 [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img ProdName : GT-I9082 ProdModel : GT-I9082 Device : GT-I9082 AndroidVer: 4.2.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.MP.V1.16 [ScatCFG] : MT6575 / V1.0.0 / hexing75_jb / EMMC FW Size : 665 MiB Scatter saved to : F:\Firmware\MT6575___GT-I9082__GT-I9082__4.2.2__ALPS.JB.MP.V1.16\ All done! Done! Elapsed: 00:04:41 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D029A014E61304D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6575_S01_MAUI_11AMD_W12_22_SP_V23 Read Ok, MT6575_S01_MAUI_11AMD_W12_22_SP_V23_eMMC.spnv saved Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
09-05-2015, 10:18 | #24984 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | CPU: MT6575 without data loss pattern unlock done miracle box Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM9) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6575 SW: E201 Ver: CB00 Downloading Boot8 ... EMMC Size: 0x00E7000000 Flash Type: EMMC INT/EXT RAM Size: 0x0+0x0 Reading ROOT DATA...DE0000_600000 C:\Program Files\Miracle Box\MTK6575emmcboot1509051414.img Writing ROOT DATA...DE0000_600000 Done. (Enter Any Pattern To Unlock Screen) >>total£º 0 mins7 s |
09-05-2015, 10:20 | #24985 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | nokia 500 Code: Core : v2.10 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm934_14.0.6.mcusw.fls PPM : rm934_14.0.6_059S9V4_m1.rofs.fls CNT : rm934_14.0.6_059S9V4_m1.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 221 [XMM2210 QIMING] IF uCHIPID : 19421909A2A961C4 IF Resp Data : 194200021C030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : 1_1345.300_MKEYSKEY QIMING EEP config Ok FLASHID : 52F00000 , [ NOR ] Boot conf set, Target Ready Boot done! ===Flashing [MCU]=== Processing file : rm934_14.0.6.mcusw.fls Region count : 2 00 : [ PSI ] : rm934_14.0.6.mcusw.fls.fls 01 : [ Code ] : rm934_14.0.6.mcusw.fls.fls Parse done , flashing now Flash : 00 : rm934_14.0.6.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40000000 , Len : 0x00020000 Erase done Region Start : 0x40000000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done rm934_14.0.6.mcusw.fls.fls image flash done Flash : 01 : rm934_14.0.6.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40040000 , Len : 0x00020000 Erase done Erase area 0x01 , Start 0x40060000 , Len : 0x00160000 Erase done Erase area 0x02 , Start 0x40340000 , Len : 0x02540000 Erase done Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000 Erase done Region Start : 0x40040000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40060000 , Data Len : 0x00160000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40340000 , Data Len : 0x02076498 Region Load done Wait for phone write all data ... Write done rm934_14.0.6.mcusw.fls.fls image flash done ===Flashing [PPM]=== Processing file : rm934_14.0.6_059S9V4_m1.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000 Erase done Region Start : 0x42880000 , Data Len : 0x005EF1C4 Region Load done Wait for phone write all data ... Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm934_14.0.6_059S9V4_m1.image.fls Region count : 1 00 : [ Cust ] : rm934_14.0.6_059S9V4_m1.image.fls.image.fls Parse done , flashing now Flash : 00 : rm934_14.0.6_059S9V4_m1.image.fls.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x43800000 , Len : 0x04600000 Erase done Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000 Erase done Region Start : 0x43800000 , Data Len : 0x02800000 Region Load done Wait for phone write all data ... Write done rm934_14.0.6_059S9V4_m1.image.fls.image.fls image flash done Flashing done! Total flash time : 00:02:24 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:45 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-05-2015, 10:32 | #24987 (permalink) |
Member: 2418725 Status: Offline Sonork: 100.1679834.ANDROID BOSS. Thanks Meter: 166 | Qmobile e9 invalid imei done QMOBILE E9 INVALID IMEI DONE BR. ANDROID BOSS |
The Following User Says Thank You to ..ANROID BOSS.. For This Useful Post: |
09-05-2015, 10:51 | #24989 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Pakistan TDM
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | Q A500 logo hang solve with Formate Code: Operation : Format FileSystem [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001153030534AE037004D6740EB5E DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D0037E05EEB4067 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to Bazeed_khan17 For This Useful Post: |
09-05-2015, 11:10 | #24990 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 112 Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm837__03.51.mcusw PPM : rm837__03.51.ppm_m2 CNT : rm837__03.51.image_m2_059P7C1 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.50_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm837__03.51.mcusw Image : rm837__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:38 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x87F4 ===Flashing [PPM]=== File : rm837__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x41BC0000 , Len : 0x0030F7C0 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x46E6 ===Flashing [CNT]=== File : rm837__03.51.image_m2_059P7C1 Image : package_m2_059P7C1.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:33 Write , Start : 0x421C0000 , Len : 0x00EE0000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x2559 Flashing done! Total flash time : 00:03:48 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:43 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
