08-28-2018, 08:53 | #52726 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | GFive Crown Format And Read Flash FIle Done 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_027 CC752A01B_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:22 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Read Ok, 4194304 bytes Saved to : C:\Users\AkhtarAli\Desktop\SPRD_SPI_WINBOND_W25Q_4MiB.bin Done! Elapsed: 00:01:12 Reconnect Power/Cable! |
08-28-2018, 10:38 | #52727 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | INFINIX X572 Frp Reset Done Via Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 470001154D4236583BC5034257B8E1D6 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6X [eMMC] : FLASH_CID : 150100475836424D4203C53BD6E18457 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x97F8A39E4045C08B60ECA91410FB63CB INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
08-28-2018, 10:45 | #52728 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | VIVO Y53(1606) Format + Frp Reset Done In Single Click Via Infinity CM2 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : AFCED579 ID_BLOCK_L : A27D26BD28AF6422FE3E32C03C63D7EC ID_BLOCK_L : 87CC46B54BB7BE078EC7394AE52F0258 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
08-28-2018, 11:30 | #52729 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Telenor Infinity E2 MT6735 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33314543860D4295A4929A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D86439A92C395 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395BC0CA10F6A65952CD0F253E9 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
08-28-2018, 11:33 | #52730 (permalink) |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | q mobile i9 read flash done 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051A45CA6C9C04F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051A45CA6C9C04F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xEE6AE9A269B9DF8D1A78A6A20D45156D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : QMobile ProdName : QMobile i9 ProdModel : QMobile i9 Device : QMobile i9 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.6 [Read Ok] : preloader_s5501.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / s5501 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1195 MiB Scatter saved to : Z:\q mobilie android\I-FOLDER\MT6582__QMobile__QMobile_i9__QMobile_i9__4. 2.2__ALPS.JB5.MP.V1.6\ All done! Done! Elapsed: 00:06:26 Reconnect Power/Cable! |
08-28-2018, 11:52 | #52731 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobvile I4 SPD77XX Logo Stuck Fix Only Formate With Infinity CM2 Card found: S/N : A19EC787 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000E6507000 State : 0x0001 Mount : /cache Size : 0x0000000008F0D000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:29 Reconnect Power/Cable! Last edited by azhergoga007; 08-28-2018 at 12:00. |
08-28-2018, 12:01 | #52732 (permalink) |
Freak Poster Join Date: Jan 2011 Location: india
Member: 1505730 Status: Offline Sonork: 100.1618029 Thanks Meter: 207 | oppo a83 2018 cph1827 firmware read success Boot done! Patch Level : N6F26Q Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2018-07-05 Build Time : 1533203675 Product Manfct : OPPO Board Platform : mt6763 Product Model : OPPO A83js Product Brand : OPPO Product Name : A83js Product Device : M6763D Product Board : full_oppo6763_17101 Product Info : oppo6763_17101 SW Version : A.18 SW OTA Version : M6763D_11.A.18_0180_201808021611 SW OTA Name : A83jsEX_11_A.18_180802 Display ID : A83jsEX_11_A.18_180802 Kernel Info : 4.4.22-G201808021611 MT6763__OPPO__OPPO_A83js__7.1.1__A83jsEX_11_A.18_1 80802__N6F26Q__oppo6763_17101 Read : preloader.bin Read : recovery.img Read : oppo_custom.img Read : persist.img ExtSparse : Compression ratio : 100% Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : tz.img Read : system.img ExtSparse : Compression ratio : 4% Read : cache.img Read : userdata.img FW Size : 5.06 GB Android Info saved : _Android_info.txt Scatter : MT6763_Android_scatter.txt Saved to : E:\cph1827\New folder\MT6763__OPPO__OPPO_A83js__7.1.1__A83jsEX_11 _A.18_180802__N6F26Q__oppo6763_17101\ Done! Elapsed: 00:09:30 |
08-28-2018, 12:09 | #52733 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Lava IRIS 65 FRP done in seconds ;) Code: Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM45) MODE : BOOTROM PORT : 45 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1816 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6739 EMI : SRC : preloader_lava6739_sp65.bin EMI : CNT : 0004 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D4203A33697C455C7 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C3DC131EE471D540E80AC4EF57367053 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : LAVA_iris65_1_8_S115_INT_18F07 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-02-05 Build Time : 1528373369 Product Model : iris65 Product Brand : LAVA Product Name : iris65 Product Device : iris65 Product Manfct : LAVA Product Info : iris65 Board Platform : mt6739 USERDATA : ENCRYPTED Code: Operation : Reset Settings/Format FS [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM45) MODE : BOOTROM PORT : 45 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1816 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6739 EMI : SRC : preloader_lava6739_sp65.bin EMI : CNT : 0004 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D4203A33697C455C7 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C3DC131EE471D540E80AC4EF57367053 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to kamal_singla For This Useful Post: |
08-28-2018, 13:07 | #52734 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile D2 V2 6531E Format And read Flash File Done Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.03 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR SPRD mode : SC6531 : REV : E000 : NOR Operation : Format FileSystem [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_058 E0B95602F_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:43 Reconnect Power/Cable! Operation : Read Flash [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Read Ok, 4194304 bytes Saved to : C:\Users\AkhtarAli\Desktop\SPRD_SPI_WINBOND_W25Q_4 MiB.bin Done! Elapsed: 00:01:13 Reconnect Power/Cable! |
08-28-2018, 13:36 | #52735 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Alcatel 5065D QLM FRP Reset Done With King Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Emergency driver NOT found, make sure it installed! Download and install from support area following file : >> InfinityBox_Update_CM2QLM_Drivers_v1.xx.rar Install it, go to /CM2QLM/Drivers/ and install ALL packages inside >> If device detected by PC, but not detected by SW : > 1. Open device manager, find in PORTS section "9008" device > 2. Change (update) driver to Emergency (or) QHSUSB_BULK Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01824482 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 07E19B63D25845403F14FCE12E75FDCD ID_BLOCK_L : 59349A3526A911923786CB0002EDFBC0 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
08-28-2018, 14:03 | #52736 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | China Tab Siccoo MT6572 Logo Stuck Fix Only Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : FE014E4D4D433034474215C24D60B167 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , G40CM [eMMC] : FLASH_CID : FE014E4D4D433034474215C24D60B167 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000EA000000 [eMMC] : FLASH_UCP : 3744 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3953AB9CA7DD6AE50DDD1C961C4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
08-28-2018, 14:08 | #52737 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | SPD samsung NOTE 9 read write done cm2 - > Wait phone connected ... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : Note 9 Model Brand : Note 9 Model Device: Note9 AndrVersion : 7.1 BaseBand CPU: SP7731CEB Project Ver : AD192_M52_N01__BAND15_HD_DHD_091_V1.0_20171223 Model Ext : Note 9 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W17.27.4_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_720x1280.bin [Read Ok] : fblogo_720x1280.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1879 MiB Saved to : C:\Users\ROB\Documents\SP7731CEB_Note9_7.1_AD192_M 52_N01__BAND15_HD_DHD_091_V1.0_20171223_Note_9\ Done! Elapsed: 00:09:07 Reconnect Power/Cable! worlds best TOOL CM2 |
08-28-2018, 14:59 | #52738 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | QMobile B60 MT6260 Logo Stuck Fix Only Formate With Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 7973915B06F6E5B0FC22444D4B0F7E02 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x0039A000-0x003FDFFF , LEN : 0x00064000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
08-28-2018, 15:55 | #52739 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | Xiaomi redmi 5 plus FRP done :) Xiaomi redmi 5 plus FRP Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : CDCCCEA1 ID_BLOCK_L : BDFA6945F7FE22751C50E0A73BAB5364 ID_BLOCK_L : 94601AB97C5F77A7502BE8DBA412DE83 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Brand : xiaomi ProdName : vince ProdModel : Redmi 5 Plus Device : vince AndroidVer: 7.1.2 Manufact. : Xiaomi SysPatch : N2G47H DevComTime: 24-05-2018 19:21:45 QLMxCPU : MSM8953 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : CDCCCEA1 ID_BLOCK_L : BDFA6945F7FE22751C50E0A73BAB5364 ID_BLOCK_L : 94601AB97C5F77A7502BE8DBA412DE83 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
08-28-2018, 17:31 | #52740 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | General Mobile 4G Dual Frp Reset Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 181DCCBB ID_BLOCK_L : C83852AC0B979C8F782D2728F7B2C20A ID_BLOCK_L : F48F31989D04B63FD21D76AFA5486665 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
