03-08-2019, 16:05 | #57376 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX D321 AND:4.2.2 MT6572 READ NVRAM BAG BRUSH HANG ON LOGO Done THANKS INFINITY-BOX TEAM |
The Following 3 Users Say Thank You to gracy_elec For This Useful Post: |
03-08-2019, 16:21 | #57377 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | ONEPLUS ONE A0001 AND:6.0.1 SnapDragon 801 [MSM8974] BRUSH HANG ON LOGO Done SUCCESSFULLY BRUSH HANG ON LOGO(ONEPLUS ONE A0001 AND:6.0.1 SnapDragon 801 [MSM8974])USB THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
03-08-2019, 16:26 | #57378 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A37F AND:5.1.1 SnapDragon 410 [MSM8916] BRUSH PATTERN & FRP Done SUCCESSFULLY BRUSH PATTERN LOCK & FRP(OPPO A37F AND:5.1.1 SnapDragon 410 [MSM8916])USB THANKS INFINITY-BOX TEAM |
03-08-2019, 16:32 | #57379 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO Y53 AND:6.0.1 SnapDragon 425 [MSM8917] BRUSH PATTERN & FRP Done SUCCESSFULLY BRUSH PATTERN LOCK & FRP(VIVO Y53 AND:6.0.1 SnapDragon 425 [MSM8917])USB THANKS INFINITY-BOX TEAM |
03-08-2019, 17:03 | #57380 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | HTC 626ph Code: Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507ADA1A0228281 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507ADA1A0228281 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0A09E135485F5E7A59D3991487F0E4D8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : htc_asia_wwe , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3650 mV BL : BatteryLevel Ok Backup enabled! Backup saved : Backup\Flash\90014A48384731650507ADA1A0228281\ BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x00000000BA700000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0015 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : COTA Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:55 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : COTA Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:08 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:24 Reconnect Power/Cable! |
03-08-2019, 17:46 | #57381 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,215 | lenovo a319 Code: Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Start at : [3/8/2019 / 10:05:36 PM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101E9A5F45C92A3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101E9A5F45C92A3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0A09E135FE8752F66EEF7B6FDDEDF3CF INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3746 mV BL : BatteryLevel Ok Backup enabled! Backup saved : Backup\Flash\90014A48344732611101E9A5F45C92A3\ BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:42 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:20 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:37 Reconnect Power/Cable! |
03-09-2019, 05:33 | #57382 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Calme c331 reset password & backup flash done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : 359529064972974 IMEI[2] : 359529064972982 Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_048 4F0A2244F_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Read Flash [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Read Ok, 4194304 bytes Saved to : G:\CM2\SPRD_SPI_GIGADEVICE_GD25Q_4MiB.bin Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
03-09-2019, 05:39 | #57383 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile lt 100 hang on logo done by cm2 Card found: S/N : 73CA70CC , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC983x] eMMC [Generic Android 7.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000FF8F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
03-09-2019, 05:44 | #57384 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i6 metal one new reset frp done by cm2 Card found: S/N : 73CA70CC , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000117FF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
03-09-2019, 05:56 | #57385 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile j5 reset frp done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! Update configuration ... Update Ok! Load IDBase v123080 Ok! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100513832334D4200511FE48521B3 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832334D4200511FE485A3B3 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q823MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 49FF30181DFACBFA76ED326D218B1BC3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:46 Reconnect Power/Cable! |
03-09-2019, 06:09 | #57387 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i6i reset frp done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! Update configuration ... Update Ok! Load IDBase v123080 Ok! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D37324A65A90242BBA2A8C4 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464A32374D4202A965C4A8A2BB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ27MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 891E4B1364AC459B17627F0276634FAA STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : LMY47I Display ID : ALPS.L1.MP6.V2_TINNO6580.WE.L Ver. CodeName : REL Ver. Release : 5.1 Build Time : 1442853592 Product Model : QMobile i6i Product Brand : QMobile Product Name : QMobile i6i Product Device : QMobile Product Manfct : QMobile Board Platform : mt6580 Product Info : QMobile Product Model : i6i USERDATA : PLAIN ( NOT encrypted ) Done! Elapsed: 00:00:17 Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D37324A65A90242BBA2A8C4 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464A32374D4202A965C4A8A2BB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ27MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 891E4B1364AC459B17627F0276634FAA STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
03-09-2019, 06:19 | #57388 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgotel venture v8 reset frp done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! Update configuration ... Update Ok! Load IDBase v123080 Ok! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017045434148A2150141FF838121 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 7001004548414345410115A2218183FF EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A5000000 [ 14.58 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 32DA511C39B5EC401D8FEFB41918A50B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : VGOTEL-VentureV8-V11_20180309 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-01-05 Build Time : 1520564359 Product Model : Venture V8 Product Brand : VGOTEL Product Name : VentureV8 Product Device : VentureV8 Product Board : VentureV8 Product Manfct : VGOTEL Board Platform : mt6580 Product Info : keytak6580_weg_n USERDATA : PLAIN ( NOT encrypted ) Done! Elapsed: 00:00:21 Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017045434148A2150141FF838121 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 7001004548414345410115A2218183FF EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A5000000 [ 14.58 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 32DA511C39B5EC401D8FEFB41918A50B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
03-09-2019, 06:27 | #57389 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgotel venture 11 reset pattern & frp done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! Update configuration ... Update Ok! Load IDBase v123080 Ok! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM31) MODE : PRELOADER PORT PORT : 31 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D333238B06C0042FBB376E4 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832334D42006CB0E476B3FB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q823MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1C43AD709164F5C9C56E9F9914B9E6EF STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : MRA58K Display ID : VGOTEL_VENTURE_11_V07 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-09-01 Build Time : 1489571643 Product Model : VENTURE 11 Product Brand : VGOTEL Product Name : VENTURE_11 Product Device : VENTURE_11 Product Board : VGOTEL Product Manfct : VGOTEL Board Platform : mt6580 Product Info : VENTURE_11 USERDATA : PLAIN ( NOT encrypted ) Done! Elapsed: 00:00:16 Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM31) MODE : PRELOADER PORT PORT : 31 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D333238B06C0042FBB376E4 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832334D42006CB0E476B3FB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q823MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1C43AD709164F5C9C56E9F9914B9E6EF STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Read Firmware [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM31) MODE : PRELOADER PORT PORT : 31 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D333238B06C0042FBB376E4 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832334D42006CB0E476B3FB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q823MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1C43AD709164F5C9C56E9F9914B9E6EF STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : MRA58K Display ID : VGOTEL_VENTURE_11_V07 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-09-01 Build Time : 1489571643 Product Model : VENTURE 11 Product Brand : VGOTEL Product Name : VENTURE_11 Product Device : VENTURE_11 Product Board : VGOTEL Product Manfct : VGOTEL Board Platform : mt6580 Product Info : VENTURE_11 MT6580__VGOTEL__VENTURE_11__6.0__VGOTEL_VENTURE_11 _V07__MRA58K__VENTURE_11 SecureDevice : Plain Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : secro.img Read : system.img ExtSparse : Compression ratio : 7% Read : cache.img Read : userdata.img FW Size : 2.53 GB Android Info saved : _Android_info.txt Scatter : MT6580_Android_scatter.txt Saved to : G:\CM2\MT6580__VGOTEL__VENTURE_11__6.0__VGOTEL_VEN TURE_11_V07__MRA58K__VENTURE_11\ Done! Elapsed: 00:09:56 |
03-09-2019, 06:53 | #57390 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Gfive shine format done Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_076 779BC7444_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:29 |
