12-28-2019, 18:33 | #61801 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Tidikelt
Member: 834813 Status: Offline Thanks Meter: 125 | Oppo a37f Code: Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 23F00C00 ID_BLOCK_L : 857F15E14CDAC7C2BD926263ACF77F4F ID_BLOCK_L : ABDA64C7C85B830085702592901F0932 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 12357896 Done! Elapsed: 00:01:06 Reconnect Power/Cable! |
12-28-2019, 19:12 | #61802 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Oppo F3 CPH1609 Hang On Logo Done Code: Preloader [HW DEV] Info : EMI : DEV : MT6755 EMI : SRC : preloader_oppo6750_16391.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 13014E51334A393756 : VEN : MICRON | DEV : Q3J97V : RAM : [ 3.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] Operation : Write Flash [ v2.07 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :16 [FL] : Set : preloader_oppo6750_16391.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : md1arm7.img [FL] : Set : md3rom.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xF96A0221 [ 3.90 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM416) MODE : BOOTROM PORT : 416 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : Oppo : F3 64GB | Manual : Disabled BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_oppo6750_16391.bin EMI : CNT : 0008 EMI : [00] : ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ] EMI : [01] : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [02] : ID : 13014E51334A393756 : VEN : MICRON | DEV : Q3J97V : RAM : [ 3.00 GB ] EMI : [03] : ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [04] : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [05] : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ] EMI : [06] : ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3.00 GB ] EMI : [07] : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100524836344D42055807CC36341F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 30D84DB0A102912F5F090ED9F2B5F561 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM95) MODE : PRELOADER PORT PORT : 95 Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000004088000 Erase : 0x0000000006588000 : 0x0000000000B00000 Erase : 0x000000000A088000 : 0x0000000004000000 Erase : 0x000000000F800000 : 0x0000000001000000 Erase : 0x0000000010B00000 : 0x0000000002400000 Erase : 0x0000000013400000 : 0x0000000113400000 Erase : 0x0000000127000000 : 0x0000000190000000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : MD1ARM7 Write : MD3IMG Write : LK Write : LK2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:55 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to CYB3R GSM For This Useful Post: |
12-29-2019, 02:29 | #61803 (permalink) |
Freak Poster Join Date: Apr 2019 Location: Egypt Age: 25
Member: 2906511 Status: Offline Thanks Meter: 136 | INFINIX HOT 8 (X653) FRP REMOVED BY INFINITY CM2MT2 (first in the world ) SELECT INFINIX SECURE BASE AND IDENTIFY AND REMOVE FRP PROTECTION LOG: Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464536324D42030F8E9A7A9603 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8F42374392E0C5C16C47ADB99BECB20 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X653-H6114NOP-PGo-191022V183 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-10-05 Build Time : 1571748344 Product Model : Infinix X653 Product Brand : Infinix Product Name : H6114 Product Device : Infinix-X653 Product Manfct : INFINIX MOBILITY LIMITED Product Info : x653_h6114 Product Board : Infinix-X653 Board Platform : mt6761 USERDATA : ENCRYPTED NVRAM check : Passed! Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464536324D42030F8E9A7A9603 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8F42374392E0C5C16C47ADB99BECB20 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:01:50 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to safina gsm For This Useful Post: |
12-29-2019, 04:18 | #61804 (permalink) |
No Life Poster Join Date: Jan 2014 Location: CUBA Age: 32
Member: 2108610 Status: Offline Thanks Meter: 379 | Infinity RKT 2.01 Read Firmware 8.1.0 Bleck Clever7 Ok! Infinity-Box RockChip Service Tool [RKT] v2.01 Operation : Read Firmware [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C644432A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020C000000 ( 8,19 GiB ) Flash Info : 8388608/16384/32/60/1 Connect Ok! Brand : BLECK ProdName : BL-919845 ProdModel : BL-919845 Device : BL-919845 AndroidVer: 8.1.0 Manufact. : BLECK SysPatch : OPM6.171019.030.B1 DevInfo : BLECK__BLECK__ANDR_v8.1.0__BL-919845__BL-919845__BL-919845 Reading Flash Content ... [Read Ok] : param.cfg [Read Ok] : u-boot.img [Read Ok] : trust.img [Read Ok] : misc.img [Read Ok] : resource.raw [Read Ok] : kernel.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : backup.img [Read Ok] : security.bin [Read Ok] : system.img [Read Ok] : vendor.bin [Read Ok] : oem.img Read finished! Configuration : / 2C644432A5 [ NAND ] Firmware Size : 1552 MiB Done! Elapsed: 00:02:21 |
The Following 2 Users Say Thank You to yosbel182us For This Useful Post: |
12-29-2019, 04:47 | #61805 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | Read Firmware Bleck Clever7 Rockchip RK3126C 8.1.0 Infinty RKT Ok!! Infinity-Box RockChip Service Tool [RKT] v2.01 Operation : Read Firmware [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C644432A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020C000000 ( 8,19 GiB ) Flash Info : 8388608/16384/32/60/1 Connect Ok! Brand : BLECK ProdName : BL-919845 ProdModel : BL-919845 Device : BL-919845 AndroidVer: 8.1.0 Manufact. : BLECK SysPatch : OPM6.171019.030.B1 DevInfo : BLECK__BLECK__ANDR_v8.1.0__BL-919845__BL-919845__BL-919845 Reading Flash Content ... [Read Ok] : param.cfg [Read Ok] : u-boot.img [Read Ok] : trust.img [Read Ok] : misc.img [Read Ok] : resource.raw [Read Ok] : kernel.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : backup.img [Read Ok] : security.bin [Read Ok] : system.img [Read Ok] : vendor.bin [Read Ok] : oem.img Read finished! Configuration : / 2C644432A5 [ NAND ] Firmware Size : 1552 MiB Done! Elapsed: 00:02:21 |
12-29-2019, 04:53 | #61806 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | Infinity RKT 2.01 Read Firmware Ok 8.1.0! Bleck Clever7 Tablet Infinity-Box RockChip Service Tool [RKT] v2.01 Operation : Read Firmware [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C644432A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020C000000 ( 8,19 GiB ) Flash Info : 8388608/16384/32/60/1 Connect Ok! Brand : BLECK ProdName : BL-919845 ProdModel : BL-919845 Device : BL-919845 AndroidVer: 8.1.0 Manufact. : BLECK SysPatch : OPM6.171019.030.B1 DevInfo : BLECK__BLECK__ANDR_v8.1.0__BL-919845__BL-919845__BL-919845 Reading Flash Content ... [Read Ok] : param.cfg [Read Ok] : u-boot.img [Read Ok] : trust.img [Read Ok] : misc.img [Read Ok] : resource.raw [Read Ok] : kernel.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : backup.img [Read Ok] : security.bin [Read Ok] : system.img [Read Ok] : vendor.bin [Read Ok] : oem.img Read finished! Configuration : / 2C644432A5 [ NAND ] Firmware Size : 1552 MiB Done! Elapsed: 00:02:21 |
12-29-2019, 08:46 | #61807 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Dany Monstar 4G SPD77XX FRP Reset Done With King Infinity CM2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 29 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000310000000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
12-29-2019, 10:09 | #61808 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Lenovo A328 MT6572 Pattren Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A28656911F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A28656911F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395EFD66D26025EDDBDC7690ECC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
12-29-2019, 18:52 | #61809 (permalink) |
No Life Poster Join Date: Mar 2014 Location: India
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | Lenovo k33 flashing successfully done Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 015F9A8F ID_BLOCK_E : 00007A2A ID_BLOCK_L : 411514E6EA94D730457E6E820998A3E2 ID_BLOCK_L : C3B68463680F34BD7CE045931F79FF49 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Brand : Lenovo ProdName : karate ProdModel : Lenovo K33 Device : K33 AndroidVer: 7.0 Manufact. : LENOVO SysPatch : NRD90N DevComTime: 11/14/2017 1:55:07 AM QLMxCPU : MSM8937 QLMxPRJ : K33_USR_S231_1711140937_Q00440_ROW USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:17 Reconnect Power/Cable! Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 015F9A8F ID_BLOCK_E : 00007A2A ID_BLOCK_L : 411514E6EA94D730457E6E820998A3E2 ID_BLOCK_L : C3B68463680F34BD7CE045931F79FF49 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Flash Chain : 195 Flashing now Flashing : NON-HLOS.bin Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : ddr.bin Flashing : boot.img Flashing : recovery.img Flashing : splash.img Flashing : mdtp.img Flashing : cache_1.img Flashing : cache_2.img Flashing : cache_3.img Flashing : system_1.img Flashing : system_2.img Flashing : system_3.img Flashing : system_4.img Flashing : system_5.img Flashing : system_6.img Flashing : system_7.img Flashing : system_8.img Flashing : system_9.img Flashing : system_10.img Flashing : system_11.img Flashing : system_12.img Flashing : system_13.img Flashing : system_14.img Flashing : system_15.img Flashing : system_16.img Flashing : system_17.img Flashing : system_18.img Flashing : system_19.img Flashing : system_20.img Flashing : system_21.img Flashing : system_22.img Flashing : system_23.img Flashing : system_24.img Flashing : system_25.img Flashing : system_26.img Flashing : system_27.img Flashing : system_28.img Flashing : system_29.img Flashing : system_30.img Flashing : system_31.img Flashing : system_32.img Flashing : system_33.img Flashing : system_34.img Flashing : system_35.img Flashing : system_36.img Flashing : system_37.img Flashing : system_38.img Flashing : system_39.img Flashing : system_40.img Flashing : system_41.img Flashing : system_42.img Flashing : system_43.img Flashing : system_44.img Flashing : system_45.img Flashing : system_46.img Flashing : preload_1.img Flashing : preload_2.img Flashing : preload_3.img Flashing : preload_4.img Flashing : preload_5.img Flashing : preload_6.img Flashing : preload_7.img Flashing : userdata_1.img Flashing : userdata_2.img Flashing : userdata_3.img Flashing : userdata_4.img Flashing : userdata_5.img Flashing : userdata_6.img Flashing : userdata_7.img Flashing : userdata_8.img Flashing : userdata_9.img Flashing : userdata_10.img Flashing : userdata_11.img Flashing : userdata_12.img Flashing : userdata_13.img Flashing : userdata_14.img Flashing : userdata_15.img Flashing : userdata_16.img Flashing : userdata_17.img Flashing : userdata_18.img Flashing : userdata_19.img Flashing : userdata_20.img Flashing : userdata_21.img Flashing : userdata_22.img Flashing : userdata_23.img Flashing : userdata_24.img Flashing : userdata_25.img Flashing : userdata_26.img Flashing : userdata_27.img Flashing : userdata_28.img Flashing : userdata_29.img Flashing : userdata_30.img Flashing : userdata_31.img Flashing : userdata_32.img Flashing : userdata_33.img Flashing : userdata_34.img Flashing : userdata_35.img Flashing : userdata_36.img Flashing : userdata_37.img Flashing : userdata_38.img Flashing : userdata_39.img Flashing : userdata_40.img Flashing : userdata_41.img Flashing : userdata_42.img Flashing : userdata_43.img Flashing : userdata_44.img Flashing : userdata_45.img Flashing : userdata_46.img Flashing : userdata_47.img Flashing : userdata_48.img Flashing : userdata_49.img Flashing : userdata_50.img Flashing : userdata_51.img Flashing : userdata_52.img Flashing : userdata_53.img Flashing : userdata_54.img Flashing : userdata_55.img Flashing : userdata_56.img Flashing : userdata_57.img Flashing : userdata_58.img Flashing : userdata_59.img Flashing : userdata_60.img Flashing : userdata_61.img Flashing : userdata_62.img Flashing : userdata_63.img Flashing : userdata_64.img Flashing : userdata_65.img Flashing : userdata_66.img Flashing : userdata_67.img Flashing : userdata_68.img Flashing : userdata_69.img Flashing : userdata_70.img Flashing : userdata_71.img Flashing : userdata_72.img Flashing : userdata_73.img Flashing : userdata_74.img Flashing : userdata_75.img Flashing : userdata_76.img Flashing : userdata_77.img Flashing : userdata_78.img Flashing : userdata_79.img Flashing : userdata_80.img Flashing : userdata_81.img Flashing : userdata_82.img Flashing : userdata_83.img Flashing : userdata_84.img Flashing : userdata_85.img Flashing : userdata_86.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:03:18 Reconnect Power/Cable |
The Following 4 Users Say Thank You to jjamshad5 For This Useful Post: |
12-29-2019, 19:33 | #61810 (permalink) |
Member: 834813 Status: Offline Thanks Meter: 125 | it1409/SP413 (frp) Code: Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 86 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001537F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 86 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001357F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
The Following User Says Thank You to laptop.dz For This Useful Post: |
12-30-2019, 05:26 | #61811 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | vivo y53 firmware read write done Code: Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 581F6203 ID_BLOCK_L : 2CEBD033BE21FEAC68C0A84AA695297A ID_BLOCK_L : F8BD37CA3AC8EF5839B64A1BB4586D2F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Brand : vivo ProdName : PD1628F_EX ProdModel : vivo PD1628F_EX Device : msm8937_32 AndroidVer: 6.0.1 Manufact. : vivo QLMxCPU : MSM8937 DevInfo : MSM8937__vivo__vivo__ANDR_v6.0.1__vivo_PD1628F_EX__msm8937_32__PD1628F_EX Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : devcfg.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : oem.img [Read Ok] : mdtp.img [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : keymaster.mbn [Read Ok] : bootbak.img [Read Ok] : apps.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8917 / eMMC Firmware Size : 3726 MiB Done! Elapsed: 00:04:59 Code: Operation : Flash [ v1.16 ] ForceFlashing : Enabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 581F6203 ID_BLOCK_L : 2CEBD033BE21FEAC68C0A84AA695297A ID_BLOCK_L : F8BD37CA3AC8EF5839B64A1BB4586D2F Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Flash Chain : 53 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : fs_gc.img Flashing : sec.dat Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : oem.img Flashing : mdtp.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : bootbak.img Flashing : apps.img Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:06:01 Reconnect Power/Cable! |
The Following User Says Thank You to kothamamun For This Useful Post: |
12-30-2019, 06:24 | #61812 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Itel it5231 password remove done Code: Operation : Format FileSystem [ v1.05 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q64 : 0x00800000 [ 8MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00800000_FMT_BACK_0F7C9A1E2B82_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
12-30-2019, 08:16 | #61813 (permalink) |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Walton EF6+ CM2SPD/UniSoc v2.03 FRP & Patter Remove done CustomBoot Uploaded Done Walton EF6+ CM2SPD/UniSoc v2.03 FRP & Patter Remove done CustomBoot Uploaded Done SPD Custom Boot Upload done Infinity Server |
The Following 2 Users Say Thank You to >>Gsmmilon>> For This Useful Post: |
12-30-2019, 08:47 | #61814 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Itel L5503 Frp remoe done Code: Operation : Format FS / Reset Settings [ v2.03 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:31 |
12-30-2019, 09:32 | #61815 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Itel L5503 identyfiy and read firmware done but take long time Code: Operation : Identify [ v2.03 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : L5503-F6301-9.0-OP-V052-20190820 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-07-01 Build Time : 1566299509 Product Model : itel L5503 Product Brand : Itel Product Name : F6301 Product Device : itel-L5503 Product Manfct : itel Product Info : L5503 Product Board : L5503 Board Platform : sp9863a Display ID : L5503-F6301-9.0-OP-V052-20190820 Update DataBase ... Platform Version: MOCORTM_18B_ITEL_W19.28.5_P2_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_ITEL_W19.28.5_P2 HW Version: sc9863A_modem CMP_Time : 07-24-2019 13:52:04 MODEM TAG : MOCORTM_18B_ITEL_W19.28.5_P2_Debug_FM_BASE_18B_ITEL_W19.28.5_P2_sc9863A_modem_sharkl3_pub UserData : STATE : PLAIN Done! Elapsed: 00:02:22 Code: Operation : Read FW [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : L5503-F6301-9.0-OP-V052-20190820 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-07-01 Build Time : 1566299509 Product Model : itel L5503 Product Brand : Itel Product Name : F6301 Product Device : itel-L5503 Product Manfct : itel Product Info : L5503 Product Board : L5503 Board Platform : sp9863a Display ID : L5503-F6301-9.0-OP-V052-20190820 VlnrLevel : 0x02 SP9863A__itel__itel_L5503__9__L5503-F6301-9.0-OP-V052-20190820__PPR1.180610.011__L5503 Read : u-boot.bin Read : sml.bin Read : tos.bin Read : vbmeta.img Read : dtb.img Read : dtbo.img Read : ldsp_l.bin Read : gdsp_l.bin Read : modem_l.bin Read : nvitem_l.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : pm_sys.bin Read : boot.img Read : recovery.img Make : persist.img Read : boot_logo.bmp Read : fastboot_logo.bmp |
The Following 2 Users Say Thank You to kothamamun For This Useful Post: |
