11-09-2015, 13:29 | #27826 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Kathmandu (Ason) Nepal
Member: 759507 Status: Offline Sonork: 100.1660105 Thanks Meter: 71 | Lenovo A850 read factory file sucess 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42014585C60E4107 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42014585C60E4107 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Lenovo ProdName : aux ProdModel : Lenovo A850 Device : A850 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : A850_S203_140208 [Read Ok] : preloader_aux.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / aux / EMMC FW Size : 682 MiB Scatter saved to : K:\LENOVO\A850\read file\MT6582__Lenovo__Lenovo A850__A850__4.2.2__A850_S203_140208\ All done! |
The Following User Says Thank You to Rohitdahal For This Useful Post: |
11-09-2015, 13:30 | #27827 (permalink) |
Member: 759507 Status: Offline Sonork: 100.1660105 Thanks Meter: 71 | Lenovo A850 Virus remove sucess 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42014585C60E4107 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42014585C60E4107 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 10 Removing infected files and scripts ... SmartAV Report : Removed 10 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:02:05 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42014585C60E4107 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42014585C60E4107 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 2 Removing infected files and scripts ... SmartAV Report : Removed 2 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Format FileSystem [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42014585C60E4107 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42014585C60E4107 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
11-09-2015, 13:39 | #27828 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Voice Xtreme V10 (NAND MT6572) Factory Firmware Backup:- Code: Operation : Read Flash [ v1.36 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 5 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009A , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... [Read Ok] : preloader_hct72_wet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache_empty.img [Read Ok] : usrdata_empty.img [ScatCFG] : MT6572 / V1.1.1 / hct72_wet_lca / NAND FW Size : 369 MiB Scatter saved to : F:\Firmware\Voice V10\MT6572__NAND__hct72_wet_lca Done! Elapsed: 00:04:10 Reconnect Power/Cable! |
11-09-2015, 13:40 | #27829 (permalink) |
11-09-2015, 13:43 | #27830 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1980599 Status: Offline Thanks Meter: 42 | Qmobile a290 gmail reset Code: Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A15DC5517B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A15DC5517B [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSA Ok! LSSW Ok! LSSS Ok! LSSK Ok! LSSG Ok! Security Settings : Clear Ok! [Info] : Android 5.x / MT67xx : If phone stuck on "Logo" 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
11-09-2015, 13:44 | #27831 (permalink) |
Member: 1980599 Status: Offline Thanks Meter: 42 | Qmobile a2 classic format Code: Operation : Format FileSystem [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008C , [SAMSUNG] K9K8G16U0K [NAND] : FLASH_DIE : 00EC 00BC 0000 006A 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
11-09-2015, 13:44 | #27832 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1893955 Status: Offline Thanks Meter: 65 | RIVO PHANTOM PZ15 Clean Done Code: Start at : [11/9/2015 / 5:35:00 PM] Operation : Remove Viruses [SmartAV] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004938584D4D42012475D434B11F DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMMX8 [eMMC] : FLASH_CID : 1501004938584D4D42012475D434B11F [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 48 Removing infected files and scripts ... SmartAV Report : Removed 48 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:38 Reconnect Power/Cable! Finish at : [11/9/2015 / 5:36:39 PM] Start at : [11/9/2015 / 5:36:42 PM] Operation : Format FileSystem [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004938584D4D42012475D434B11F DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMMX8 [eMMC] : FLASH_CID : 1501004938584D4D42012475D434B11F [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
11-09-2015, 13:46 | #27833 (permalink) |
Member: 1893955 Status: Offline Thanks Meter: 65 | RIVO PHANTOM PZ15 Read FF Code: Start at : [11/9/2015 / 5:28:34 PM] Operation : Read Flash [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004938584D4D42012475D434B11F DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMMX8 [eMMC] : FLASH_CID : 1501004938584D4D42012475D434B11F [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : PHANTOM ProdName : PZ15 ProdModel : PHANTOM PZ15 Device : PHANTOM_PZ15 AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : RIVO_PHANTOM_PZ15_S004_20150121 [Read Ok] : preloader_huaqin92_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6592 / V1.1.2 / huaqin92_cwet_kk / EMMC FW Size : 1451 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6592__PHANTOM__PHANTOM PZ15__PHANTOM_PZ15__4.4.2__RIVO_PHANTOM_PZ15_S004_20150121\ All done! Done! Elapsed: 00:06:18 Reconnect Power/Cable! |
11-09-2015, 13:49 | #27834 (permalink) |
Member: 1980599 Status: Offline Thanks Meter: 42 | QMOBILE A8i monky test, time service , system error remove SMART AV Code: Operation : Remove Viruses [SmartAV] [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201C82DC4FF4107 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201C82DC4FF4107 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 11 Removing infected files and scripts ... SmartAV Report : Removed 11 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:42 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201C82DC4FF4107 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201C82DC4FF4107 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
11-09-2015, 13:59 | #27835 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | qmobile x11 Code: Chinese Miracle II [MTK module] v 1.36 Operation : Remove Viruses [SmartAV] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483447316404050EA20BD1C10B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A483447316404050EA20BD1C10B [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 15 Removing infected files and scripts ... SmartAV Report : Removed 15 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:53 Reconnect Power/Cable! Operation : Format FileSystem [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483447316404050EA20BD1C10B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A483447316404050EA20BD1C10B [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Read NVRAM [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483447316404050EA20BD1C10B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A483447316404050EA20BD1C10B [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n Read Ok, MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n_eMMC.spnv saved Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-09-2015, 13:59 | #27836 (permalink) |
Freak Poster Join Date: Mar 2014 Location: GSM WORLD
Member: 2140248 Status: Offline Thanks Meter: 166 | Q Mobile S1 MT6582 Read Factory File Done. Code: Start at : [11/9/2015 / 5:01:12 PM] Operation : Read Flash [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48384731650507E244681F62FB DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : e1G8 [eMMC] : FLASH_CID : 90014A48384731650507E244681F62FB [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobile S1 ProdModel : QMobile S1 Device : QMobile AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_TINNO6582.WT.L_P7 [Read Ok] : preloader_s5222.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / s5222 / EMMC FW Size : 2034 MiB Scatter saved to : C:\Users\K-B\Desktop\MT6582__QMobile__QMobile S1__QMobile__5.0__ALPS.L0.MP2.V1_TINNO6582.WT.L_P7\ All done! Done! Elapsed: 00:08:12 Reconnect Power/Cable! Finish at : [11/9/2015 / 5:09:24 PM] |
11-09-2015, 14:01 | #27837 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lava iris 470 flash and fix dl image done Code: Scatter Load Ok , BaseBand : MT6572 , Project : lava72_sp03w , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.36 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201AB3B5299114F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201AB3B5299114F [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : lava72_sp03w , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3926 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000A1040000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lava72_sp03w.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:58 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:22 Reconnect Power/Cable! Operation : Fix DL Errors [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201AB3B5299114F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201AB3B5299114F [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-09-2015, 14:06 | #27838 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | gionee v4 av successfully Code: Operation : Remove Viruses [SmartAV] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001153030534ACB0E004D9F707215 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D000ECB1572709F [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 28 Removing infected files and scripts ... SmartAV Report : Removed 28 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:59 Reconnect Power/Cable! Operation : Format FileSystem [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001153030534ACB0E004D9F707215 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D000ECB1572709F [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
11-09-2015, 14:07 | #27839 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | karbon a19 flash done Code: Scatter Load Ok , BaseBand : MT6572 , Project : mbk72_wet_jb3 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.36 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A36B24518D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A36B24518D [eMMC] : FLASH_EXT : 00200000/00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : mbk72_wet_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3614 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x0000000097640000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_mbk72_wet_jb3.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:50 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:12 Reconnect Power/Cable! |
11-09-2015, 14:09 | #27840 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | karbon titanium s2 av done Code: Operation : Remove Viruses [SmartAV] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001153030534A45EC004DF5300700 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00EC45000730F5 [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 22 Removing infected files and scripts ... SmartAV Report : Removed 22 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:16 Reconnect Power/Cable! Operation : Format FileSystem [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001153030534A45EC004DF5300700 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00EC45000730F5 [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
