12-09-2015, 08:35 | #29191 (permalink) |
No Life Poster Join Date: Apr 2008 Age: 28
Member: 745672 Status: Offline Thanks Meter: 555 | Mt6572 Huwei Y520 /read/smartAv/format done ------------------------------------------------------- Card found : S/N : xxxx Chinese Miracle II [MTK module] v 1.38 Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051D7888A267101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7888A267101 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : HUAWEI ProdName : Y520-U22 ProdModel : HUAWEI Y520-U22 Device : HWY520-U AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 Saved to : C:\Users\Shibu's Computer\Desktop\MT6572__HUAWEI__HUAWEI_Y520-U22__Y520-U22__HWY520-U__ALPS.KK1.MP6.V1__Android_4.4.2__20140916_104620 .ispff Done! Elapsed: 00:15:07 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051D7888A267101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7888A267101 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 15 Removing infected files and scripts ... SmartAV Report : Removed 15 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:05 Reconnect Power/Cable! Operation : Format FileSystem [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051D7888A267101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7888A267101 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:46 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051D7888A267101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7888A267101 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 11 Removing infected files and scripts ... SmartAV Report : Removed 11 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:50 Reconnect Power/Cable! Operation : Format FileSystem [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051D7888A267101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7888A267101 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to Gsmbizz For This Useful Post: |
12-09-2015, 08:46 | #29192 (permalink) |
Member: 745672 Status: Offline Thanks Meter: 555 | mt-6583 xolo Q800x Virus remove/smartAv/format done Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D5657356FF3014211B03DD0 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D4201F36FD03DB011 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 69 Removing infected files and scripts ... SmartAV Report : Removed 69 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:41 Reconnect Power/Cable! Operation : Format FileSystem [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D5657356FF3014211B03DD0 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D4201F36FD03DB011 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Gsmbizz For This Useful Post: |
12-09-2015, 10:51 | #29194 (permalink) |
Crazy Poster Join Date: Jun 2010 Location: cold place
Member: 1316900 Status: Offline Sonork: none Thanks Meter: 30 | Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 70010056313030303806957508BE7241 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 70010056313030303806957508BE7241 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : lcsh82_cwet_kk ProdModel : lcsh82_cwet_kk Device : lcsh82_cwet_kk AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_lcsh82_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / lcsh82_cwet_kk / EMMC FW Size : 1036 MiB Scatter saved to : E:\DING DING IRON2\MT6582__alps__lcsh82_cwet_kk__lcsh82_cwet_kk __4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:05:18 Reconnect Power/Cable! |
The Following User Says Thank You to d'starter For This Useful Post: |
12-09-2015, 11:22 | #29195 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | zen q303hd remove virus and read ff done remove virus Code: Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051A04CB69541E7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051A04CB69541E7 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 16 Removing infected files and scripts ... SmartAV Report : Removed 16 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:02:14 Reconnect Power/Cable! Operation : Format FileSystem [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051A04CB69541E7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051A04CB69541E7 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051A04CB69541E7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051A04CB69541E7 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : FortuneShip ProdName : 303qHD ProdModel : 303qHD Device : 303qHD AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_hexing72_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / hexing72_cwet_kk / EMMC FW Size : 776 MiB Scatter saved to : D:\MT6572__FortuneShip__303qHD__303qHD__4.4.2__ALPS.KK1.MP7.V1\ All done! Done! Elapsed: 00:04:06 Reconnect Power/Cable! |
12-09-2015, 11:24 | #29196 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung w279 reset done COM168 [sscdserd0] selected module v2.05 Device: Samsung-SCH-F339 operation: user code Phone should be Switched ON ! connecting... Resseting user code... Done... Finished, time used: 3 sec |
The Following User Says Thank You to rehmani For This Useful Post: |
12-09-2015, 11:31 | #29197 (permalink) |
Member: 745672 Status: Offline Thanks Meter: 555 | sc7715 Intex Aqua V 3G hang on logo/format done :D/ Operation : Format File System [ v1.07 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
12-09-2015, 12:05 | #29198 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pako new road,Nepal
Member: 257603 Status: Offline Sonork: 100.1605284 Thanks Meter: 147 | Touchkon M800 reset privacy lock sucessfull unlock Card found : S/N : 857A5ED7 , v0129 Chinese Miracle II [MTK module] v 1.38 Operation : Reset Privacy Lock [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004938584D4D42017C4ED695512D DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMMX8 [eMMC] : FLASH_CID : 1501004938584D4D42017C4ED695512D [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! thanks the the team good software . @009779841232370 [email protected] |
The Following User Says Thank You to jawedjp For This Useful Post: |
12-09-2015, 12:15 | #29199 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Samsung I8552 google account removed by CM2 Code: Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 150100534A5330304D004BA44F2A6003 [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! ProdName : GT-I8552 ProdModel : GT-I8552 Device : GT-I8552 AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.MP.V1.16 MODEM : BaseBand : MT6575_S01_MAUI_11AMD_W12_22_SP_V23 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 150100534A5330304D004BA44F2A6003 [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSA Ok! LSSW Ok! LSSS Ok! LSSK Ok! LSSG Ok! Security Settings : Clear Ok! [Info] : Android 5.x / MT67xx : If phone stuck on "Logo" 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
12-09-2015, 12:22 | #29200 (permalink) |
Freak Poster Join Date: May 2012
Member: 1763380 Status: Offline Thanks Meter: 86 | android virus? money for me... Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7901004D4D433034474506849EB2310B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0079 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G40CM [eMMC] : FLASH_CID : 7901004D4D433034474506849EB2310B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : GT-I9600 ProdModel : GT-I9600 Device : GT-I9600 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 EXTRA : LCD [0] : ili9806e_fwvga_vdo_dsi LCD [1] : otm8018b_fwvga_dsi_vdo LCD Res : 854x480 TOUCH [0] : GT9XX TOUCH [1] : s2202 TOUCH [2] : ft6x06 CAM [0] : ov5645_mipi_yuv CAM [1] : ov5645_pip_yuv CAM [2] : ov7695_yuv CAM [3] : gc0329_yuv MODEM : lightning72_wet_jb3_hspa LOCALE : en_US zh_CN zh_TW es_ES ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR fa_IR sl_SI pl_PL hi_IN ca_ES sv_SE da_DK fi_FI hr_HR sr_RS hdpi Done! Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7901004D4D433034474506849EB2310B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0079 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G40CM [eMMC] : FLASH_CID : 7901004D4D433034474506849EB2310B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : GT-I9600 ProdModel : GT-I9600 Device : GT-I9600 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 [Read Ok] : preloader_lightning89_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / lightning89_wet_jb3 / EMMC FW Size : 688 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__alps__GT-I9600__GT-I9600__4.2.2__ALPS.JB3.MP.V1.2\ All done! Done! Elapsed: 00:03:17 Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 200/110/3000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7901004D4D433034474506849EB2310B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0079 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G40CM [eMMC] : FLASH_CID : 7901004D4D433034474506849EB2310B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 21 Removing infected files and scripts ... SmartAV Report : Removed 21 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Format FileSystem [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7901004D4D433034474506849EB2310B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0079 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G40CM [eMMC] : FLASH_CID : 7901004D4D433034474506849EB2310B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Repair Security [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7901004D4D433034474506849EB2310B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0079 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G40CM [eMMC] : FLASH_CID : 7901004D4D433034474506849EB2310B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 355236030442991 Set IMEI [00] : 355236030442991 Prepare finished. Security check required! Wait for phone... Phone found! [ 29 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
12-09-2015, 12:27 | #29201 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Club A95 Restart On Logo Done by FS with CM2 Code: Operation : Format File System [ v1.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
12-09-2015, 12:53 | #29202 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bangladesh
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | Rm-145 nokia 6233 flash done! RM-145 NOKIA 6233 FLASH DONE! Code: Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm123_145_30005.600.mcusw PPM : rm123_145_3005.60.ppm_x CNT : rm123_145_30005.60.image_x Check FlashFiles, Please, wait... -> Check SW version... FlashFile version : 05.60 Phone version : Error -> Error on SW version check... Backup enabled, Will read Certificates now... CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 26E0010684A20154E3C50225F534761AF70844DE CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F [1ST BOOT] : Boot Ok , 62 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 002F0001 , CMT , NOR CMT Flash ID : 002F0001 < SPANSION => 72NS256N FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok [2ND BOOT] : CMT : Boot Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 2F36DDC4990FD844712A61A80C033211BD9602E3C7 [ALGO BOOT] : CMT : Boot Ok Transmission mode : Dual (Ddr, TX2) [BOOT] : Ok , target ready CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 356293010440288 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) NPC Certificate saved... VARIANT Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert \356293010440288_CRT.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 26E0010684A20154E3C50225F534761AF70844DE CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F [1ST BOOT] : Boot Ok , 62 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 002F0001 , CMT , NOR CMT Flash ID : 002F0001 < SPANSION => 72NS256N FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok [2ND BOOT] : CMT : Boot Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 2F36DDC4990FD844712A61A80C033211BD9602E3C7 [ALGO BOOT] : CMT : Boot Ok Transmission mode : Dual (Ddr, TX2) [BOOT] : Ok , target ready Transmission mode : Dual (Ddr, TX2) Erase : Processing rm123_145_30005.600.mcusw Found 7 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0000FFFF CMT , NOR , Area : 0x00010000 - 0x0007FFFF CMT , NOR , Area : 0x000A0000 - 0x0021FFFF CMT , NOR , Area : 0x00220000 - 0x011DDFFF CMT , NOR , Area : 0x011DE000 - 0x011DEFFF CMT , NOR , Area : 0x011DF000 - 0x011DFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:18 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm123_145_30005.600.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 1061 blocks TIME : Write time : 00:01:48 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm123_145_3005.60.ppm_x Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x011E0000 - 0x016DFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:19 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm123_145_3005.60.ppm_x Total writen 311 blocks TIME : Write time : 00:00:35 PrReq : NOR , 00 CNT : Converted to 128k page data exist Transmission mode : Dual (Ddr, TX2) Erase : Processing rm123_145_30005.60.image_x_128 Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x016E0000 - 0x01E7FFFF CMT , NOR , Area : 0x01E80000 - 0x01FDFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:41 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm123_145_30005.60.image_x_128 Total writen 208 blocks TIME : Write time : 00:00:22 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 6233 Software Info: V 05.60 14-09-07 RM-145 (c) Nokia IMEI: 356293010440288 Product code: 0532188 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... Read and Check phone data... SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 26E0010684A20154E3C50225F534761AF70844DE CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F [1ST BOOT] : Boot Ok , 62 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 002F0001 , CMT , NOR CMT Flash ID : 002F0001 < SPANSION => 72NS256N FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok [2ND BOOT] : CMT : Boot Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 2F36DDC4990FD844712A61A80C033211BD9602E3C7 [ALGO BOOT] : CMT : Boot Ok Transmission mode : Dual (Ddr, TX2) [BOOT] : Ok , target ready PrReq : NOR , 00 Init Service mode... Wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6233 Software ver : V 05.60 14-09-07 RM-145 (c) Nokia IMEI : 356293010440288 XappVer : 00000852 DSP Ver : pb05wk46v50 PPM : V 05.60 14-09-07 RM123_145_- (c) Nokia X CNT : Content: x V 05.60 14-09-07 RM123_145_- (c) Nokia Product SN : 2AG593670 Product code : 0532188 Base Prd.code: 0528588 Module code : 0202772 Hardware info======= HWID : 1014 Retu : 32 Tahvo : 53 Battery: 4570 mV LCDVer: SEIKO RF ic : 17191719 Lock info =========== IMEI : 356293010440288 IMEI spNet : IMEI svNet : Conf key : 8000000000000002 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again User Code : 11111 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Resetting User Code to default (12345)... Clear data : Ok Result: 12345 Done! |
12-09-2015, 13:45 | #29203 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Voice Xtreme V70 Remove Virus Done :) Code: Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D565735B83101425980B860 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D420131B860B88059 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Xtreme ProdName : xtreme_v70 ProdModel : V70 Device : xtreme_v70 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D565735B83101425980B860 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D420131B860B88059 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Xtreme ProdName : xtreme_v70 ProdModel : V70 Device : xtreme_v70 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 [Read Ok] : preloader_xtreme_v70.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6589 / V1.0.0 / xtreme_v70 / EMMC FW Size : 683 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6589__Xtreme__V70__xtreme_v70__4.2.1__ALPS.JB2.MP.V1.2\ All done! Done! Elapsed: 00:03:16 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D565735B83101425980B860 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D420131B860B88059 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 58 Removing infected files and scripts ... SmartAV Report : Removed 58 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:50 Reconnect Power/Cable! Operation : Format FileSystem [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D565735B83101425980B860 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D420131B860B88059 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
12-09-2015, 13:46 | #29204 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Calme Spark S11 Remove Virus/Format Done :) Code: Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201932BC4D11113 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201932BC4D11113 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : V4 ProdName : V4 ProdModel : SPARK_S11 Device : V4 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201932BC4D11113 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201932BC4D11113 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : V4 ProdName : V4 ProdModel : SPARK_S11 Device : V4 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_v4_m1bom_pstan.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / v4_m1bom_pstan / EMMC FW Size : 488 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__V4__SPARK_S11__V4__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:02:27 Reconnect Power/Cable! Code: Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201932BC4D11113 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201932BC4D11113 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 1 Removing infected files and scripts ... SmartAV Report : Removed 1 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:29 Reconnect Power/Cable! Operation : Format FileSystem [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201932BC4D11113 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201932BC4D11113 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
12-09-2015, 13:54 | #29205 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Calme Spark S33 Read Factory FIrmware DOne :) Code: Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 76 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447584A5849BE7145 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447584A5849BE7145 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : CALME ProdName : Z16CCL ProdModel : S33 Device : Z16CCL AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 76 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447584A5849BE7145 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447584A5849BE7145 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : CALME ProdName : Z16CCL ProdModel : S33 Device : Z16CCL AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_vanzo72_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / vanzo72_wet_jb3 / EMMC FW Size : 678 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__CALME__S33__Z16CCL__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:03:20 Reconnect Power/Cable! |
