Old 10-19-2017, 14:32   #45661 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile K550 SPD6531 Illegal use Fix Only Formate Done With Infinity CM2
Card found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 9 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 10-19-2017, 15:49   #45662 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X2 Energy MT6580 FRP Reset Done With King Infinity CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 37 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4841473265050732DB694BB3A9
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265050732DB694BB3A9
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F39556C88DF30D1A8FB3A81F1E42
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:11
Old 10-19-2017, 16:21   #45663 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
moto E3 frp remove done
Card found : S/N : 29BC6477 , v0136
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 460001154D32584EC1B30142DFBFFFCE
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D4201B3C1CEFF63DF
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x51EA5065C6B4EC359BCF74580C3A5B76
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to khanzada606 For This Useful Post:
Old 10-20-2017, 05:39   #45664 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile E4 MT625A Read Code Done With King Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 16 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 99FAAE14721D67F43D6B7D55F81470F9
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : EF00 4000 1600 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D400
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 66156
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:09
Old 10-20-2017, 06:44   #45665 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
CUBOT Z100 PRO FRP REMOVE MT6735/6737M Done
SUCCESSFULLY REMOVE FRP(CUBOT Z100 PRO MT6735/6737M)USB
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 32 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
eMMC Flash : 520001154142313339B40642D7965BAA
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0xC0000000
[eMMC] : FLASH_INF : [SAMSUNG] , BAB13
[eMMC] : FLASH_CID : 15010052333142414206B439AA5B73D7
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xFD096D450BF474EE73AA926A4FAF2A87
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : CUBOT
ProdName : Z100 Pro
ProdModel : Z100 Pro
Device : Z100_Pro
AndroidVer: 5.1
MTKxCPU : MT6735
MTKxPRJ : ALPS.L1.MP3.V1_VANZO6735M.35GC.L_P76
SECURITY :
IMEI_SW [1] : XXXXXXXXXXXXXX
IMEI_SW [2] : XXXXXXXXXXXXXX
BTMAC Addr : XXXXXXXXX
WiFi MAC : XXXXXXXXXX
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V8_P32_1_lwg_ n
EXTRA :
LCD : Not info available
LCD Res : 960x540
TOUCH [0] : GT1XX
CAM [0] : imx219_mipi_raw
CAM [1] : gc2355_mipi_raw
MODEM : vanzo6735m_65c_l_lttg_dsds_cmcc vanzo6735m_65c_l_lwg_dsds_cmcc
LOCALE : zh_CN en_US zh_TW
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 32 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:48
THANKS INFINITY-BOX TEAM
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 10-20-2017, 06:57   #45666 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
ALCATEL POP D5 TCL 5038D PATTERN LOCK REMOVE Done
SUCCESSFULLY REMOVE PATTERN LOCK(ALCATEL POP D5 TCL 5038D)USB
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A483447316404050AA1474C4179
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A483447316404050AA1474C4179
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xFD096D45AEACE0E5FCCB1C88E3C8E17C
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Brand : TCL
ProdName : 5038D
ProdModel : 5038D
Device : SOUL45_GSM
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.KK1.MP1.V2.10
Done!
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:41
Old 10-20-2017, 07:10   #45667 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Samsung Clone S338 SPD6531 Read Code/Read File Done With King Infinity CM2
Read Code Done
Operation : Read User Code [ v1.27 ]
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
Check data... Can take some time
User Code : 1213
Done!
Elapsed: 00:00:06
Read File Done
Operation : Read FullFlash [ v1.27 ]
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
Set FileInfo :
Model Vendor : Samsung
Model Name : S338
ExtInfo Data : Eng
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32_Eng__Samsung -S338.bin
Done!
Elapsed: 00:00:47
Old 10-20-2017, 09:20   #45668 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
OPPO A37F FRP REMOVE Done
SUCCESSFULLY REMOVE FRP(OPPO A37F)USB
Operation : Identify [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 1E117980
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 05FF9561CC5A47423D12E2E32C77FFCF
ID_BLOCK_L : C8BB05A4A938A223A6117AB3B17C6A51
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand : OPPO
ProdName : A37f
ProdModel : A37f
Device : A37f
AndroidVer: 5.1.1
SWVersion : A37fEX_11.A.14_INT_014_201610141638
Manufact. : OPPO
SysPatch : LMY47V
QLMxCPU : MSM8916
Done!
Elapsed: 00:00:08
Operation : Reset Settings [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:22
The Following 4 Users Say Thank You to gracy_elec For This Useful Post:
Old 10-20-2017, 09:33   #45669 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
LAVA A1 HANG ON LOGO REPAIR Done
SUCCESSFULLY RECOVER HANG ON LOGO(LAVA A1)USB
Set mode to : SP [SC773x] eMMC [Android 5.x]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 45 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : A1
Model Brand : Lava
Model Device: A1
AndrVersion : 5.1
BaseBand CPU: A1
CompileDate : 10/16/2015 8:32:03 AM
Project Ver : Lava_iris_atom_S109_20151016
Model Ext : A1
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:19
3. Insert cable
Phone found! [ 45 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:22
Old 10-20-2017, 10:21   #45670 (permalink)
Member: 2628089
Sonork: 100.1670212
Thanks Meter: 102
Smile Samsung J7 (2015) J700H FRP Remove Done 1 Click By InfinityBox SM Tool
[IMG][/IMG]
The Following User Says Thank You to firmwarehouse For This Useful Post:
Old 10-20-2017, 14:00   #45671 (permalink)
Member: 935112
Sonork: 100.1675738
Thanks Meter: 15
solid soulution
https://*********/DKRUlPIq7Dw
Old 10-20-2017, 14:04   #45672 (permalink)
Member: 935112
Sonork: 100.1675738
Thanks Meter: 15
coolpad e2 frp done
copy & pest url & del space
https:// you tu. be /DKRUlPIq7Dw
Old 10-21-2017, 05:03   #45673 (permalink)
awanbrother's Avatar
Member: 2505147
Thanks Meter: 183
LG-D850 MSM8974 AOSv6.0 read backup done by great cm2 lgs
Card found : CD924DCD , v0136
Infinity-Box LG Service Tool [ LGS ] v1.03
Operation : Read Firmware [ v1.03 ]
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x01
Boot done!
DevInfo : MSM8974__LG-D850__D85030l__V30l__AOSv6.0__LGD850AT-00-V30l-ATT-US-MAY-11-2016+0
Reading Flash Content ...
[Read Ok] : gpt_main.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : sbl1.mbn
[Read Ok] : dbi.mbn
[Read Ok] : ddr.bin
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : boot.img
[Read Ok] : persist.img
[Read Ok] : recovery.img
[Read Ok] : misc.img
[Read Ok] : laf.img
[Read Ok] : persist_lg.img
[Read Ok] : calibration.img
[Read Ok] : fact.img
[Read Ok] : system.img
[Read Ok] : gpt_backup.bin
Android Info saved!
Read finished!
Configuration : MSM8974 / 6.0 / V30l
Firmware Size : 3011 MiB
Done!
Elapsed: 00:02:55
Operation : Reset Settings/Format FS [ v1.03 ]
Wait for phone...
Handshake passed!
Collect info...
Boot done!
Format UserData
Format Cache
Format done
Done!
Elapsed: 00:00:13
The Following User Says Thank You to awanbrother For This Useful Post:
Old 10-21-2017, 05:53   #45674 (permalink)
Taguro-GSMLover's Avatar
Member: 2669319
Thanks Meter: 421
Polaroid Rockchip RK3066 MID0880 Password Locked and READ FLASH Done
Card found : BCE8XXXX , v0136
Infinity-Box RockChip Service Tool [RKT] v2.01
Operation : Identify [ v2.01 ]
----- > Phone/Tablet :
1. Power Off device
3. Insert USB cable! Press 'POWER_ON' button for a few second!
----- > IoT/Box :
1. Reset device power
2. PRESS and HOLD 'RESET' KEY!
3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second!
Wait for device ...
Device Connected!
Interface test : Passed
Device mode : Normal [ LOADER OPEN ]
Machine : RK3066
Device : MID0880
ExtInfo : 4.1.1
SoC CPU : 300B
SoC PDT : 2012
SoC SWN : 1001
SoC REV : V100
Flash CSx : 0x00
Flash Type : 2C64444BA9 [ NAND ]
Flash Vend : MICRON
Flash Size : 0x0000000200000000 ( 8.00 GiB )
Flash Info : 2097152/8192/30/40/1
Connect Ok!
Brand : rk30sdk
ProdName : rk30sdk
ProdModel : MID0880
Device : rk30sdk
AndroidVer: 4.2.2
Manufact. : rockchip
SysPatch : JDQ39
RKTxCPU : RK30XXB
Done!
Elapsed: 00:00:03
Operation : Reset Settings [ v2.01 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
Machine : RK3066
Device : MID0880
ExtInfo : 4.1.1
SoC CPU : 300B
SoC PDT : 2012
SoC SWN : 1001
SoC REV : V100
Flash CSx : 0x00
Flash Vend : MICRON
Connect Ok!
Wiping UserData ...
Wipe DATA Ok!
Done!
Elapsed: 00:00:03
Operation : Read Firmware [ v2.01 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
Machine : RK3066
Device : MID0880
ExtInfo : 4.1.1
SoC CPU : 300B
SoC PDT : 2012
SoC SWN : 1001
SoC REV : V100
Flash CSx : 0x00
Flash Vend : MICRON
Connect Ok!
Brand : rk30sdk
ProdName : rk30sdk
ProdModel : MID0880
Device : rk30sdk
AndroidVer: 4.2.2
SysPatch : JDQ39
RKTxCPU : RK30XXB
DevInfo : RK30XXB__rockchip__rk30sdk__ANDR_v4.2.2__MID0880
[Read Ok] : param.cfg
[Read Ok] : kernel.img
[Read Ok] : backup.img
Android Info saved!
Read finished!
Configuration : RK3066 / 2C64444BA9 [ NAND ]
Firmware Size : 872 MiB
Done!
Elapsed: 00:01:22
The Following User Says Thank You to Taguro-GSMLover For This Useful Post:
Old 10-21-2017, 06:26   #45675 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile K140 SPD6531 Logo Stuck Fix Only Formate With Infinity CM
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:10
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.61072 seconds with 10 queries
