04-28-2016, 16:31 | #33346 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | Alcatel 4024d READING FLASH OK Code: Start at : [28/04/2016 / 16:12:38] Operation : Read FullFlash [ v1.15 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 37 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 37 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : 4024D Model Brand : TCL Model Device: PLAY_P1 AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA_18045 Project Ver : 4024D_D7_DZ_V1.2_160115 Model Ext : 4024D [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc7731g_modem_CP2_WCN_14E_W15.42.5_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img AndroidInfo created Firmware Size : 1243 MiB Saved to : C:\InfinityBox\CM2SPD\phdata\backup\4024d\SP7731GEA_18045_PLAY_P1_4.4.2_4024D_D7_DZ_V1.2_160115_4024D\ Done! Elapsed: 00:07:59 Reconnect Power/Cable! Finish at : [28/04/2016 / 16:20:37] Start at : [28/04/2016 / 16:21:35] Operation : SP Unlock [ v1.15 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 37 ] Open Port Failed! Reconnect Power/Cable! Finish at : [28/04/2016 / 16:21:39] Code: Start at : [28/04/2016 / 16:21:44] Operation : SP Unlock [ v1.15 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 37 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Locked! Unlocking ... Unlock Done! Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [28/04/2016 / 16:21:55] |
04-28-2016, 17:27 | #33347 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Qmobile A290 hang Format Code: Operation : Format FileSystem [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 92 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A25C40B131 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A25C40B131 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 8D24518ACC2E6D005A9BC13E27258CBA INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:34 |
04-28-2016, 19:39 | #33349 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 130 Code: Verify files ... MAUI : RM-1133_ROM_eMP_10.01.11 VIVA : RM-1133_VIVA_eMP_10.01.11 LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_10.01.11_004 CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_004 JMPT : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_004 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 28 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 78C09235E53261105342717C602C1116 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 SecureDecrypt : RM-1133_ROM_eMP_10.01.11 SecureDecrypt : RM-1133_VIVA_eMP_10.01.11 SecureDecrypt : RM-1133_LANG_PACK_ROM_IJ_eMP_10.01.11_004 SecureDecrypt : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_004 SecureDecrypt : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_004 OVRLP : 000069B900000001 PHPID : LAGOS61D.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1133_ROM_eMP_10.01.11 Write : RM-1133_LANG_PACK_ROM_IJ_eMP_10.01.11_004 Write : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_004 Write : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_004 Write : RM-1133_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1133_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1133_LANG_PACK_ROM_IJ_eMP_10.01.11_004 [VERIFY] DONE : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_004 [VERIFY] DONE : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_004 [VERIFY] DONE : RM-1133_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:50 Reboot phone Ok |
04-28-2016, 19:41 | #33350 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia Asha 200 Code: Files Set for Flashing : MCU : rm761__11.95.mcusw PPM : rm761__11.95.ppm_mec CNT : rm761__11.95.image_mec_059J4L2 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm761__11.95.mcusw Image : rm761__11.95.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:30 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x495E ===Flashing [PPM]=== File : rm761__11.95.ppm_mec Image : package_mec.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00740000 Erasing, wait ... Erase done, time : 00:00:21 Write , Start : 0x41A80000 , Len : 0x00697CF0 Flashing , wait ... Region flash done, time : 00:00:08 CRC check passed , 0x27DB ===Flashing [CNT]=== File : rm761__11.95.image_mec_059J4L2 Image : package_mec_059J4L2.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:02:40 Write , Start : 0x421C0000 , Len : 0x00FA0000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip CRC check passed , 0x9CE4 Flashing done! Total flash time : 00:05:54 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:06:39 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
04-28-2016, 19:43 | #33351 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia X2-01 Pasword Read Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000001099C01EC8DFB3E04305CD07B7B8B1 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 ADL: Check mode Select ASIC [C900] PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09 ADL: Reading certificates... Reading NPC certificate... IMEI : 352856053977871 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok CMLA Key read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352856053977871.rpl All done, Disconnecting Elapsed: 00:00:53 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - X2-01 Software ver : V 08.71 15-11-11 RM-709 (c) Nokia IMEI : 352856053977871 XappVer : 0000087A PPM : V 08.71 15-11-11 RM-709 (c) Nokia MH CNT : Content: mh_059C2Z2 V 08.71 15-11-11 RM-709 (c) Nokia Product SN : CJR819452 Product code : 059G521 Base Prd.code: 059B859 Module code : 0204674 Long Prod.SN : 0 Hardware info======= HWID : 1001 Battery: 3747 mV CMT BT: 2.31-SP2.31 LCDVer: SEIKO Lock info =========== IMEI : 352856053977871 IMEI spNet : 3A 25 58 06 35 79 87 07 IMEI svNet : 33 25 58 06 35 79 87 47 F3 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 824262 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
04-28-2016, 19:44 | #33352 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 112 Code: Files Set for Flashing : MCU : rm827__03.51.mcusw PPM : rm827__03.51.ppm_m2 CNT : rm827__03.51.image_m2_059Q541 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.51.mcusw Image : rm827__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xA3D6 ===Flashing [PPM]=== File : rm827__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x41BC0000 , Len : 0x0030F748 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x4605 ===Flashing [CNT]=== File : rm827__03.51.image_m2_059Q541 Image : package_m2_059Q541.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:10 Write , Start : 0x421C0000 , Len : 0x00F00000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x7EE5 Flashing done! Total flash time : 00:03:17 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:15 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
04-28-2016, 19:45 | #33353 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 205 Code: Files Set for Flashing : MCU : rm862__03.18.mcusw PPM : rm862__03.18.ppm_ma2 CNT : rm862__03.18.image_ma2_059Q0F3 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.55_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm862__03.18.mcusw Image : rm862__03.18.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x017C0000 Erasing, wait ... Erase done, time : 00:02:12 Write , Start : 0x40280000 , Len : 0x017C0000 Flashing , wait ... Region flash done, time : 00:00:31 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x107F ===Flashing [PPM]=== File : rm862__03.18.ppm_ma2 Image : package_ma2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A40000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:22 Write , Start : 0x41A40000 , Len : 0x003EF444 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xF579 ===Flashing [CNT]=== File : rm862__03.18.image_ma2_059Q0F3 Image : package_ma2_059Q0F3.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42080000 , Len : 0x01DA0000 Erasing, wait ... Erase done, time : 00:03:46 Write , Start : 0x42080000 , Len : 0x00FC0000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0xF79F Flashing done! Total flash time : 00:07:35 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:40 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
04-28-2016, 19:46 | #33354 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 108 Code: Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 28 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : D63E026DC943E07FBF8BE1462BFD1E78 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.10.04.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.10.04.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_12.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 Write : RM-944_VIVA_eMP_12.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_12.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_12.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:11 Reboot phone Ok |
04-28-2016, 19:47 | #33355 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia Asha 503 Code: Files Set for Flashing : MCU : rm922_14.0.6.mcusw.fls PPM : rm922_14.0.1_059S8P4_m1_2022_01_452465.rofs.fls CNT : rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A91012002459A4 IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1404.300_M1S1 QUARK EEP config Ok FLASHID : 20004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! ===Flashing [MCU]=== Processing file : rm922_14.0.6.mcusw.fls Region count : 7 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm922_14.0.6.mcusw.fls_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Code ] : aeneas_signed.fls 06 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm922_14.0.6.mcusw.fls_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x64800000 , Len : 0x02600000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x64800000 , Data Len : 0x023218B4 Region Load done Write done rm922_14.0.6.mcusw.fls_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x01100000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x000053DC Region Load done Write done swap_signed.fls image flash done Flash : 05 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x67F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x67F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 06 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00164348 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm922_14.0.1_059S8P4_m1_2022_01_452465.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x66E00000 , Len : 0x01100000 Erase now... Erase done Region Start : 0x66E00000 , Data Len : 0x005EF04C Region Load done Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls Region count : 1 00 : [ Cust ] : rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls.image.fls Parse done , flashing now Flash : 00 : rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C680000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x031C4000 Region Load done Write done rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls.image.fls image flash done Flashing done! Total flash time : 00:00:20 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:01:02 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
04-28-2016, 19:48 | #33356 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia C5 Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1E2001078BB300524440E33EF8F9B1EFFD69DAD2 ASIC MODE ID: 00 ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : D9C25399C696B8549EDCDB1497A950B3A20DDFB6 CFL : Reading flash certs.... CFL : Reading NPC IMEI : 357397046427554 CFL : Reading CCC CFL : Reading HWC CFL: Close_Session Content: 000300000000010000000100000000 CFL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357397046427554_XG213_CRT.rpl All done, Disconnecting Elapsed: 00:00:56 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:11 Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! |
04-28-2016, 19:49 | #33357 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia E63 Code: Files Set for Flashing : MCU : rm437_510.21.010_prd.c00 PPM : rm437_510.21.010_prd.v42 CNT : rm437_510.21.010.36U APE : sofie_erase_y_drive.fpsx CNT3 : RM437_ENO_008.07.45_100.71.952.a018.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1E2001078BB300524440E33EF8F9B1EFFD69DAD2 ASIC MODE ID: 00 ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! :) TIME : Boot time : 00:00:30 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm437_510.21.010_prd.c00 Found 3 areas to erase Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00A00000 - 0x0759FFFF, NAND, CMT Result: 0000 Erasing area 0x0F1C0000 - 0x0F8BFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partition erase not allowed by loader Partition erase not allowed by loader Partitioning : Ok [7] TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010_prd.c00 Total 533 [533/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:22 MCU Write done ===Flashing [PPM]=== Erase : Processing rm437_510.21.010_prd.v42 Found 1 areas to erase Erasing area 0x05420000 - 0x0759FFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010_prd.v42 Total 211 [211/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:35 PPM Write done ===Flashing [CNT]=== Erase : Processing rm437_510.21.010.36U Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010.36U Total 181 [181/0/0] blocks to write, writing... TIME : Write time : 00:00:29 CNT Write done ===Flashing [APE]=== Erase : Processing sofie_erase_y_drive.fpsx Found 1 areas to erase Erasing area 0x0F020000 - 0x0F1BFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing sofie_erase_y_drive.fpsx No any data for write, skip write APE Write done ===Flashing [CNT3]=== Erase : Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx TIME : Erase time : 00:00:00 Write : Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx Total 16 [16/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:02:30 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:03:30 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
04-28-2016, 19:50 | #33358 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 110 Code: Files Set for Flashing : MCU : rm827__03.51.mcusw PPM : rm827__03.51.ppm_m2 CNT : rm827__03.51.image_m2_059Q541 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.51.mcusw Image : rm827__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:00:52 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:36 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xA3D6 ===Flashing [PPM]=== File : rm827__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x41BC0000 , Len : 0x0030F748 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x4605 ===Flashing [CNT]=== File : rm827__03.51.image_m2_059Q541 Image : package_m2_059Q541.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:20 Write , Start : 0x421C0000 , Len : 0x00F00000 Flashing , wait ... Region flash done, time : 00:00:22 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x7EE5 Flashing done! Total flash time : 00:03:31 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:32 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
04-28-2016, 19:51 | #33359 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia C3 Pasword Read Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000C4A01AC15FB3A1E43FCDED7B301984 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 ADL: Reading certificates... Reading NPC certificate... IMEI : 359335041451748 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok CMLA Key read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359335041451748.rpl All done, Disconnecting Elapsed: 00:00:29 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C3-00 Software ver : V 08.65 12-05-11 RM-614 (c) Nokia IMEI : 359335041451748 XappVer : 0000087A PPM : V 08.65 12-05-11 RM-614 (c) Nokia MSH CNT : Content: Vodacom ZA v4 V 08.65 12-05-11 RM-614 (c) Nokia Product SN : CCM999252 Product code : 0594154 Base Prd.code: 059D7N6 Module code : 0204418 Long Prod.SN : 0 Hardware info======= HWID : 4000 Battery: 3755 mV CMT BT: 4217-v529 LCDVer: SEIKO Lock info =========== IMEI : 359335041451748 IMEI spNet : 3A 95 33 05 14 54 71 04 IMEI svNet : 33 95 33 05 14 54 71 34 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
04-28-2016, 19:52 | #33360 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 5130 Code: Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 04F00018F6028D56BB899F88C3C9601C2A7271BD CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:52 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:41 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mena_a1 Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:48 Write : Processing rm495__07.97.ppm_mena_a1 Total 388 [388/0/0] blocks to write, writing... TIME : Write time : 00:00:36 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:00 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:57 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:57 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:11:07 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
