05-26-2011, 15:52 | #12151 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Connect phone on selected interface... UFS S/N 1***** boot - Ok Connect phone on selected interface... Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : 4BB8AA07_rm495__07.97.ppm_mena_a1 CNT : E24393CE_rm495__07.97.image_mena_a1_red Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 09D00108AF42005609C2DC60C0363180A57012C9 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing C5F02102_rm495__07.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:26 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing C5F02102_rm495__07.97.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1169 blocks TIME : Write time : 00:02:38 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1 Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:30 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1 Total writen 388 blocks TIME : Write time : 00:00:50 PrReq : NOR , 00 ConvertImage: Processing E24393CE_rm495__07.97.image_mena_a1_red ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing E24393CE_rm495__07.97.image_mena_a1_red Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:03:28 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing E24393CE_rm495__07.97.image_mena_a1_red Total writen 656 blocks TIME : Write time : 00:01:30 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 352003044095618 Product code: 0576443 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... SL3 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 09D00108AF42005609C2DC60C0363180A57012C9 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 352003044095618 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.22\Backup\Cert\352003044095618.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-26-2011, 16:44 | #12152 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 1***** boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 2230020C66D98C56CC855B2202C233F125F25DB6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 003F0001 , CMT , NOR CMT Flash ID : 003F0001 < SPANSION => 72NS512P FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! PrReq : NOR , 00 Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL3 phone detected Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Manual Files Set for Flashing : CNT : rm495__07.95.image_aa_red Check FlashFiles, Please, wait... -> SWversion check skipped : Custom mode selected Backup enabled, Will read Certificates now... SL3 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 2230020C66D98C56CC855B2202C233F125F25DB6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 003F0001 , CMT , NOR CMT Flash ID : 003F0001 < SPANSION => 72NS512P FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 359336039357277 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.22\Backup\Cert\359336039357277.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 2230020C66D98C56CC855B2202C233F125F25DB6 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 003F0001 , CMT , NOR CMT Flash ID : 003F0001 < SPANSION => 72NS512P FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.95.image_aa_red Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:03:56 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.95.image_aa_red Total writen 776 blocks TIME : Write time : 00:01:33 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.91 29-10-09 RM-495 (c) Nokia IMEI: 359336039357277 Product code: 0576443 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-26-2011, 17:03 | #12153 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | 1616 rh-125 flash ufs Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rh125_004.650 PPM : rh125_004.65ek CNT : rh1250_nai04.65ek Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 PBL : SE0_091125 F11 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 0020000000C08800 FLASH ID : ST, M58WR064 Boot Done! ===Flashing [MCU]=== File : rh125_004.650 Image : hw_f11_rh125_r04.650.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00204080 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00204080 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00000040 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 1FF2 ===Flashing [PPM]=== File : rh125_004.65ek Image : hw_f11_rh125_004.65ek.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x001B9EC0 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001B9EC0 Flashing , wait ... Region flash done Check : 78B3 ===Flashing [CNT]=== File : rh1250_nai04.65ek Image : hw_f11_rh1250_nai04.65ek.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x0004E080 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x0004E080 Flashing , wait ... Region flash done Check : 7E6B Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 04.65 24-04-10 RH-125 (c) Nokia IMEI : 353752040391723 PCode : 0587411 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-26-2011, 18:12 | #12154 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | N73 RM-133 flash USB Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : N73_3.0638.0.0.1_western_C00_PRD_cc.fpsx PPM : N73_rofx_3.0638.0.0.1_PRD.V05 CNT : N73_userarea_3.0638.0.0.1.U02 Flashing phone now... Check files done... -> Check SW version... FlashFile version : 3.0638.0.0.1 Phone version : V 3.0638.0.0.1 30-10-2006 RM-133 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created... Check communication with phone.... ADL Boot req Communication verify done... Preparing... Gathering phone info... RAP_BOOT: 0803000002010000 RAP_PUBLIC: 2460020A13A40154CFA4C59B127F168EA49A801A CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: 5E8D0D504A0902E261268C14FCD8A2C9093523BC APE_ROOTKEY: 49A97E826B93BA20B7ED0B082475C005 Check communication with phone... CMT Loader len: 43456, CHK: EB5A Sending CMT boot.... APE Loader len: 88064, CHK: 05B2 Sending APE boot.... Boot done TIME : Boot time : 00:00:01 Reboot.... Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL Server confirm flashmode! ADL : Auth skip ADL : ASIC CMT select Ok ADL : ASIC APE select Ok ===Flashing [MCU]=== Erase : Processing N73_3.0638.0.0.1_western_C00_PRD_cc.fpsx Found 4 areas to erase Erasing area 0x00080000 - 0x00730FDD, NOR, CMT Result: 0000 Erasing area 0x00000000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x001E0000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00880000 - 0x00FEFFFF, NOR, CMT Result: 0000 Found 4 areas to erase Erasing area 0x00000000 - 0x0007FFFF, NAND, APE Result: 0000 Erasing area 0x00080000 - 0x000FFFFF, NAND, APE Result: 0000 Erasing area 0x00100000 - 0x0025FFFF, NAND, APE Result: 0000 Erasing area 0x003C0000 - 0x04C1FFFF, NAND, APE Result: 0000 Partitioning : Ok [4] TIME : Erase time : 00:01:31 Write : Processing N73_3.0638.0.0.1_western_C00_PRD_cc.fpsx Total 1546 [327/1219/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [ADL] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] APE : Writing Hash CERT [KEYS] APE : Writing Hash CERT [X-LOADER] APE : Writing Hash CERT [PRIMAPP] APE : Writing Hash CERT [SOS+LOADER] APE : Writing Hash CERT [SOS*UPDAPP] APE : Writing Hash CERT [SOS+UZIP] APE : Writing Hash CERT [PAPUBKEYS] APE : Writing Hash CERT [PASUBTOC] APE : Writing Hash CERT [ADL] APE : Writing Hash CERT [SOS+XZIP] APE : Writing Hash CERT [SOS*CORE] TIME : Write time : 00:03:32 MCU Write done ===Flashing [PPM]=== Erase : Processing N73_rofx_3.0638.0.0.1_PRD.V05 Found 1 areas to erase Erasing area 0x03920000 - 0x04C1FFFF, NAND, APE Result: 0000 Partitioning : Ok [4] TIME : Erase time : 00:00:00 Write : Processing N73_rofx_3.0638.0.0.1_PRD.V05 Total 2175 [0/2175/0] blocks to write, writing... TIME : Write time : 00:01:20 PPM Write done ===Flashing [CNT]=== Erase : Processing N73_userarea_3.0638.0.0.1.U02 Found 1 areas to erase Erasing area 0x04C20000 - 0x07CFFFFF, NAND, APE Result: 0000 TIME : Erase time : 00:00:00 Write : Processing N73_userarea_3.0638.0.0.1.U02 Total 33 [0/33/0] blocks to write, writing... TIME : Write time : 00:00:05 CNT Write done ================= ADL : End flashing ADL : Close CMT session Ok ADL : Close APE session Ok Flashing done! Total flash time : 00:06:31 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N73 Software Info: V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI: 353640014262147 Ape Version: V 3.0638.0.0.1 30-10-2006 RM-133 Product code: 0543568 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:07:11 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following User Says Thank You to raychevski For This Useful Post: |
05-26-2011, 18:13 | #12155 (permalink) |
No Life Poster Join Date: May 2005 Location: SOUSSE / TUNISIA - 21959153 Age: 44
Member: 145225 Status: Offline Thanks Meter: 98 | Ot209x change imei done COM5 [VCP0] selected module v3.90 Device: Alcatel-209X Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 353923030000000 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6537:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 76S provider: 209X-2BRGTN1 customization: CM76CW80 customization: XM76CW80 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... ......... pass #1 firmware remap[01]: 08000000 pass #2 firmware remap[01]: 08000000 ..... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: imei flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CM76CW80 customization name adjusted customization: CM76CW80 customization name adjusted customization detected: CM76CW80 customization: CM76CW80 customization: XM76CW80 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-209X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20110524-133041.B0X.bin Finished, time used: 2 min 50 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to THE-MAXIMUS For This Useful Post: |
05-26-2011, 18:15 | #12156 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Change imei done ot209x COM5 [VCP0] selected module v3.90 Device: Alcatel-209X Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 353923030220095 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6E45:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 76S provider: 209X-2BRGTN1 customization: CM76CW80 customization: XM76CW80 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... ......... pass #1 firmware remap[01]: 08000000 pass #2 firmware remap[01]: 08000000 ..... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: imei flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CM76CW80 customization name adjusted customization: CM76CW80 customization name adjusted customization detected: CM76CW80 customization: CM76CW80 customization: XM76CW80 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-209X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20110524-164346.B0X.bin Finished, time used: 2 min 48 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-26-2011, 18:16 | #12157 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Change imei done ot209x COM5 [VCP0] selected module v3.90 Device: Alcatel-209X Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 353923030820035 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7F93:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 76S provider: 209X-2BRGTN1 customization: CM76CW80 customization: XM76CW80 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... ......... pass #1 firmware remap[01]: 08000000 pass #2 firmware remap[01]: 08000000 ..... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: imei flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CM76CW80 customization name adjusted customization: CM76CW80 customization name adjusted customization detected: CM76CW80 customization: CM76CW80 customization: XM76CW80 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-209X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20110524-163603.B0X.bin Finished, time used: 2 min 55 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-27-2011, 00:14 | #12158 (permalink) |
Freak Poster Join Date: May 2009 Location: *JAVA*
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | e63 Files Set for Flashing : MCU : rm437_500.21.009_prd.c00 PPM : rm437_500.21.009_prd.v26 CNT : rm437_500.21.009.27U APE : RM437_ENO_008.07.45_100.71.920.a01.fpsx CNT3 : sofie_erase_y_drive.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 14B00119C4918D5209B1556D9283C33353C1EBD6 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! TIME : Boot time : 00:00:30 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm437_500.21.009_prd.c00 Found 3 areas to erase Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00A00000 - 0x0759FFFF, NAND, CMT Result: 0000 Erasing area 0x0F1C0000 - 0x0F8BFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partition erase not allowed by loader Partition erase not allowed by loader Partitioning : Ok [7] TIME : Erase time : 00:00:00 Write : Processing rm437_500.21.009_prd.c00 Total 532 [532/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:26 MCU Write done ===Flashing [PPM]=== Erase : Processing rm437_500.21.009_prd.v26 Found 1 areas to erase Erasing area 0x05420000 - 0x0759FFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm437_500.21.009_prd.v26 Total 243 [243/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:41 PPM Write done ===Flashing [CNT]=== Erase : Processing rm437_500.21.009.27U Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm437_500.21.009.27U Total 171 [171/0/0] blocks to write, writing... TIME : Write time : 00:00:29 CNT Write done ===Flashing [APE]=== Erase : Processing RM437_ENO_008.07.45_100.71.920.a01.fpsx TIME : Erase time : 00:00:00 Write : Processing RM437_ENO_008.07.45_100.71.920.a01.fpsx Total 16 [16/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 APE Write done ===Flashing [CNT3]=== Erase : Processing sofie_erase_y_drive.fpsx Found 1 areas to erase Erasing area 0x0F020000 - 0x0F1BFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing sofie_erase_y_drive.fpsx No any data for write, skip write CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:02:41 |
05-27-2011, 00:15 | #12159 (permalink) |
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | 5610d rm242 blink done white best infinity Files Set for Flashing : MCU : rm242__10.00.mcusw PPM : rm242__10.00.ppm_x CNT : rm242__10.00_ISM_012.image_x Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006010C192101003000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0D60010F044E0254525F0AF71F54C4EB781C16CC CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! ===Flashing [MCU]=== Erase : Processing rm242__10.00.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:31 Write : Processing rm242__10.00.mcusw Total 1316 [1316/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:02:06 MCU Write done ===Flashing [PPM]=== Erase : Processing rm242__10.00.ppm_x Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:28 Write : Processing rm242__10.00.ppm_x Total 419 [419/0/0] blocks to write, writing... TIME : Write time : 00:00:41 PPM Write done ===Flashing [CNT]=== Erase : Processing rm242__10.00_ISM_012.image_x Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:24 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm242__10.00_ISM_012.image_x Total 1176 [1176/0/0] blocks to write, writing... TIME : Write time : 00:01:47 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:08:59 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5610d-1 Software Info: V 10.00 06-03-09 RM-242 (c) Nokia IMEI: 358652012836876 PPM version : V 10.00 06-03-09 RM-242 (c) Nokia X Product code: 0552250 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:09:50 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-27-2011, 00:16 | #12160 (permalink) |
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | n70 interface n-box Selected FlashSettings : Manual Files Set for Flashing : MCU : RM84_50737301.C0 PPM : RM84_50737301.V32 CNT : RM84_50737301.UDA Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 94E8E7E1E602CECE72C4E08CA26307C2366C1D37 APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 2030010B28E15851F968052FE072E1E2B47AF7DE CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC1 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00360098 , APE , APE Flash ID : 00360098 < UNKNOW [NOT IN BASE] ReqAlgo : APE , OMAP1610 GBBM-1.8.1 ALG FLCNT : 01010000020000000600000000000000000000 Sending ALGO.... Use : h3_sam_nand_gbbm.fg , Rev : 0.0 Ver : 1.33.0 APE Algo sent APE PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC0 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 351863018157400 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) APE : Read NPC certificate... Cert size : 0 byte(s) APE : Read CCC certificate... Cert size : 0 byte(s) APE : Read HWC certificate... Cert size : 0 byte(s) APE : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\351863018157400.rp l Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 94E8E7E1E602CECE72C4E08CA26307C2366C1D37 APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 2030010B28E15851F968052FE072E1E2B47AF7DE CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC1 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00360098 , APE , APE Flash ID : 00360098 < UNKNOW [NOT IN BASE] ReqAlgo : APE , OMAP1610 GBBM-1.8.1 ALG FLCNT : 01010000020000000600000000000000000000 Sending ALGO.... Use : h3_sam_nand_gbbm.fg , Rev : 0.0 Ver : 1.33.0 APE Algo sent APE PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC0 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_50737301.C0 Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0052B515 CMT , NOR , Area : 0x006A0000 - 0x006BFFFF CMT , NOR , Area : 0x006DF000 - 0x006EFFFF CMT , NOR , Area : 0x00700000 - 0x007EFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0000FFFF APE , NAND , Area : 0x00010000 - 0x0001FFFF APE , NAND , Area : 0x00020000 - 0x000203FF APE , NAND , Area : 0x00050000 - 0x03ECFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:47 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_50737301.C0 CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [SOS*CORE] Total writen 1122 blocks TIME : Write time : 00:03:19 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_50737301.V32 Found 2 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x01AE0000 - 0x02AFFFFF APE , NAND , Area : 0x02B00000 - 0x03ECFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_50737301.V32 Total writen 1312 blocks TIME : Write time : 00:01:45 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_50737301.UDA Erase : No any region, skip erase TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_50737301.UDA Total writen 479 blocks TIME : Write time : 00:00:40 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia N70 Software Info: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 351863018157400 Product code: 0534652 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... Error When resetting FullFactory ... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to sadermo For This Useful Post: |
05-27-2011, 04:58 | #12161 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | COM3 [VCP0] selected module v3.30 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... BB13_PCB01_GPRS_MT6225_S00.BB13_BLE_L7EN_205_08042 9_HRILI9320_SIV0_TO75_CTF_BT_FM__fullflash_2011052 6-172346.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7803:0000 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: BB13_BLE_L7EN_205_080429_HRILI9320_SIV0_TO75_CTF_B T_FM Version: BET25_06B_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 512 byte(s) read 160 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 50 sec Remove/Install battery now ! |
05-27-2011, 05:03 | #12162 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | COM3 [VCP0] selected module v3.30 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7803:0000 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: BB13_BLE_L7EN_205_080429_HRILI9320_SIV0_TO75_CTF_B T_FM Version: BET25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 129 items cleared: 129 of 129 building list... done items remains: 0 Finished, time used: 25 sec Remove/Install battery now ! |
05-27-2011, 05:05 | #12163 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | COM3 [VCP0] selected module v3.30 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9E7C:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: L132_JWT01_GL_JD_Y90_T01_V01 Version: LENTEK23D_GEMINI_ULC_07B_HW ==================== New firmware found (v.3.30, database date: 16.05.2011): L132_JWT01_GL_JD_Y90_T01_V01 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 5 11 done 67 byte(s) read imei: 35211904094111 connection Ok building list... done items to clear: 89 items cleared: 89 of 89 building list... done items remains: 0 Finished, time used: 28 sec Remove/Install battery now ! |
05-27-2011, 05:07 | #12164 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | COM3 [VCP0] selected module v3.30 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CF03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N66_F_ABROAD_5CDGB_S5_TM_V2.0.2 Version: GIONEE25_GEMINI_07B_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35169501989842 connection Ok building list... done items to clear: 142 warning: wrong packet cs warning: wrong packet cs items cleared: 142 of 142 building list... done items remains: 0 Finished, time used: 27 sec Remove/Install battery now ! |
05-27-2011, 05:38 | #12165 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | COM6 [VCP3] selected module v3.74 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E-PK-ZONG9-P107A1V1.0.0B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903273756 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 24 sec Remove/Install battery now ! |
