Old 10-18-2017, 18:34   #45631 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
QMobile X30 Hang Logo Write File
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483447326111018D6A0D69628D
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111018D6A0D69628D
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xD5229C25ED836FF40E0F855AEAA54A26
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : TINNO
ProdName  : QMobile X30
ProdModel : QMobile X30
Device    : QMobile X30
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3760 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:16
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4050ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:45
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:21
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 10-18-2017, 18:35   #45632 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Motorola Xt1254 Frp Reset
Infinity-Box Android Service Tool [AST] v1.01
Operation : Enable ADB (Moto) [ v1.01 ]
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with  : 192.168.137.2
Connected to device!
Device : XT1254
VerInfo : QUARK_CUST
Version : Blur_Version.24.91.5.quark_verizon.verizon.en.US
Enabling ADB ...
1. Disconnect cable from device, press and hold 'VOLUME_DOWN' and 'POWER_ON'
2. Select 'FACTORY MODE' and press 'POWER ON'!
3. Wait for device boot completely!
Done!
Elapsed: 00:00:09
Operation : Reset FRP (ADB) [ v1.01 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : quark_verizon
Model  : XT1254
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:15
Old 10-19-2017, 04:57   #45633 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile Eco2 SPD6531 Logo Stuck Fix Only Formate With Infinity CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 9 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:09
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 10-19-2017, 05:06   #45634 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Huawei Y560-U02 SPD77xx Logo Hang Fix Only Formate With Infinity CM2
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 23 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:24
Old 10-19-2017, 05:44   #45635 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile S1 MT6580 Pin Lock Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A483847316505072A523192135F
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505072A523192135F
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395A78D96B10AF47D299C442323
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSGS Ok!
LSSKY Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:21
Old 10-19-2017, 06:17   #45636 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile B67 MT6261 Read Code Done With King Infinity CM2
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 16 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 5E937B89713C1EB7B56EEAF91C8753B3
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 7171
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:21
Old 10-19-2017, 07:59   #45637 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Voice V780 SPD6531 Logo Stuck Fix Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
Format Block Done!
Done!
Elapsed: 00:00:10
Old 10-19-2017, 08:31   #45638 (permalink)
monusah25's Avatar
Member: 2650572
Sonork: 100.107126
Thanks Meter: 151
Diamond R2 Read Firmware Done With GREAT Cm2 Tool
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Read FullFlash [ v1.27 ]
3. Insert cable
Phone found! [ 39 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 39 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 39 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name  : sp7731c_c7356_wvga_oversea
Model Brand : Diamond
Model Device: R2
AndrVersion : 6.0
BaseBand CPU: SP7731CEB
Project Ver : C7357_BP_BP241_Diamond_360X640_324_B1V01.01B05
Model Ext   : BP241
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W17.21.3_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_360x640.bin
[Read Ok] : fblogo_360x640.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Read Ok] : sysinfo.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 1888 MiB
Saved to : C:\InfinityBox\CM2SPD\Read_out\SP7731CEB_R2_6.0_C7357_BP_BP241_Diamond_360X640_324_B1V01.01B05_BP241\
Done!
The Following User Says Thank You to monusah25 For This Useful Post:
Old 10-19-2017, 09:35   #45639 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Smile Nokia 105 DS flashing done
Core : v2.29 , MTKx FlashEngine : v14.0
Verify files ...
MAUI : RM-1190_DUBAI_ROM_eMP_11.00.11
VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11
LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
JMPT : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
 - > MODE : FullFlash
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 77 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0001
BB_CPU_SN : A6776B8C966020C64412198E1B9A8226
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : DUBAI61D.11.00.11.p1
BROM/BL stage done
DA_eMP_Dubai.fg
DA_VERIFY : 00
DA_JUMP   : 00100000
DA_AUTH   : Passed!
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0113 ,
[0] : FLASH_DIE : 00EF 0070 0016 0000
FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000
SecureDecrypt : RM-1190_DUBAI_ROM_eMP_11.00.11
SecureDecrypt : RM-1190_DUBAI_VIVA_eMP_11.00.11
SecureDecrypt : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
SecureDecrypt : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
SecureDecrypt : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
Executing FFS FORMAT now...
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
OVRLP : 000069B900000001
PHPID : DUBAI61D.11.00.11.p1
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1190_DUBAI_ROM_eMP_11.00.11
Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_VIVA_eMP_11.00.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1190_DUBAI_ROM_eMP_11.00.11
[VERIFY] DONE : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
[VERIFY] DONE : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
[VERIFY] DONE : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
[VERIFY] DONE : RM-1190_DUBAI_VIVA_eMP_11.00.11
CODE_VERIFY : Ok
Flashing done!
Total flash time : 00:00:58
Reboot phone Ok
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 10-19-2017, 09:55   #45640 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I4 SPD77xx Dead Set Re Alive Done By Flashing With Infinity CM2
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : QMobilei4_MP_20150721.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC7731_UMS
PacVersion : QMobilei4_MP_20150721
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : u-boot-spl-16k.bin
File : SC7702_sc7731g_band128.bin
File : DSP_DM_G2.bin
File : SC8800G_x30g_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : LOGO.bmp
File : charge.bmp
File : prodnv.img
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 23 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC7702_sc7731g_band128.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : SC8800G_x30g_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : LOGO.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : charge.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASESD
Current Part : internalsd
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:09:09
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Old 10-19-2017, 10:01   #45641 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile L2 Classic SPD6531 Call Logs Not Show Recover Done By Flashing With Infinity
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:06
Old 10-19-2017, 10:37   #45642 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile Qmobile i6 metal one reset frp lock done with king infinity cm2
QMOBILE I6 METAL ONE RESET FRP LOCK DONE WITH KING INFINITY CM2
Operation : Check/Read Info [ v1.27 ]
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : i6_Metal_ONE
Model Brand : QMobile
Model Device: i6_Metal_ONE_new
AndrVersion : 6.0
BaseBand CPU: I6_METAL_ONE
CompileDate : 2/28/2017 10:16:31 AM
Project Ver : MRA58K release-keys
Model Ext : QMobile i6 Metal ONE
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:20
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:29
If You Like My Post Press Thanks
ShahiD
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 10-19-2017, 10:40   #45643 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile Qmobile i8i hang on logo done with king infinity cm2
QMOBILE I8I HANG ON LOGO DONE WITH KING INFINITY CM2
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : I8i
Model Device: I8i
AndrVersion : 6.0
BaseBand CPU: SP7731CEA
CompileDate : 7/21/2017 11:50:35 AM
Project Ver : QMobile I8i_MP_21_07
Model Ext : QMobile I8i
Elapsed: 00:00:22
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:25
ShahiD
The Following 3 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 10-19-2017, 10:44   #45644 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile Qmobile m95 hang on logo done with king infinity cm2
QMOBILE M95 HANG ON LOGO DONE WITH KING INFINITY CM2
Set mode to : SP [SC773x] eMMC [Android 5.x]
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : scx35_sp7731geaplus_dt
Model Device: scx35_sp7731gea
AndrVersion : 4.4.3
BaseBand CPU: SP7731GEA
CompileDate : 7/31/2015 12:00:38 PM
Project Ver : KOT49H 14B_test-keys
Model Ext : QMobile M95
Elapsed: 00:00:21
Infinity SC Firmware Detected
FW Size : 1239 MiB
Load Ok!
======= Flash
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:03:16
ShahiD
Old 10-19-2017, 10:49   #45645 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile Haier g30 hang on logo done with king infinity cm2
HAIER G30 HANG ON LOGO DONE WITH KING INFINITY CM2
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 45010053454D3034473AF00339455291
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , G40ME
[eMMC] : FLASH_CID : 45010053454D3034473AF00339455291
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0x0B9C44DE75DA1DF100BBD7A27F826AF6
SOC VERIFY : C1
Boot Ok!
Brand : Haier
ProdName : G30
ProdModel : G30
Device : G30
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : G30-H01-S023-PK
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P6_1_wg_n
EXTRA :
LCD [0] : ili9806e_fwvga_dsi_vdo_zgd
LCD [1] : ili9806e_fwvga_dsi_vdo_huashi
LCD Res : 854x480
TOUCH [0] : ft6306_yuye
TOUCH [1] : GT9XX_hotknot
CAM [0] : gc2145_mipi_yuv_m11
CAM [1] : hi541_mipi_yuv_m11
CAM [2] : ov5645_mipi_yuv_m11 sp2529_mipi_yuv_m11
CAM [3] : s5k4ecgx_mipi_yuv
CAM [4] : #s5k8aayx_yuv
MODEM : huiyue72_w_kk_hspa_m11_b1b8_pk
LOCALE : en_US ur_PK fa_IR
Done!
Elapsed: 00:00:16
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:30
ShahiD
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.64105 seconds with 10 queries
