09-14-2018, 14:48 | #53281 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile k150 illegal use done by cm2 Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
09-14-2018, 14:49 | #53282 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x75 reset frp done by cm2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513858534142064D4ED066A21B Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 150100513858534142064D4ED066A21B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB9E2EB77B7C623B764038703EFE70360 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
09-14-2018, 15:29 | #53283 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 232 | oppo a83 format and reed file done Operation : Reset Settings/Format FS [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : Oppo : F5,A83 | Manual : Disabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : UNKNOWN | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 1501005248363441420523DE9ABF353F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64AB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D1754678E2BCA8F53F19EFEA6796393 DA : USB : HIGH-SPEED Boot done! ERR : 0xC0010001 ERR : ERROR ERR : 0x08000000|0x0898E998 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! show error but set is ok format done Operation : Read Firmware [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : Oppo : F5,A83 | Manual : Disabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : UNKNOWN | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 1501005248363441420523DE9ABF353F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64AB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D1754678E2BCA8F53F19EFEA6796393 DA : USB : HIGH-SPEED Boot done! Patch Level : N6F26Q Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2018-07-05 Build Time : 1533203675 Product Manfct : OPPO Board Platform : mt6763 Product Model : OPPO A83js Product Brand : OPPO Product Name : A83js Product Device : M6763D Product Board : full_oppo6763_17101 Product Info : oppo6763_17101 SW Version : A.18 SW OTA Version : M6763D_11.A.18_0180_201808021611 SW OTA Name : A83jsEX_11_A.18_180802 Display ID : A83jsEX_11_A.18_180802 Kernel Info : 4.4.22-G201808021611 MT6763__OPPO__OPPO_A83js__7.1.1__A83jsEX_11_A.18_1 80802__N6F26Q__oppo6763_17101 Read : preloader.bin Read : recovery.img Read : oppo_custom.img Read : persist.img ExtSparse : Compression ratio : 100% Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : tz.img Read : system.img ExtSparse : Compression ratio : 6% Read : cache.img Read : userdata.img FW Size : 4.96 GB Android Info saved : _Android_info.txt Scatter : MT6763_Android_scatter.txt Saved to : MT6763__OPPO__OPPO_A83js__7.1.1__A83jsEX_11_A.18_1 80802__N6F26Q__oppo6763_17101\ Done! Elapsed: 00:09:32 |
09-14-2018, 15:37 | #53284 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Lava iris 50 MTK 6737M FRP Remove Done By CM2 Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847346132A54F89120F54E5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4G8 [eMMC] : FLASH_CID : 90014A483847346132A54F89120F54E5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x6D75BC63D49C51C4473432BB082C80CD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSNP Ok! LSSNG Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
09-14-2018, 15:38 | #53285 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Smile Q4 MTK 6580 Frimware Read Done By CM2 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : SMILE ProdName : Q4 ProdModel : Q4 Device : Q4 AndroidVer: 7.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_YUANDA6580.WE.L [Read Ok] : preloader_yuanda6580_we_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / yuanda6580_we_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1037 MiB Scatter saved to : E:\New folder (43)\MT6580__SMILE__Q4__Q4__7.1__ALPS.L1.MP6.V2_YU ANDA6580.WE.L\ All done! Done! Elapsed: 00:07:34 Reconnect Power/Cable! |
09-14-2018, 17:07 | #53286 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Tele2fon_V6 stuck on logo solved Tele2fon_V6 stuck on logo solved Card found : S/N : 07EDXXXX , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323734BB004297B3CFC2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200BB34C2CF9297 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x7FBB5333AF50ADB7F424151DEA66809A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TELE2 ProdName : Tele2fon_V6 ProdModel : Tele2fon_V6 Device : Android AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V1_BIRD6735M.35GU.A.L Done! Elapsed: 00:00:07 Reconnect Power/Cable! ------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323734BB004297B3CFC2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200BB34C2CF9297 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x7FBB5333AF50ADB7F424151DEA66809A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:38 Reconnect Power/Cable! ---------------------------------------------------------- Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : TELE2 ProdName : Tele2fon_V6 ProdModel : Tele2fon_V6 Device : Android AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V1_BIRD6735M.35GU.A.L [Read Ok] : preloader_bird6735m_35gu_a_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735M / V1.1.2 / bird6735m_35gu_a_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1385 MiB Scatter saved to : C:\Users\korisnik\Desktop\2tele2\MT6735__TELE2__Te le2fon_V6__Android__5.1__ALPS.L1.MP3.V1_BIRD6735M. 35GU.A.L\ All done! Done! Elapsed: 00:03:55 Reconnect Power/Cable! |
09-14-2018, 19:55 | #53287 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | World first tinno c800 8.0 read info backup sec and frp unlock Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : E2E1F947 ID_BLOCK_E : 00007705 ID_BLOCK_L : 3D5EF19BFDF6ACF58990B8BA589904EF ID_BLOCK_L : 39ED136215BB7331F63CA818A8C57D63 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Brand : TINNO ProdName : C800 ProdModel : C800 Device : C800 AndroidVer: 8.0.0 Manufact. : C800 SysPatch : OPR1.170623.032 DevComTime: 6/11/2018 10:11:09 AM QLMxPRJ : OPR1.170623.032 release-keys_20180611-1814 USERData : ENCRYPTED GCSec : EMPTY Done! Elapsed: 00:00:23 Reconnect Power/Cable! Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : E2E1F947 ID_BLOCK_E : 00007705 ID_BLOCK_L : 3D5EF19BFDF6ACF58990B8BA589904EF ID_BLOCK_L : 39ED136215BB7331F63CA818A8C57D63 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Backup Security Partitions Backup : FSG Backup : MODEMST1 Backup : MODEMST2 Backup saved to : C:\InfinityBox\CM2QLM\Backup\MSM8937_[0006B0E1]_E2E1F947_SEC\ Done! Elapsed: 00:00:54 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : E2E1F947 ID_BLOCK_E : 00007705 ID_BLOCK_L : 3D5EF19BFDF6ACF58990B8BA589904EF ID_BLOCK_L : 39ED136215BB7331F63CA818A8C57D63 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to bright hlatini For This Useful Post: |
09-15-2018, 05:26 | #53288 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | OALE X2 MT6580 Setting Not Show Fix Only Formate With Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : F40122426977696E20100001BC9EA4F7 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xF4 , OEM : 0122 [eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi [eMMC] : FLASH_CID : F40122426977696E20100001BC9EA4F7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395EFFA7CE0B4B891615A52C206 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:01:08 Reconnect Power/Cable! |
09-15-2018, 06:59 | #53289 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile k100 read code done Operation : Read User Code [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data... Can take some time User Code : 11122233 Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
09-15-2018, 07:08 | #53290 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Oale X1 touch not work just format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001005432323730380139D2FC0A34F1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80722 [eMMC] : FLASH_CID : 7001005432323730380139D2FC0A34F1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x0386520D15FBA10BC1843799557CD56D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
09-15-2018, 07:19 | #53291 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinity K MT6735 Network Lock Remove Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32314543170D42ADB8E3DA Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21E [eMMC] : FLASH_CID : 150100464531324D420D1743DAE374AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395E097D48204D01665DFF19614 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
09-15-2018, 07:35 | #53292 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Gfive G3310 SPD 2SCR Logo Stuck Fix Done With King Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.03 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR SPRD mode : SC6531 : REV : E000 : NOR Operation : Format FileSystem [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0A7 D271BEE5F_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
09-15-2018, 07:43 | #53293 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile I8i Blue Display Done Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
09-15-2018, 07:45 | #53294 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Infinix x5010 remove frp done With cm2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513832334D42001243EE2EC345 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42001243EE2EC345 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0386520D66E758AA15F5C8CD9E8B2D1D INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
09-15-2018, 07:51 | #53295 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | vgotel venture v8 write ff done Scatter Load Ok , BaseBand : MT6580 , Project : keytak6580_weg_l , Storage : EMMC Files found : 9 , Set to Flash : 8 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : VGOTEL Device Model : Venture V8 Device CPU : MT6580 Device IntName : Venture V8 Device Version : 5.1 Device Compile : 6/1/2016 7:01:39 AM Device Project : ALPS.L1.MP6.V2_KEYTAK6580.WEG.L_P22 Device ExtInfo : Venture V8 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 64 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100444C32303136019310743453C9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6102L [eMMC] : FLASH_CID : 450100444C32303136019310743453C9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x644765A70F6A0640B11BED134B60EF14 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : keytak6580_weg_l , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4142 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000003320000 Erase : 0x00000000050A0000-0x000000039DCE0000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0014 Update PMT by user request [SpecOp] : Extend UserArea Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:04:22 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:02 Update Mirror PMT [SpecOp] : Extend UserArea Update Done! Update RomInfo done Done! Elapsed: 00:04:38 Reconnect Power/Cable! |
