02-21-2024, 14:30 | #75871 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Card found : 73CA70CC , v0158 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : itel-s663l.460f890f.04b4b7c0 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
02-21-2024, 14:37 | #75872 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Tecno bd4 reset frp done by cm2 Card found : 73CA70CC , v0158 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : BD4_Pop-5-LTE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
02-21-2024, 14:43 | #75873 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile l3 selfie v2 reset password done by cm2 Card found : S/N : 73CA70CC , v0158 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 252EBCFDBA21C4D9C8C457910F29482D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61M_11C_PCB01_gsm_MT6261_S00.QMOBILE_L3_SELFIE _V2_V10_28_12_18.bin FileVersion : QMobile_L3_Selfie_V2_V10_28_12_18 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 252EBCFDBA21C4D9C8C457910F29482D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
02-22-2024, 09:04 | #75874 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Sparx Neo 7 Plus Frp Done By cm2 Card found : 73CA70CC , v0158 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : C31-RMX3501EU-Nico-Natv Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : UserData : STATE : ENCRYPTED - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:31 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : C31-RMX3501EU-Nico-Natv Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:34 |
02-22-2024, 16:35 | #75875 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | S/N: 0073CA70CC v0158 Chinese Miracle II - MT2 Service Tool v2.51 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 9 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 81 DA profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v915508 Ok Operation: Reset Settings/Format FS [ v2.51 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [+] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM Port (COM4) MODE [0]: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: EABA28B37BBA41403BA2103AFEF5D3C3EF22A06B9CFB835573 A89DF0BFD7B7B7 AGENT: AUTO: 0_base: base_v2316 [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for suitable BootChain in DA... Found: MT6739; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x40000000 [ 1024.00 Mb ] EMMC CID: 90014A483847346132A5648A30746629 EMMC crc Ok Ven: Hynix OEM: 330 ID: 483847346132 [H8G4a2] PRV: 0xA5 SNN: 1686777972 [0x648A3074] MM/YY: 6/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 13EABDB37045B11266F2318F96EB8AD0 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 46 Get slot info... a Select info source... boot_a [1800000] Ok SW: wowi/SQ788Extreme/SQ788Extreme:11/RP1A.200720.011/mp1V83031:user/release-keys Product Brand: Digit4G_E4_Pro Product Device: l280_mipi_qvga Product Model: Digit4G_E4_Pro Product Name: full_l280_mipi_qvga Patch Level: RP1A.200720.011 Display ID: DigitOS11_E4Pro_OPN_V1.1.4_202309270914 SW Version: mp1k61v164bspP1 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-09-01 Build Time: 6/13/2023 6:23:33 AM CPU: armeabi-v7a,armeabi Product Info: l280_mipi_qvga SW: full_l280_mipi_qvga-user 11 RP1A.200720.011 mp1k61v164bspP1 test-keys Product Board: l280_mipi_qvga Board Platform: mt6739 Product Manfct: alps Strategy: [none|generic] SmartInfo: Android Ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6739__13EABDB37045B 11266F2318F96EB8AD0\ Items to check: 20 Read [15] NVRAM Read [7] NVDATA Read [14] PROINFO Read [6] NVCFG Read [10] PROTECT1 Read [1] PGPT Read [0] PRELOADER Done 7 files Compress: C:\InfinityBox\CM2MT2\backup\MT6739__13EABDB37045B 11266F2318F96EB8AD0\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6739__13EABDB37045B 11266F2318F96EB8AD0.7z Verified Stage: Android OS [2] WIPE... Skip [3] PROTECTION... Ok [5] USERDATA... Create image... Ok Ok [8] USERDATA... Ok [9] USERDATA... Ok Stage: FRP... FRP is Off Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:37 Reconnect Power/Cable now |
02-22-2024, 16:44 | #75876 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | S/N: 0073CA70CC v0158 Chinese Miracle II - MT2 Service Tool v2.51 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 10 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 81 DA profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v915508 Ok DA selected: Vivo | 2023-08 | MTK_AllInOne_DA_v3.bin Operation: Reset Settings/Format FS [ v2.51 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [+] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM Port (COM4) MODE [0]: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 48F2056A7B8D786C749152157FF9D6BF3B9B02CA1BE37C8773 FCA26F47C18FC6 AGENT: AUTO: Vivo: 2023-08 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.bin Looking for suitable BootChain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100444836444142020D8ACA941899 EMMC crc Ok Ven: Samsung OEM: 256 ID: 444836444142 [DH6DAB] PRV: 0x02 SNN: 227199636 [0x0D8ACA94] MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: EC2746D89653DBBB488A8392A2EE7AA1 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Select info source... recovery [6000000] Ok SW: vivo/2026/2026:11/RP1A.200720.012/compiler0504145542:user/release-keys Product Brand: vivo Product Device: 2026 Product Model: V2026 Product Name: 2026 Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012 release-keys Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20230504.145730 release-keys SW Version: eng.compil.20230504.145730 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-05-01 Build Time: 5/4/2023 6:55:42 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Strategy: [vivo] SmartInfo: Android Ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__33D3317AB5F32 EB1D7E1678B2B8D8614 Stage: Android OS [2] WIPE... Skip [3] PROTECTION... Ok [5] USERDATA... Create image... Ok Ok [6] CACHE... Create image... Ok Ok [8] USERDATA... Ok [9] USERDATA... Ok Stage: FRP... FRP is Off Stage: Smart... Ok Reset port... Trying to reboot... Done: 00:00:43 Reconnect Power/Cable now |
02-22-2024, 19:16 | #75877 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Card found : 73CA70CC , v0158 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
02-22-2024, 19:40 | #75878 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile X30 Flash Code: Brand : TINNO ProdName : QMobile X30 ProdModel : QMobile X30 Device : QMobile X30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111015285099C228F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111015285099C228F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C256859E12B2FB329BDD3CA838F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : Unknown (not supported or without battery) BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:00 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:45 Reconnect Power/Cable! |
02-23-2024, 08:19 | #75879 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 4g ta 1389 read flash file done by cm2 Card found : S/N : 73CA70CC , v0158 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : FAD715169F15B75C43590CDF9D62E95E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : J115_5_BOE_R1_7003_PCB01_gsm_MT6260_S00.J115_5_GCZ L7003_BOE_RED1_V1.bin FileVersion : J115_5_GCZL7003_BOE_Red1_V1 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : FAD715169F15B75C43590CDF9D62E95E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : J115_5_BOE_R1_7003_PCB01_gsm_MT6260_S00.J115_5_GCZ L7003_BOE_RED1_V1.bin FileVersion : J115_5_GCZL7003_BOE_Red1_V1 Saved to : C:\InfinityBox\CM2MTK\Read_out\J115_5_BOE_R1_7003_ PCB01_gsm_MT6260_S00.J115_5_GCZL7003_BOE_RED1_V1.b in Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
02-23-2024, 14:24 | #75880 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i6i reset frp done by cm2 Card found : 73CA70CC , v0158 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : QMobile : i6i-2020 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
02-23-2024, 14:43 | #75881 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | clone nokia spd phone security code reading done Card found : 41DEDF35 , v0159 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Read UserCode [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! UserCode : 332211 Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
02-24-2024, 13:08 | #75882 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Redmi 11s FRP reset Code: Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM39) MODE [0]: BOOTROM; PORT: 39 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6781 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x1066 CODE: Lagrange TYPE: NEXTGEN [LUCI] MEID: C329AE866C2E9F5A45C71D4309933FFC BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: D151DCF0543FF4DC641ECDA98FFC7B6C23A13D6022C50A166AA035E02854D929 SLA: Local Auth [Forced mode] Start Auth... port open Protocol|Filter fault - Check USB drivers - Reinstall libusb https://infinity-box.com/?r=100232 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM39) MODE [0]: BOOTROM; PORT: 39 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6781 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x1066 CODE: Lagrange TYPE: NEXTGEN [LUCI] MEID: C329AE866C2E9F5A45C71D4309933FFC BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: D151DCF0543FF4DC641ECDA98FFC7B6C23A13D6022C50A166AA035E02854D929 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: C329AE866C2E9F5A45C71D4309933FFC AGENT: AUTO: Xiaomi: Redmi-Note-11S [d800c7a9] C:\InfinityBox\CM2MT2\boot\Xiaomi\Redmi-Note-11S\MTK_AllInOne_DA_2021-11-03_190409.bin [7fe3d760] C:\InfinityBox\CM2MT2\boot\Xiaomi\Redmi-Note-11S\preloader_fleur_b.bin Looking for suitable BootChain in DA... Found: MT6781; DA: MTK_DOWNLOAD_AGENT ID6 vendor: 2 ID6 Memory: H9HQ15AECMBDAR [ 6.00 Gb ] KM8F9001JM-B813 [ 8.00 Gb ] MT128GAXAU2U227X [ 6.00 Gb ] H9HQ54AECMMDAR [ 6.00 Gb ] KM8L9001JM-B624 [ 8.00 Gb ] H9QT1G6DN6X132 [ 8.00 Gb ] H9QT0GECN6X145 [ 6.00 Gb ] BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Agent Started LC: Agent online Agent ENV tuned succesfully Version: 1.1 DevRND: 0C7B382ADACB9D4E6F7BCBC476B4FFB6 Battery: 3756 mV RAM Size: 0x0000000000 [ 0 B ] Storage: UFS ID: BLK: 0x00001000 LUN0: 0x0000400000 [ 4.00 Mb ] LUN1: 0x0000400000 [ 4.00 Mb ] LUN2: 0x1DCB000000 [ 119.17 Gb ] LUN3: 0x0000000000 [ 0 B ] LC: Hardware not initialized yet. Process HWinit... LC: Hardware init Ok LC: Set HostCapps... Fail LC: Set HostInfo... Ok Version: 1.1 DevRND: 0C7B382ADACB9D4E6F7BCBC476B4FFB6 Battery: 3757 mV RAM Size: 0x0180000000 [ 6.00 Gb ] Storage: UFS ID: BLK: 0x00001000 LUN0: 0x0000400000 [ 4.00 Mb ] LUN1: 0x0000400000 [ 4.00 Mb ] LUN2: 0x1DCB000000 [ 119.17 Gb ] LUN3: 0x0000000000 [ 0 B ] LC: Boot to 2nd Agent.. Ok LC2: Process HW init... Ok LC2: SLA request by agent, vendor: 2 SLA ID: D151DCF0543FF4DC641ECDA98FFC7B6C23A13D6022C50A166AA035E02854D929 Request... Finished Received: 0x200 LC2: SLA: Challenge Pass CHIP: MT6781 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x1066 CODE: Lagrange TYPE: NEXTGEN [LUCI] MEID: D151DCF0543FF4DC641ECDA98FFC7B6C USB: HIGH-SPEED Boot done NEXTGEN [LUCI] Analyze PMT... PMT: PGPT [0x64] Records: 60 Get slot info... a Select info source... boot_a [4000000] Ok Product Brand: Redmi Product Device: fleur Product Model: fleur Product Name: fleur SW: Redmi/fleur/fleur:12/SP1A.210812.016/V14.0.5.0****EEUXM:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016 SW Version: V14.0.5.0****EEUXM Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-10-01 Build Time: 26.09.2023 12:41:45 Product Info: fleur SW: fleur-user 12 SP1A.210812.016 V14.0.5.0****EEUXM release-keys Product Manfct: Xiaomi Product Board: fleur Board Platform: mt6781 Strategy: [xiaomi] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6781__D151DCF0543FF4DC641ECDA98FFC7B6C Stage: Android OS [1] ... Create image... Ok Ok [4] USERDATA... Ok [5] USERDATA... Ok Stage: FRP... [1] PROTECTION... Done Stage: Smart... Probe Account... status: off Reset Account... Done Trying to reboot... Done: 00:01:32 Reconnect Power/Cable now |
02-24-2024, 18:07 | #75883 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Infinix X6825 Repair Security Done Code: Operation: Identify Device [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [+] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D6010335384134343111842041E0A949 VEN: Foresee OEM: 259 ID: 353841343431 [58A441] PRV: 0x11 SNN: 2216706528 [0x842041E0] MM/YY: 10/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE67800000 [ 57.62 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 7E3ECC4E6753A50E268CAB0613DC70DC USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 50 Get slot info... Select info source... Ok Product Brand: Infinix Product Device: Infinix-X6825 Product Model: Infinix X6825 Product Name: X6825-GL SW: Infinix/X6825-GL/Infinix-X6825:12/SP1A.210812.016/220609V1:user/release-keys Patch Level: SP1A.210812.016 Display ID: X6825-XE685SABCDEF-S-GL-220609V1 SW Version: 220609V1 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-05-05 Build Time: 16/05/2023 04:59:28 Product Info: x6825_xe685s SW: vnd_x6825_xe685s-user 12 SP1A.210812.016 327867 release-keys Product Manfct: INFINIX Product Board: Infinix Board Platform: mt6765 Strategy: [none|generic] Firmware ID: MT6765_INFINIX_Infinix_X6825_OSv12_X6825-XE685SABCDEF-S-GL-220609V1_SP1A.210812.016_x6825_xe685s Verify firmware [MT6765_INFINIX_Infinix_X6825_OSv12_X6825-XE685SABCDEF-S-GL-220609V1_SP1A.210812.016_x6825_xe685s]... Exist Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xA5 Size: 0x08C299 State: Ok WiFi MAC: AA0036004400 BlTh MAC: 88B86F8AF022 IMEI[1]: 35xxxxxxxxxxxxxx IMEI[2]: 35xxxxxxxxxxxxxx Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__7E3ECC4E6753A50E268CAB0613DC70DC\ Items to check: 20 Read [16] NVRAM Read [8] NVDATA Read [3] PROINFO Read [7] NVCFG Read [11] PROTECT1 Read [1] PGPT Read [14] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__7E3ECC4E6753A50E268CAB0613DC70DC\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__7E3ECC4E6753A50E268CAB0613DC70DC.7z Verified STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6765 preloader_x6825_xe685s.bin with 3 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x6825_xe685s.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x6825_xe685s.bin [c38b0af8]... Exist Done: 00:01:30 Code: Operation: Repair Security [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [+] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D6010335384134343111842041E0A949 VEN: Foresee OEM: 259 ID: 353841343431 [58A441] PRV: 0x11 SNN: 2216706528 [0x842041E0] MM/YY: 10/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE67800000 [ 57.62 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 7E3ECC4E6753A50E268CAB0613DC70DC USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 50 Reading... NVRAM: Items: 0xA5 Size: 0x08C299 State: Ok WiFi MAC: AA0036004400 BlTh MAC: 88B86F8AF022 IMEI[1]: 35xxxxxxxxxxxxxx IMEI[2]: 35xxxxxxxxxxxxxx Ok IMEI[1]: 35xxxxxxxxxxxxxx IMEI[2]: 35xxxxxxxxxxxxxx Writing... Ok Update NVRAM... Ok Update dependencies... Ok Select info source... Ok Strategy: [none|generic] Done: 00:01:20 |
The Following User Says Thank You to tayobjoy1 For This Useful Post: |
02-24-2024, 18:08 | #75884 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo 1726 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM28) MODE [0]: BOOTROM; PORT: 28 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 77C3CEB26E6B40D474E750FCD0F08C2D BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 09E65AB4EBCB142FAFB576126F2B9CD878E7645EC15921AE09B732D014DDFB9B SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 77C3CEB26E6B40D474E750FCD0F08C2D AGENT: AUTO: 0_base: base_v2316 [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable BootChain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010052483634414205AA019A205573 crc Ok Ven: Samsung OEM: 256 ID: 524836344142 [RH64AB] PRV: 0x05 SNN: 2852231712 [0xAA019A20] MM/YY: 5/2018 EMI: FireFly preloader_k62v1_64_bsp.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100524436344D42 Samsung RD64MB RAM: 4.00 Gb 2. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444D42 Samsung DH6DMB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 7. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 8. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 9. eMMC DDR3 ID: 150100475036424D42 Samsung GP6BMB RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010052483634414205AA019A205573 crc Ok Ven: Samsung OEM: 256 ID: 524836344142 [RH64AB] PRV: 0x05 SNN: 2852231712 [0xAA019A20] MM/YY: 5/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 0C104019EEA042217B681C435AA5E4D2 MEID: 77C3CEB26E6B40D474E750FCD0F08C2D USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 43 Select info source... recovery [4000000] Ok Patch Level: O11019 Display ID: O11019 release-keys SW Version: 1562074165 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2019-06-05 Build Time: 02/07/2019 1:29:14 pm Product Model: vivo 1726 Product Brand: vivo Product Name: PD1803F_EX Product Device: PD1803F_EX CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k62v1_64_bsp SW: full_k62v1_64_bsp-user 8.1.0 O11019 1562074165 release-keys Product Model: PD1803F_EX Product Board: k62v1_64_bsp Board Platform: mt6765 Strategy: [vivo] SmartInfo: Android Ver: 8 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Stage: Android OS [1] ... Create image... Ok Ok [2] ... Create image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Done Stage: Smart... Ok Reset port... Trying to reboot... Done: 00:00:37 Reconnect Power/Cable now |
02-24-2024, 18:16 | #75885 (permalink) |
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Spark 10 Pro KI7 Repair Security Done Code: Operation: Identify Device [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [+] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 63E577A9E53A66E97816BA4258CCA252 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: AE87AB8FEB75DFC8A1296F8D27C35FE0C3BA393D9666A160371150D0F1BD2DCF SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 63E577A9E53A66E97816BA4258CCA252 AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D62D004D4D4331323851197500525A9B VEN: Foresee OEM: 11520 ID: 4D4D43313238 [MMC128] PRV: 0x51 SNN: 427098194 [0x19750052] MM/YY: 5/2023 EMI: Init Ok EMI: FireFly preloader_ki7_v7510.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D62D004D4D4331323851197500525A9B VEN: Foresee OEM: 11520 ID: 4D4D43313238 [MMC128] PRV: 0x51 SNN: 427098194 [0x19750052] MM/YY: 5/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D20500000 [ 116.50 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 32F8793655C1C0FA289D2CCAABEC23E6 MEID: 63E577A9E53A66E97816BA4258CCA252 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 53 Get slot info... Select info source... Ok Product Brand: TECNO Product Device: TECNO-KI7 Product Model: TECNO KI7 Product Name: KI7-GL SW: TECNO/KI7-GL/TECNO-KI7:12/SP1A.210812.016/230711V2407:user/release-keys Patch Level: SP1A.210812.016 Display ID: KI7-V7510AACDEGHJKLMN-S-GL-230711V2407 SW Version: 230711V2407 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-07-05 Build Time: 11/07/2023 12:02:31 Product Info: ki7_v7510 SW: vnd_ki7_v7510-user 12 SP1A.210812.016 376366 release-keys Product Manfct: TECNO Product Board: TECNO-KI7 Board Platform: mt6768 Strategy: [none|generic] Firmware ID: MT6768_TECNO_TECNO_KI7_OSv12_KI7-V7510AACDEGHJKLMN-S-GL-230711V2407_SP1A.210812.016_ki7_v7510 Verify firmware [MT6768_TECNO_TECNO_KI7_OSv12_KI7-V7510AACDEGHJKLMN-S-GL-230711V2407_SP1A.210812.016_ki7_v7510]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xA3 Size: 0x08C64F State: Ok WiFi MAC: AA0036004400 BlTh MAC: 4CA3A728CB96 IMEI[1]: 35xxxxxxxxxxxxxx IMEI[2]: 35xxxxxxxxxxxxxx Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6768__63E577A9E53A66E97816BA4258CCA252\ Items to check: 20 Read [37] NVRAM Read [19] NVDATA Read [3] PROINFO Read [18] NVCFG Read [21] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6768__63E577A9E53A66E97816BA4258CCA252\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__63E577A9E53A66E97816BA4258CCA252.7z Verified STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6752 preloader_ki7_v7510.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_ki7_v7510.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_ki7_v7510.bin [40de5a80]... Exist Done: 00:01:51 Code: Operation: Repair Security [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [+] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 63E577A9E53A66E97816BA4258CCA252 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: AE87AB8FEB75DFC8A1296F8D27C35FE0C3BA393D9666A160371150D0F1BD2DCF SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 63E577A9E53A66E97816BA4258CCA252 AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D62D004D4D4331323851197500525A9B VEN: Foresee OEM: 11520 ID: 4D4D43313238 [MMC128] PRV: 0x51 SNN: 427098194 [0x19750052] MM/YY: 5/2023 EMI: Init Ok EMI: FireFly preloader_ki7_v7510.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D62D004D4D4331323851197500525A9B VEN: Foresee OEM: 11520 ID: 4D4D43313238 [MMC128] PRV: 0x51 SNN: 427098194 [0x19750052] MM/YY: 5/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x1D20500000 [ 116.50 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 32F8793655C1C0FA289D2CCAABEC23E6 MEID: 63E577A9E53A66E97816BA4258CCA252 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 53 Reading... NVRAM: Items: 0xA3 Size: 0x08C64F State: Ok WiFi MAC: AA0036004400 BlTh MAC: 4CA3A728CB96 IMEI[1]: 35xxxxxxxxxxxxxx IMEI[2]: 35xxxxxxxxxxxxxx Ok IMEI[1]: 351111111222220 IMEI[2]: 350000888886666 Writing... Ok Update NVRAM... Ok Update dependencies... Ok Select info source... Ok Strategy: [none|generic] Done: 00:01:36 |
