Old 10-24-2017, 14:50   #45736 (permalink)
jjamshad5's Avatar
Member: 2156086
Sonork: 4562
Thanks Meter: 210
samsung J510F FRP LOCK DONE
Phone found on COM9
Phone In Download mode...
Reset FRP Procedure started...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
Phone Disconnected
The Following User Says Thank You to jjamshad5 For This Useful Post:
Old 10-25-2017, 05:44   #45737 (permalink)
Taguro-GSMLover's Avatar
Member: 2669319
Thanks Meter: 421
Oppo A57 Read Flash Done
Operation : Read Flash [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 435 [MSM8940]
ID_BLOCK_S : 3E097E1E
ID_BLOCK_I : 0006B0E1
ID_BLOCK_L : 10CE4FF5CDDBA2B398CACC7CDB92EDA8
ID_BLOCK_L : 3F068F98237BE8422B4489B4A8FB71EA
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB
Boot Ok!
Brand : Android
ProdName : CPH1701
ProdModel : CPH1701
Device : CPH1701
AndroidVer: 6.0.1
SWVersion : CPH1701EX_11.A.21_INT_021_201708202024
Manufact. : OPPO
QLMxCPU : MSM8937
DevInfo : MSM8937__OPPO__Android__ANDR_v6.0.1__CPH1701__CPH1 701__CPH1701__CPH1701EX_11.A.21_INT_021_2017082020 24
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : sbl1.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : devcfg.mbn
[Read Ok] : adspso.bin
[Read Ok] : pnvbak.img
[Read Ok] : lsplash.img
[Read Ok] : ddr.bin
[Read Ok] : sec.dat
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : cache.img
[Read Ok] : system.img
[Read Ok] : persist.img
[Read Ok] : misc.img
[Read Ok] : mdtp.img
[Read Ok] : cmnlib.mbn
[Read Ok] : cmnlib64.mbn
[Read Ok] : keymaster.mbn
[Read Ok] : ap.mbn
[Read Ok] : driver.iso
[Read Ok] : reserve4.bin
[Read Ok] : reserve_exp1.bin
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
[Read Ok] : gpt_main2.bin
[Read Ok] : cdt.mbn
[Read Ok] : gpt_backup2.bin
Android Info saved!
Read finished!
Configuration : MSM8937 / eMMC
Firmware Size : 4581 MiB
Done!
Elapsed: 00:08:47
Reconnect Power/Cable!
The Following User Says Thank You to Taguro-GSMLover For This Useful Post:
Old 10-25-2017, 05:44   #45738 (permalink)
Member: 2669319
Thanks Meter: 421
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Brand : Android
ProdName : CPH1701
ProdModel : CPH1701
Device : CPH1701
AndroidVer: 6.0.1
Manufact. : OPPO
QLMxCPU : MSM8937
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : ddr.bin
[Read Ok] : sec.dat
[Read Ok] : ap.mbn
[Read Ok] : cdt.mbn
Android Info saved!
Read finished!
Done!
Elapsed: 00:08:47
Old 10-25-2017, 07:18   #45739 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
ONEPLUS 3T A3003 HANG ON LOGO RECOVER Done
SUCCESSUFLLY RECOVER HANG ON LOGO (ONEPLUS 3T A3003)USB
Operation : Identify [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 820 [MSM8996]
ID_BLOCK_S : 5A33E03C
ID_BLOCK_I : 009470E1
ID_BLOCK_E : 2A703DB9
ID_BLOCK_L : 454CECA2056D82B3312CD92CC1B67322
ID_BLOCK_L : 845560538E4FD2FAA377031B53E56054
Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1
ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000
UFS Device : SAMSUNG KLUCG4J1CB-B0B1 0800
UFS SectSize : 0x1000
UFS LU0 Size : 0x00000007602F0000 : 29.50 GiB
--------------UFS Device Info--------------
UFS Total Active LU: 0x6
UFS wManufacturerID: 0x1ce
UFS Boot Partition Enabled: 0x1
UFS LU Write Protect: 0x0
UFS Boot LUN ID: = 0x0
UFS Memory Type: 0x0
UFS LU Total Blocks: 0x0
UFS Supported Memory Types: 0x800f
UFS LUN Enable Bitmask: 0x3f
UFS bConfigDescrLock: 0x0
Boot Ok!
Brand : OnePlus
Device : OnePlus3
AndroidVer: 6.0.1
SWVersion : OnePlus3Oxygen_16.A.07_GLO_007_1606062247
Manufact. : OnePlus
SysPatch : MMB29M
QLMxCPU : MSM8996
Done!
Elapsed: 00:00:16
Operation : Reset Settings [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:13
THANKS INFINITY-BOX TEAM
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 10-25-2017, 07:22   #45740 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
SAMSUNG B310E HANG ON LOGO RECOVER Done
SUCCESSFULLY RECOVER HANG ON LOGO(SAMSUNG B310E)USB
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 37 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6530 , FDLStat : 00C0
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Elapsed: 00:00:08
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 37 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:21
The Following 3 Users Say Thank You to gracy_elec For This Useful Post:
Old 10-25-2017, 07:40   #45741 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
HTC D616 PATTERN LOCK REMOVE Done
SUCCESSFULLY REMOVE PATTERN LOCK(HTC D616)USB
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 23 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048601A3D55151DB
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A3D55151DB
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xFD096D45F451659D7F61F147362D6293
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : htc
ProdName : htc_asia_sea_wwe
ProdModel : HTC Desire 616 dual sim
Device : htc_v3_dug
AndroidVer: 4.2.2
MTKxCPU : MT6592
MTKxPRJ : SW_G98518A2_V019_M10_HTC_V3DUG_ASIA_MP
SECURITY :
IMEI_SW [1] : XXXXXXXXXXXXX
IMEI_SW [2] : XXXXXXXXXXXXX
BTMAC Addr : XXXXXXXXX
WiFi MAC : XXXXXXXXXXX
MODEM :
BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V21_P30_1_wg_n
EXTRA :
LCD [0] : hx8394a_hd720_dsi_vdo_tcl
LCD [1] : hx8394a_hd720_dsi_vdo_truly
LCD Res : 1280x720
TOUCH [0] : GT9XX
CAM [0] : ov8858_mipi_raw
CAM [1] : ov8858_mipi_raw_truly
CAM [2] : nt99252_yuv
CAM [3] : hi257_yuv
MODEM : wingtech92_wet_jb9_hspa_wt_pa_sky77593_band18_v3_a sia
LOCALE : ar_SA hy_AM bg_BG hr_HR en_US et_EE cs_CZ da_DK fi_FI el_GR iw_IL nb_NO fa_IR pl_PL pt_BR ro_RO sr_RS sk_SK sl_SI ca_ES ms_MY hi_IN hu_HU de_DE en_GB es_ES es_US fr_FR in_ID kk_KZ lv_LV lt_LT it_IT nl_NL pt_PT ru_RU sv_SE th_TH uk_UA tr_TR vi_VN zh_CN zh_TW zh_HK
Done!
Elapsed: 00:00:09
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 23 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:27
Old 10-25-2017, 08:47   #45742 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile J5 MT6737T FRP Reset Done With Great King Infinity CM2
Card found : S/N : A19EC787 , v0136
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D333238065300427BAFBDD6
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D42005306D6BDA37B
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395113EC3BA5B7C150883726A3B
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 10-25-2017, 08:51   #45743 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X30 MT6572 Pattren Read Done With King Of King Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_Pa , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A4834473261110111B651064243
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A4834473261110111B651064243
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F395D9416CDD530AE47A2570F4D1
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 3879
Done!
Elapsed: 00:00:20
Old 10-25-2017, 09:24   #45744 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
QMobile E1000 read factory firmware / format Done :)
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 32 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 72BCE49F206CC35CEE58C0BA5F67D344
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
File_Info   : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_E1000_V08_19052017.bin
FileVersion : QMobile_E1000_V08_19052017
Done!
Elapsed: 00:00:09
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 32 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Reading Flash Content now ...
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
[ScatCFG] : MT6261 / QMobile_E1000_V08_19052017 / NOR , SF
Firmware saved to : F:\1+Flashing Software\1+Infinity Box\CM2MTK\Read_out\HONGYU61M_11C_PCB01_gprs_MT6261_S00\
Done!
Elapsed: 00:00:16
Wait for phone...
Phone found! [ 32 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x003A5000-0x003FDFFF , LEN : 0x00059000
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:11
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 10-25-2017, 09:42   #45745 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X32 MT6580 FRP Reset Done With Great Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 90014A483847316505072B242A5133BB
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505072B242A5133BB
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F39582B00C33E5D790D6E6971E28
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:51
Old 10-25-2017, 10:07   #45746 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
KARBONN AURA 4G FRP REMOVE Done
SUCCESSFULLY REMOVE FRP LOCK(KARBONN AURA 4G)USB
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC983x] eMMC [Generic Android 6.x]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 36 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : Aura_4G
Model Brand : Karbonn
Model Device: Aura_4G
AndrVersion : 6.0
BaseBand CPU: AURA_4G
CompileDate : 2/23/2017 7:17:09 AM
Project Ver : Karbonn_Aura_4G_V12
Model Ext : Aura 4G
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:54
3. Insert cable
Phone found! [ 36 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:35
Old 10-25-2017, 10:15   #45747 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
MICROMAX D320 HANG ON LOGO Done
SUCCESSFULLY RECOVER HANG ON LOGO(MICROMAX D320)USB
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48344732611101C2C522703299
[eMMC] : FLASH_CID : 90014A48344732611101C2C522703299
DEV RID : 0xFD096D45BD5410608563BA632736F31B
SOC VERIFY : C1
Boot Ok!
Brand : Micromax
ProdName : D320
ProdModel : Micromax D320
Device : D320
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : D320
SECURITY :
WiFi MAC : XXXXXXX
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_1_wg_n
EXTRA :
LCD [0] : ili9806e_fwvga_dsi_vdo_s857_6572
LCD [1] : #ili9806e_wvga_dsi_vdo_s833_6572
LCD [2] : nt35510_dsi_vdo_s833_kdw_6572
LCD Res : 854x480
TOUCH [0] : ft6206_s857
CAM [0] : gc2145mipi_yuv
CAM [1] : gc0310_mipi_yuv
CAM [2] : #
CAM [3] : s5k4ecgx_mipi_yuv
CAM [4] : s5k8aayx_yuv
MODEM : s857_kk_hspa
LOCALE : es_ES es_US en_US cs_CZ sk_SK hr_HR sl_SI pl_PL hu_HU zh_CN ru_RU hi_IN ru_RU fr_FR es_ES bn_IN ar_EG fa_IR en_GB
Done!
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 23 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:39
Old 10-25-2017, 10:29   #45748 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
HTC D326G FLASH & RECOVER Done
SUCCESSFULLY FLASH AND RECOVER(HTC D326G)USB
Set mode to : SP SC77xx [Model Select]
Loading : 2PNTIMG_V01A_DUG_K44_SENSE53_MEA_1.79.401.1_RADIO_ W15.15_V01A.WG.N06.W10.G10_RELEASE.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC7730_UMS
PacVersion : 2PNTIMG_V01A_DUG_K44_SENSE53_MEA_1.79.401.1_RADIO_ W15.15_V01A.WG.N06.W10.G10_RELEASE
FastCheck : 0x0057E053A4
Loading files ...
File : fdl1.bin.signed
File : fdl2.bin.signed
File : wnvitem.bin
File : u-boot-spl-16k.bin.signed
File : wmodem.bin.signed
File : wdsp.bin.signed
File : boot.img.signed
File : recovery.img.signed
File : system.img
File : userdata.img
File : bootlogo.bmp
File : fbootlogo.bmp
File : prodnv.img
File : cache.img
File : cota.img
File : u-boot.bin.signed
File : SC7730_UMS_sec.xml
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : 2PNTIMG_V01A_DUG_K44_SENSE53_MEA_1.79.401.1_RADIO_ W15.15_V01A.WG.N06.W10.G10_RELEASE.pac
File : wnvitem.bin
File : system.img
File : userdata.img
File : bootlogo.bmp
File : prodnv.img
File : cache.img
File : cota.img
3. Insert cable
Phone found! [ 37 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : PMT Update skipped by user!
Flashing now
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k.bin.signed
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : wmodem.bin.signed
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : wdsp.bin.signed
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img.signed
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img.signed
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : bootlogo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : fbootlogo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:03:30
Old 10-25-2017, 10:55   #45749 (permalink)
NadeemSandhu1's Avatar
Member: 2077858
Thanks Meter: 128
MTN 5982C3 read flash done with CM2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10]
ID_BLOCK_S : 04E821B8
ID_BLOCK_I : 008110E1
ID_BLOCK_L : CD37ADA904929F8A752A2A2BF44FC707
ID_BLOCK_L : A3D27CCFC053FB088D682D9AE807113A
Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1
ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000
Boot Ok!
Brand : MTN
ProdName : MTN-TBW5982C3
ProdModel : MTN-TBW5982C3
Device : MTN-TBW5982C3
AndroidVer: 4.3
Manufact. : MTN
QLMxCPU : MSM8610
QLMxPRJ : TBW598213_9423_V016018
DevInfo : MSM8610__MTN__MTN__ANDR_v4.3__MTN-TBW5982C3__MTN-TBW5982C3__MTN-TBW5982C3__TBW598213_9423_V016018
[Read Ok] : deploy.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : fs_gc.img
[Read Ok] : splash.img
[Read Ok] : prjconfig.mbn
[Read Ok] : usbdisk.img
[Read Ok] : cdt.mbn
Android Info saved!
Read finished!
Configuration : MSM8x10 / eMMC
Firmware Size : 1907 MiB
Done!
Elapsed: 00:03:32
The Following 3 Users Say Thank You to NadeemSandhu1 For This Useful Post:
Old 10-25-2017, 11:03   #45750 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Enovo A1000 SPD7731 Logo Stuck Fix Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0136
Set mode to : SP [SC773x] eMMC [Android 5.x]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x]
3. Insert cable
Phone found! [ 23 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:19
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.70449 seconds with 10 queries
