01-26-2019, 11:39 | #56536 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Oppo A37fw Formating Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 24BE24BE ID_BLOCK_L : CB3D57AF0E94818C7BD0202DEAB1C109 ID_BLOCK_L : 95E856F9FA65D55E734217CCC629C704 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:30 |
01-26-2019, 12:09 | #56537 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q Mobile X30 Flashing Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101A296D2BC2283 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101A296D2BC2283 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0CF2E6DE236B519B47A64D74DB71C6D4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3777 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:44 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:39 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:51 |
01-26-2019, 12:13 | #56538 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Rm1187 Flashing done Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1187_ROM_eMP_10.01.11 VIVA : RM-1187_VIVA_eMP_10.01.11 LANG : RM-1187_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1187_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1187_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 115 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : EB67EF0B83248CD21B0C600D5715A9BB BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.12.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 SecureDecrypt : RM-1187_ROM_eMP_10.01.11 SecureDecrypt : RM-1187_VIVA_eMP_10.01.11 SecureDecrypt : RM-1187_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1187_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1187_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : SUEZ.12.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1187_ROM_eMP_10.01.11 Write : RM-1187_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1187_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1187_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1187_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1187_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1187_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1187_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1187_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1187_VIVA_eMP_10.01.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:53 Reboot phone Ok |
01-26-2019, 12:33 | #56539 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Lenovo A319 MT6572 Hanging Probelam fix Only Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 197 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35585A4D4201EAD9D6D191D7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201EAD9D6D191D7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3950F93F5B6D073A98C0F64DDE2 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
01-26-2019, 13:02 | #56540 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lenovo a590 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D002A16730770E3 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C371543698E01F9C169BE2C23B5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! Reconnect Power/Cable! |
01-26-2019, 13:08 | #56541 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Rm1035 Flashing done Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_10.01.11 VIVA : RM-1035_VIVA_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 21 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F9601114CFEA11616FCC42953A3556C7 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.01.11 SecureDecrypt : RM-1035_VIVA_eMP_10.01.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.13.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:00:49 Reboot phone Ok |
01-26-2019, 13:12 | #56542 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i2 hang on logo done by cm2 Card found: S/N : 73CA70CC , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011F7FC000 State : 0x0001 Mount : /cache Size : 0x000000000FA00000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
01-26-2019, 13:19 | #56543 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo r9 reset pattern done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : D25FD0AE ID_BLOCK_I : 000460E1 ID_BLOCK_L : 677ABA3C6D0F681B96C435A407EE60C7 ID_BLOCK_L : F2B7CB2D56257C600928CC625F3692C0 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
01-26-2019, 13:28 | #56544 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgo tel v11 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513832334D4200A7D4AAB2C389 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200A7D4AAB2C389 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xE6C52A7DE77EE10F86DA65FBAF316B0B INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:01:11 Reconnect Power/Cable! |
01-26-2019, 13:34 | #56545 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Redmi note 5a reset pattern and frp done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : AD708E4A ID_BLOCK_L : C48D1E3C8087492CA53F89FC50C23A1D ID_BLOCK_L : 38C4BE15D8F3934B34974C3740B66227 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GD6BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
01-26-2019, 13:42 | #56546 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i7 hang on logo done by cm2 Card found: S/N : 73CA70CC , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000180000000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
01-26-2019, 13:53 | #56547 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x30 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110111274C64720D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110111274C64720D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3957571409220032B5484AE73B1 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3474 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:55 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:57 Reconnect Power/Cable! |
01-26-2019, 15:01 | #56548 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37Fw FRP QLM Reset Done With King Infinity CM2 Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 237413A9 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 3EC6BC5AF5616E99463BD53A055CD4F4 ID_BLOCK_L : 2F26E84334DF0F8439F4D9161C938DCE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
01-27-2019, 05:35 | #56549 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Lenovo A319 Flashing Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 45 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101BA574EF08281 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101BA574EF08281 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0CF2E6DEA757EE243CB13734D106A927 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3826 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin72_cwet_1a_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:25 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:00 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:44 |
01-27-2019, 06:27 | #56550 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q Mobile m350 pro farmating done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420DBFDE909C6405 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DBFDE909C6405 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0CF2E6DE4C00DD1E7E9FA63C19237A36 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:43 |
