06-25-2016, 13:35 | #34832 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Lenovo A319 Hang Logo Write File Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110191EAA8177281 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110191EAA8177281 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25EB284410B42CA6B36AA27168 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : A319 ProdModel : Lenovo A319 Device : A319 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : A319_ROW_DS_S313_150427 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.51 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110191EAA8177281 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110191EAA8177281 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25EB284410B42CA6B36AA27168 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3703 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin72_cwet_1a_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:20 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:19 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:07 Reconnect Power/Cable! |
06-25-2016, 13:57 | #34833 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Intex Aqua T4 MT6571 NAND Hang LOGO AND Read F/F DONE FORMAT Code: Operation : Format FileSystem [ v1.50 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001500010000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0x922D73355907A342564BDDE9ED5CA3A1 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! --------------------------------------------------------------------------------- RAED F/Firmware Code: Operation : Read Flash [ v1.50 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001500010000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0x922D73355907A342564BDDE9ED5CA3A1 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_vanzo71_cwet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6571 / V1.1.1 / vanzo71_cwet_lca / NAND FW Size : 255 MiB Brand : alps ProdName : Aqua_T4 ProdModel : Aqua T4 Device : Aqua_T4 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1 Android Info saved Scatter saved to : C:\Users\Downloads\ MT6571_NAND_alps__Aqua T4__Aqua_T4__4.4.2__ALPS.KK1.MP7.V1 Done! Elapsed: 00:02:53 Reconnect Power/Cable! |
06-25-2016, 14:06 | #34834 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | iphone 5 read ff done Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 00AD00BC00900055005400AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008B , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xC1F94A5CA6635E8CAFE663CE0C4A1E7E INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : benrui71_e_lca ProdModel : MT6571 Device : benrui71_e_lca AndroidVer: 4.2.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.JB7.MP.V1.14 SECURITY : BTMAC Addr : B8A3E06FABA5 WiFi MAC : B8A3E06FABA5 Done! Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Read Flash [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 00AD00BC00900055005400AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008B , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xC1F94A5CA6635E8CAFE663CE0C4A1E7E INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_benrui71_e_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6571 / V1.1.1 / benrui71_e_lca / NAND FW Size : 307 MiB Brand : alps ProdName : benrui71_e_lca ProdModel : MT6571 Device : benrui71_e_lca AndroidVer: 4.2.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.JB7.MP.V1.14 Android Info saved Scatter saved to : C:\MT6571_NAND_alps__MT6571__benrui71_e_lca__4.2.2__ALPS.JB7.MP.V1.14 Done! Elapsed: 00:03:44 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473464040501A14C245165 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d4GA [eMMC] : FLASH_CID : 90014A4841473464040501A14C245165 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5CCD7552A30E0C84B4DEC827BC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : Titanium Octane ProdModel : Titanium Octane Device : tianyu92_wet_kk AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.11 SECURITY : IMEI_SW [1] : 91136125025---- IMEI_SW [2] : 91136125025---- BTMAC Addr : 125825155709 WiFi MAC : E8D4E0EDEFE1 MODEM : BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V35_P3_1_wg_n Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473464040501A14C245165 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d4GA [eMMC] : FLASH_CID : 90014A4841473464040501A14C245165 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5CCD7552A30E0C84B4DEC827BC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D42008EA8FAAA42BB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D42008EA8FAAA42BB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5C19F033B9FC4CB44E89AC67A7 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Panasonic ProdName : ELUGA_Z ProdModel : Panasonic ELUGA Z Device : ELUGA_Z AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : K3466_DK34661_KARBONN_L111 SECURITY : IMEI_SW [1] : 35211107002---- IMEI_SW [2] : 35211107005---- BTMAC Addr : EEFC466592D1 WiFi MAC : 700BC0879208 MODEM : BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P20_1_wg_n EXTRA : LCD [0] : rm69052_hd720_dsi_vdo_auo_q34 LCD Res : 1280x720 TOUCH [0] : s3402_q34 CAM [0] : ov13850_mipi_raw_sunwin CAM [1] : ov5670_mipi_raw MODEM : dewav92_wet_kk_hspa LOCALE : en_US en_GB hi_IN ja_JP fr_FR de_DE it_IT ru_RU zh_CN ar_IL bn_IN th_TH af_ZA ar_IL zh_TW en_IN tl_PH in_ID fa_IR pt_PT es_ES sw_TZ ur_PK vi_VN zu_ZA nl_BE nl_NL pl_PL tr_TR uk_UA gu_IN mr_IN pa_IN Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D42008EA8FAAA42BB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D42008EA8FAAA42BB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5C19F033B9FC4CB44E89AC67A7 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : Panasonic ProdName : ELUGA_Z ProdModel : Panasonic ELUGA Z Device : ELUGA_Z AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : K3466_DK34661_KARBONN_L111 [Read Ok] : preloader_k3466.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : test.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6592 / V1.1.2 / k3466 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1260 MiB Scatter saved to : C:\MT6592__Panasonic__Panasonic_ELUGA_Z__ELUGA_Z__4.4.2__K3466_DK34661_KARBONN_L111\ All done! Done! Elapsed: 00:05:13 Reconnect Power/Cable! |
06-25-2016, 14:26 | #34835 (permalink) |
Insane Poster Join Date: Feb 2015
Member: 2339459 Status: Offline Thanks Meter: 26 | nokia x2 android dead recover with best dongle done nokia x2 android dead recover with best dongle done Connect phone on selected interface... Core : v2.21 , NXP FlashEngine : v5.2 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.13_059V782_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.13_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Handshake Ok Init[0] : 0x01000000 Init[1] : 0x30000000 Sending Loader ... Init Loader ... FireHose Initialized Device Init OkTarget VER : 1 Target CPU : 8x10 Target FLN : eMMC Target CNF : 1000/C000/1000 Target DBG : logbuf@0xF8021118 fh@0xF801DF80 Files in Chain : 67 Flashing now Flashing : rm1013_2.1.0.13_user_NON-HLOS.bin ProgInit : start 16384, num 75203 ProgDone : Finished sector address 91587 Flash Ok Flashing : rm1013_2.1.0.13_user_sbl1.mbn ProgInit : start 147456, num 492 ProgDone : Finished sector address 147948 Flash Ok Flashing : rm1013_2.1.0.13_user_sbl1.mbn ProgInit : start 148480, num 492 ProgDone : Finished sector address 148972 Flash Ok Flashing : rm1013_2.1.0.13_user_sdi.mbn ProgInit : start 149504, num 45 ProgDone : Finished sector address 149549 Flash Ok Flashing : rm1013_2.1.0.13_user_emmc_appsboot.mbn ProgInit : start 180224, num 938 ProgDone : Finished sector address 181162 Flash Ok Flashing : rm1013_2.1.0.13_user_emmc_appsboot.mbn ProgInit : start 181248, num 938 ProgDone : Finished sector address 182186 Flash Ok Flashing : rm1013_2.1.0.13_user_rpm.mbn ProgInit : start 182272, num 296 ProgDone : Finished sector address 182568 Flash Ok Flashing : rm1013_2.1.0.13_user_rpm.mbn ProgInit : start 183272, num 296 ProgDone : Finished sector address 183568 Flash Ok Flashing : rm1013_2.1.0.13_user_boot.img ProgInit : start 196608, num 14549 ProgDone : Finished sector address 211157 Flash Ok Flashing : rm1013_2.1.0.13_user_tz.mbn ProgInit : start 229376, num 663 ProgDone : Finished sector address 230039 Flash Ok Flashing : rm1013_2.1.0.13_user_tz.mbn ProgInit : start 230376, num 663 ProgDone : Finished sector address 231039 Flash Ok Flashing : rm1013_2.1.0.13_user_system_1.img ProgInit : start 344064, num 262160 ProgDone : Finished sector address 606224 Flash Ok Flashing : rm1013_2.1.0.13_user_system_2.img ProgInit : start 606600, num 16 ProgDone : Finished sector address 606616 Flash Ok Flashing : rm1013_2.1.0.13_user_system_3.img ProgInit : start 610352, num 257992 ProgDone : Finished sector address 868344 Flash Ok Flashing : rm1013_2.1.0.13_user_system_4.img ProgInit : start 868352, num 16 ProgDone : Finished sector address 868368 Flash Ok Flashing : rm1013_2.1.0.13_user_system_5.img ProgInit : start 872104, num 258384 ProgDone : Finished sector address 1130488 Flash Ok Flashing : rm1013_2.1.0.13_user_system_6.img ProgInit : start 1130496, num 16 ProgDone : Finished sector address 1130512 Flash Ok Flashing : rm1013_2.1.0.13_user_system_7.img ProgInit : start 1130888, num 16 ProgDone : Finished sector address 1130904 Flash Ok Flashing : rm1013_2.1.0.13_user_system_8.img ProgInit : start 1134640, num 95696 ProgDone : Finished sector address 1230336 Flash Ok Flashing : rm1013_2.1.0.13_user_system_9.img ProgInit : start 1392640, num 16 ProgDone : Finished sector address 1392656 Flash Ok Flashing : rm1013_2.1.0.13_user_system_10.img ProgInit : start 1654784, num 16 ProgDone : Finished sector address 1654800 Flash Ok Flashing : rm1013_2.1.0.13_user_system_11.img ProgInit : start 1655176, num 16 ProgDone : Finished sector address 1655192 Flash Ok Flashing : rm1013_2.1.0.13_user_cache_1.img ProgInit : start 1777664, num 11376 ProgDone : Finished sector address 1789040 Flash Ok Flashing : rm1013_2.1.0.13_user_recovery.img ProgInit : start 1974272, num 15529 ProgDone : Finished sector address 1989801 Flash Ok Flashing : rm1013_2.1.0.13_user_misc_erase.img ProgInit : start 1998848, num 1 ProgDone : Finished sector address 1998849 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_1.img ProgInit : start 2015232, num 262136 ProgDone : Finished sector address 2277368 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_2.img ProgInit : start 2277376, num 16 ProgDone : Finished sector address 2277392 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_3.img ProgInit : start 2277640, num 16 ProgDone : Finished sector address 2277656 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_4.img ProgInit : start 2280856, num 258656 ProgDone : Finished sector address 2539512 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_5.img ProgInit : start 2539520, num 16 ProgDone : Finished sector address 2539536 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_6.img ProgInit : start 2542736, num 252928 ProgDone : Finished sector address 2795664 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_7.img ProgInit : start 2801664, num 16 ProgDone : Finished sector address 2801680 Flash Ok Flashing : rm1013_2.1.0.13_059V782_001.custom_8.img ProgInit : start 2801928, num 16 ProgDone : Finished sector address 2801944 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_1.img ProgInit : start 2834432, num 80272 ProgDone : Finished sector address 2914704 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_2.img ProgInit : start 3096576, num 16 ProgDone : Finished sector address 3096592 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_3.img ProgInit : start 3097800, num 16 ProgDone : Finished sector address 3097816 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_4.img ProgInit : start 3358720, num 16 ProgDone : Finished sector address 3358736 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_5.img ProgInit : start 3620864, num 16 ProgDone : Finished sector address 3620880 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_6.img ProgInit : start 3622088, num 16 ProgDone : Finished sector address 3622104 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_7.img ProgInit : start 3883008, num 16 ProgDone : Finished sector address 3883024 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_8.img ProgInit : start 4145152, num 16 ProgDone : Finished sector address 4145168 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_9.img ProgInit : start 4146376, num 16 ProgDone : Finished sector address 4146392 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_10.img ProgInit : start 4407296, num 16 ProgDone : Finished sector address 4407312 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_11.img ProgInit : start 4669440, num 16 ProgDone : Finished sector address 4669456 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_12.img ProgInit : start 4670664, num 16 ProgDone : Finished sector address 4670680 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_13.img ProgInit : start 4931584, num 16 ProgDone : Finished sector address 4931600 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_14.img ProgInit : start 5193728, num 16 ProgDone : Finished sector address 5193744 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_15.img ProgInit : start 5194952, num 16 ProgDone : Finished sector address 5194968 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_16.img ProgInit : start 5455872, num 16 ProgDone : Finished sector address 5455888 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_17.img ProgInit : start 5718016, num 16 ProgDone : Finished sector address 5718032 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_18.img ProgInit : start 5980160, num 16 ProgDone : Finished sector address 5980176 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_19.img ProgInit : start 6242304, num 16 ProgDone : Finished sector address 6242320 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_20.img ProgInit : start 6504448, num 16 ProgDone : Finished sector address 6504464 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_21.img ProgInit : start 6766592, num 16 ProgDone : Finished sector address 6766608 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_22.img ProgInit : start 7028736, num 16 ProgDone : Finished sector address 7028752 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_23.img ProgInit : start 7290880, num 16 ProgDone : Finished sector address 7290896 Flash Ok Flashing : rm1013_2.1.0.13_user_userdata_24.img ProgInit : start 7553024, num 16 ProgDone : Finished sector address 7553040 Flash Ok Chain finished, All files flashed! Rebooting phone now Flashing done! Total flash time : 00:03:04 bro. usmantahir118 |
The Following User Says Thank You to usman.118 For This Useful Post: |
06-25-2016, 14:35 | #34836 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile Power 900 Read Flash File DOne Code: Operation : Read Flash [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 33D1E57211F09B7124505ABD1629E76D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : FARSIGHTED61D_11C_PCB01_gprs_MT6261_S00.QMOBILE_POWER900_V04.bin FileVersion : QMobile_Power900_V04 Saved to : C:\InfinityBox\CM2MTK\Read_out\FARSIGHTED61D_11C_PCB01_gprs_MT6261_S00.QMOBILE_POWER900_V04.bin Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
06-25-2016, 15:50 | #34837 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | SYMPHONY Symtab20 read done Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 153 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E43617264202907E010364301 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E43617264202907E010364301 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0x3D106F2D39E6E42601E438AA020DBB36 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : SYMPHONY ProdName : Symtab20 ProdModel : Symtab20 Device : Symtab20 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.43 SECURITY : IMEI_SW [1] : 351737080200399 IMEI_SW [2] : 351737080230396 BTMAC Addr : 000CE752009B WiFi MAC : 000A0052009B MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V71_P1_1_wg_n EXTRA : LCD [0] : KR070IG1T_9122 LCD Res : 600x1024 TOUCH [0] : GT910_9122 CAM [0] : gc0329_yuv_9122 CAM [1] : gc0312_yuv_9120 CAM [2] : gc2155_yuv_9122 MODEM : miki12c_tb_kk_hspa_900_1900_2100 LOCALE : en_US ur_PK bn_BD es_ES zh_CN zh_HK zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB Done! Elapsed: 00.00.35 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 153 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E43617264202907E010364301 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E43617264202907E010364301 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0x3D106F2D39E6E42601E438AA020DBB36 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V71_P1_1_wg_n NVM Read Ok, MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V71_P1_1_wg_n_eMMC.spnv Done! Elapsed: 00.00.36 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 153 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E43617264202907E010364301 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E43617264202907E010364301 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0x3D106F2D39E6E42601E438AA020DBB36 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : SYMPHONY ProdName : Symtab20 ProdModel : Symtab20 Device : Symtab20 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.43 [Read Ok] : preloader_symphony12c_9122.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / symphony12c_9122 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1009 MiB Scatter saved to : E:\All Flash file\Android\China\Symphony\New folder\MT6572__SYMPHONY__Symtab20__Symtab20__4.4.2__ALPS.KK1.MP7.V1.43\ All done! Done! Elapsed: 00.04.59 Reconnect Power/Cable! |
06-25-2016, 15:53 | #34838 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | Winmax W50 user code read done Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 49D022519CE04F96252CBBE4F69DFC91 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x002FE000 , 0x00002000 Done! Elapsed: 00.00.07 Reconnect Power/Cable! Code: Operation : Read UserCode [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 49D022519CE04F96252CBBE4F69DFC91 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x002FE000 , 0x00002000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 5566 PLock|MobTrack : Not active Done! Elapsed: 00.00.03 Reconnect Power/Cable! |
06-25-2016, 16:42 | #34839 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | lg d100 flash ok Code: Scatter Load Ok , BaseBand : MT6572 , Project : muse72_s2_kk0 , Storage : EMMC Files found : 17 , Set to Flash : 16 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : lge Device Model : luv20ss Device CPU : MT6572 Device IntName : luv20ss_global_com Device Version : 4.4.2 Device Compile : 09/12/2014 11:34:21 Device Project : ALPS.W10.24.p0 Device ExtInfo : LG-D100 Ready to Flash! Operation : Flash [ v1.51 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 376 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35585A4D4206AC46DC9DC1B3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4206AC46DC9DC1B3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x76BB4F4FCFF441E67B83A569BEE240C7 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : muse72_s2_kk0 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3726 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 3 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000001D00000-0x0000000000080000 Erase : 0x0000000003980000-0x00000000E3680000 Flash Pre-Erase Done, time used : 00:00:11 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_muse72_s2_kk0.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 001F Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : _EXT_PL Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : EBR3 Image Flash Ok Flash now : PERSIST Image Flash Ok Flash now : CUST Image Flash Ok Flash now : FACTORY Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:55 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : _EXT_PL Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : EBR3 Verify Passed : PERSIST Verify Passed : CUST Verify Passed : FACTORY Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:27 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:48 Reconnect Power/Cable! |
06-25-2016, 18:14 | #34840 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Gujranwala Age: 25
Member: 2451476 Status: Offline Sonork: 100.1669164 Thanks Meter: 345 | VGOTel Venture_V2 hang on logo done by cm2 FEEL THE ULTRA POWER OF CHINESE TOOLS Operation : Flash [ v1.51 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E355530304D0246E880648037 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U5 [eMMC] : FLASH_CID : 1501004E355530304D0246E880648037 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xB4A11DC7ECA47A3E44CB6F9A8A9630A5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : konka72_i120_emmc_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3541 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E5C20000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_konka72_i120_emmc_jb3.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:16 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:26 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:04 Reconnect Power/Cable! |
The Following User Says Thank You to UMeR3 For This Useful Post: |
06-25-2016, 18:17 | #34841 (permalink) |
Member: 2451476 Status: Offline Sonork: 100.1669164 Thanks Meter: 345 | QMOBILE K160 FORMATE DONE BY CM2 WITHOUT ANY RISK Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 60 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
06-25-2016, 18:19 | #34842 (permalink) |
Member: 2451476 Status: Offline Sonork: 100.1669164 Thanks Meter: 345 | QMOBILE W10 FORMATE DONE WITH OUT aNY RIsk Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 63 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000009A1F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
06-26-2016, 06:41 | #34844 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Q I6I HANG ON LOGO DONE WITH WRITE FLASH. Code: Chinese Miracle II [MTK module] v 1.51 Scatter Load Ok , BaseBand : MT6580 , Project : s5030 , Storage : EMMC Files found : 9 , Set to Flash : 8 Ready to Flash! Operation : Flash [ v1.51 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A32374D4202B719DE9182A7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM72J [eMMC] : FLASH_CID : 150100464A32374D4202B719DE9182A7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x1A73FE40530353F5F418412204CAFECF INT RAM : 0x00020000 EXT RAM : 0x30000000 [768 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : s5030 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3735 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000000E6300000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5030.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:03:05 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:02 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:36 Reconnect Power/Cable! |
06-26-2016, 07:28 | #34845 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | HUAWEI Y511-U30 Reset Code Done :) Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A23B60A071 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A23B60A071 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D1822A3082FAF7AD6580B2EED INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : Y511-U30 ProdModel : HUAWEI Y511-U30 Device : HWY511-U AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A23B60A071 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A23B60A071 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D1822A3082FAF7AD6580B2EED INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSGS Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
