Old 11-16-2019, 14:31   #61246 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Oppo A31 QLM Logo Stuck Fix Ony Formate With King Infinity CM2
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 194B2C88
ID_BLOCK_L : 1DE79D79D4424F7A251AFADB247FF7D7
ID_BLOCK_L : 067DC36A6FF658EDE0CF80794BBAB497
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Done!
Elapsed: 00:00:41
Old 11-16-2019, 16:42   #61247 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
NOkia 108 Pinlock Format
Operation : Format FileSystem [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 366 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 91641EFC7BA93DDC6BB4969CCCAB27A9
BROM Protocol Version : 05
BROM Status : 1012
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_NkB.fg
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
Executing FFS FORMAT now...
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:15
Reconnect Power/Cable!
Old 11-16-2019, 16:42   #61248 (permalink)
Manikanika81's Avatar
Member: 2897012
Thanks Meter: 400
****EL S5506 read user code done by cm2
SPRD mode : SC6531 : REV : C000 : NOR : [ 4MB-8MB ]
Operation : Read UserCode [ v1.05 ]
MODE : From Device
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Spreadtrum Boot Block version 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Reading data ...
Sorting data ...
STATE : ACTIVE : CODE : 4130
Done!
Elapsed: 00:00:36
Old 11-17-2019, 08:30   #61249 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Motorolla XT1254 FRP Reset Done With King Infinity CM2
Card found : A19EC787 , v0138
Infinity-Box Android Service Tool [AST] v1.03
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with : 192.168.137.2
Connected to device!
Device : XT1254
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:00:33
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : quark_verizon
Model : XT1254
FRP reset passed! Make FACTORY RESET from menu!
-- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:18
Old 11-17-2019, 09:16   #61250 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Oppo A37 QLM FRP Reset Done With King Infinity CM2
Operation : Read PatternLock [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 2871CCC8
ID_BLOCK_L : DD275DB914828FBA65DA3A1BE4BF3717
ID_BLOCK_L : 285BE54449D8028306F1DA13119C8AB1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 53286417
Done!
Elapsed: 00:00:21
Old 11-17-2019, 10:56   #61251 (permalink)
Member: 2935044
Thanks Meter: 75
iBRIT Ver 7.0 FRP Reset Done By 1 Click With CM2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=p_SRmpIVsPk
The Following User Says Thank You to AAdnan Mobile For This Useful Post:
Old 11-17-2019, 11:05   #61252 (permalink)
Member: 2935044
Thanks Meter: 75
QMobile i6 Metal ONE FRP Reset Done By 1 Click With CM2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=Pf45ANwSiLE
Old 11-17-2019, 11:14   #61253 (permalink)
Member: 2935044
Thanks Meter: 75
QMobile i9 FRP Reset Done By 1 Click With CM2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=Sztzcx7cdJs
Old 11-17-2019, 11:21   #61254 (permalink)
Member: 2935044
Thanks Meter: 75
QMobile Q3310 MINI Reset Pin Code Done With CM2SPD
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=szWOq5azijI
Old 11-17-2019, 11:30   #61255 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
OPPO A37f Pattern Read
Brand     : OPPO
ProdName  : A37f
ProdModel : A37f
Device    : A37f
AndroidVer: 5.1.1
SWVersion : A37fEX_11.A.28_INT_028_201710081545
Manufact. : OPPO
SysPatch  : LMY47V
DevComTime: 2017-10-08 9:26:49 AM
QLMxCPU   : MSM8916
USERData : NORMAL
GCSec    : EMPTY
Done!
Elapsed: 00:00:18
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 26954A7D
ID_BLOCK_L : 0AFA906EC955424D3A6FE1EE297080C8
ID_BLOCK_L : 4C07892015BC2EA75A95FE373DF0EEED
Boot Ok!
PatternLock sequence : 2457
Done!
Elapsed: 00:00:24
Old 11-17-2019, 12:16   #61256 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Wintel Big Tiger Code Read
SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ]
Operation : Read UserCode [ v1.04 ]
MODE : From Device
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Reading data ...
Sorting data ...
STATE : ACTIVE : CODE : 5524420
Done!
Elapsed: 00:00:25
Old 11-17-2019, 15:21   #61257 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Nokia 1 Hang Logo Format
Brand     : Nokia
ProdName  : Frontier_00WW
ProdModel : Nokia 1
Device    : FRT
AndroidVer: 8.1.0
Done!
Elapsed: 00:00:28
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer   : 0x00FF
BLVersion : 0x0002
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9B
NAND Flash : NOT INSTALLED
eMMC Flash : 484A01906134473867C7A532531D765C
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4G8
[eMMC] : FLASH_CID : 90014A483847346132A5C7675C763553
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0xD5229C2571FCBB0FB437D91EBF6E9691
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:35
Old 11-18-2019, 08:15   #61258 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile S4 MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0138
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100513832334D4200588C6875836F
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D4200588C6875836F
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F3951008F9BCA679BE096933E4B3
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:14
Old 11-18-2019, 08:19   #61259 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I5 MT6580 Restert Fix Only Formate With King Infinity CM2
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A4834473164040502A2D73291E5
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040502A2D73291E5
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3953B42C2F9B7CC4B6B5467CAF3
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:39
Old 11-18-2019, 09:51   #61260 (permalink)
chadzar's Avatar
Member: 2489690
Thanks Meter: 289
World's first itel a33 read privacy done by cm2 only
Card found : F21468FB , v0138
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.02
Load IDBase v10107 Ok!
Operation : Read PrivacyLock [ v2.02 ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Itel : itel W5503
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
PASSWORD : 076163
CONTACTS :
Done!
Elapsed: 00:01:34
The Following 2 Users Say Thank You to chadzar For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.69915 seconds with 10 queries
