02-24-2020, 06:03 | #62581 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000117FF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:22 |
02-24-2020, 06:04 | #62582 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile i6 metal one flash done Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x19 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731C_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_480x854.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x854.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Erase Block : PERSIST Erase block ... Block erase Ok! Write CodeData : sysinfo.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:04:25 Reconnect Power/Cable! |
02-24-2020, 06:04 | #62583 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001276F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! |
02-24-2020, 06:05 | #62584 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:22 |
02-24-2020, 06:20 | #62585 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | Qmobile L12 Pro Spd 6531e Flash File Firmware Cm2Scr Tool Readed Qmobile L12 Pro Spd 6531e Flash File Firmware Cm2Scr Tool Readed |
The Following User Says Thank You to zoiya For This Useful Post: |
02-24-2020, 06:22 | #62586 (permalink) |
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | qmobile 3310 mini spd 6531e flash file via cm2scr tool qmobile 3310 mini spd 6531e flash file via cm2scr tool |
02-24-2020, 06:50 | #62587 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Tecno kc2 frp remove done just one click Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM87) MODE : PRELOADER PORT PORT : 87 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D4201A550E41DB649 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 52E09E7C28DB2FD7C9B68E435447C9C4 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:30 |
02-24-2020, 06:51 | #62588 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | Great Cm2 dead qmobile i8i 2019 Done Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! UBOOT : u-boot.bin ERASE : UBOOT_LOG CODE : boot_logo.bmp ERASE : FLASH_W CODE : modem_w.bin CODE : deltanv_w.bin CODE : gdsp_w.bin CODE : pm_sys.bin CODE : boot.img FSIMG : system.img FSIMG : cache.img FSIMG : vendor.img CODE : vbmeta.img CODE : vbmeta.img FSIMG : userdata.img UBOOT : u-boot-spl.bin Failed to update block! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2019 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-05 Build Time : 1550555934 Product Model : QMobile i8i 2019 Product Info : i8i 2019 Product Brand : QMobile Product Name : i8i_2019 Product Device : i8i_2019 Product Model : i8i 2019 Product Model : I8I2019 Product Manfct : QMobile Product Board : i8i-2019 Board Platform : sp7731e Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : recovery.img ERASE : MISC UBOOT : u-boot.bin ERASE : UBOOT_LOG CODE : boot_logo.bmp CODE : fastboot_logo.bmp ERASE : FLASH_W FSIMG : persist.img CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : modem_wcn.img CODE : modem_w.bin CODE : deltanv_w.bin CODE : gdsp_w.bin CODE : pm_sys.bin CODE : boot.img FSIMG : system.img FSIMG : cache.img FSIMG : vendor.img CODE : vbmeta.img CODE : vbmeta.img FSIMG : userdata.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:05:48 [IMG][/IMG] [IMG][/IMG] |
The Following User Says Thank You to amjadnona For This Useful Post: |
02-24-2020, 07:17 | #62589 (permalink) |
Freak Poster Join Date: Dec 2015
Member: 2498305 Status: Offline Thanks Meter: 37 | Vivo Y91c Frp and Passcode successful done Operation : Identify [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM53) MODE : PRELOADER PORT PORT : 53 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Vivo : Y83 | Manual : Disabled BROM : Change Configuration settings for target AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_VIP.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 150100514436334D42017EF4686726AB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B404858641A72CF4C4C52B578BD7F4F7 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-12-05 Build Time : 1577713024 Product Model : vivo 1820 Product Brand : vivo Product Name : PD1818HF_EX Product Device : PD1818HF_EX Product Manfct : vivo Product Info : k62v1_64_bsp Product Board : k62v1_64_bsp Board Platform : mt6765 USERDATA : ENCRYPTED STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:26 |
The Following 2 Users Say Thank You to Future42 For This Useful Post: |
02-24-2020, 07:27 | #62590 (permalink) |
No Life Poster Join Date: Mar 2014 Location: India
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | REDMI 5A flashing successfully done Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 9BFC13E6 ID_BLOCK_L : 7821A2802C3BEDB0C19B2560F46696B9 ID_BLOCK_L : C4304AE92C0F07D7801BB8ABD442EED3 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Brand : Xiaomi ProdName : riva ProdModel : Redmi 5A Device : riva AndroidVer: 7.1.2 Manufact. : Xiaomi SysPatch : N2G47H DevComTime: 8/10/2018 4:56:57 AM QLMxCPU : MSM8937 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 9BFC13E6 ID_BLOCK_L : 7821A2802C3BEDB0C19B2560F46696B9 ID_BLOCK_L : C4304AE92C0F07D7801BB8ABD442EED3 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Flash Chain : 52 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : splash.img Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : lksecapp.mbn Flashing : lksecapp.mbn Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : cust.img Flashing : userdata.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:05:19 Reconnect Power/Cable! Last edited by jjamshad5; 02-24-2020 at 07:36. |
The Following User Says Thank You to jjamshad5 For This Useful Post: |
02-24-2020, 08:51 | #62592 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | itel W5005 frp Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : W5005-F3110-9.0-OP-V021-20191118 Ver. Incmt : OP-V021-20191118 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-11-05 Build Time : 1574053682 Product Model : itel W5005 Product Brand : Itel Product Name : F3110 Product Device : itel-W5005 Product Manfct : itel Product Info : W5005 Product Board : W5005 Board Platform : sp7731e Display ID : W5005-F3110-9.0-OP-V021-20191118 Platform Version: MOCORTM_17C_ITEL_RLS2_W19.28.5_P4_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_ITEL_RLS2_W19.28.5_P4 HW Version: sc7731e_modem CMP_Time : 10-15-2019 12:10:52 MODEM TAG : MOCORTM_17C_ITEL_RLS2_W19.28.5_P4_Debug_FM_BASE_17 C_ITEL_RLS2_W19.28.5_P4_sc7731e_modem_pike2_pub UserData : STATE : PLAIN Done! Elapsed: 00:01:30 Operation : Format FS / Reset Settings [ v2.04 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:35 |
02-24-2020, 11:54 | #62593 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix X573 QLM FRP Reset Done With King Infiinity CM2 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 77527E0F ID_BLOCK_L : 946C06F05FCBF0F3AC81735C9BE66E5E ID_BLOCK_L : 0944CA6556F961E2E7D6BB7072BDAB90 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
02-24-2020, 13:36 | #62594 (permalink) | ||
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | Y6 Pro 2019(MRD-L22,MRD-LX2 FRP Remove Done by Great CM2 Quote:
The Following 5 Users Say Thank You to tapas770 For This Useful Post: |
02-24-2020, 15:08 | #62595 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | World first lava V6+ prime imei repair with Great one World first lava V6+ prime imei repair with Great one CM2 https://www.youtube.com/watch?v=jrOB...ture=********* |
The Following 2 Users Say Thank You to dany_boy For This Useful Post: |
