10-27-2010, 17:03 | #5911 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:AD03:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: T33+_TS70_TRIPLE_V010 Version: T33+_V1.0_HW detecting structure #2... 5 11 done 67 byte(s) read imei: *********** connection Ok building list... done items to clear: 163 warning: wrong packet cs warning: wrong packet cs items cleared: 163 of 163 items remains: 0 Finished, time used: 33 sec Remove/Install battery now ! |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-27-2010, 17:04 | #5912 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: " imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 355705007665503 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
10-27-2010, 17:04 | #5913 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | COM5 [VCP1] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:AD03:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: T33+_TS70_TRIPLE_V010 Version: T33+_V1.0_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 1 5 8 9 10 12 13 14 done 178 byte(s) read 166 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1122 Finished, time used: 20 sec Remove/Install battery now ! |
10-27-2010, 17:05 | #5914 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | COM2 [VCP2] selected module v1.78 Device: Zong-A136 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check parameters Done backup critical area ... reading eeprom-static... file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20101018-162026.B1E.bin loading data... data loaded reading eeprom-security... file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20101018-162026.B1E.bin reading eeprom-complete... file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20101018-162028.B1E.bin reading additional data... file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20101018-162031.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 30 sec Remove/Install battery now ! |
The Following User Says Thank You to c_ahmad79 For This Useful Post: |
10-27-2010, 17:07 | #5915 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | COM10 ready Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Software version: MT6223, E05" Software date: MAGCOMM23C Barcode: F96Z08AGv01.01b03 imei-1: 2000.00.00" imei-2: MT0123456789012 imei-3: " Finished, time used: 3 sec Remove/Install battery now ! |
10-27-2010, 17:08 | #5916 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 135790246811220 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 356404001182983 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
10-27-2010, 17:09 | #5917 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 363297002835653 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 350077803417306 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
10-27-2010, 17:09 | #5918 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 500039174745698 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 363297002835653 verification Ok Finished, time used: 5 sec Remove/Install battery now ! |
10-27-2010, 17:10 | #5919 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | ZTE A35 unlock COM4 [VCP5] selected module v1.73 Device: ZTE-A35 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: RID-P108A5V1.0.0B01 WARID-P108A5B01-En-PK01 g3dBV2.0 7 ,3 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20100908-204010.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20100908-204011.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20100908-204013.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_lock-area_20100908-204019.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 40 sec Remove/Install battery now ! |
The Following User Says Thank You to asad_nomy7 For This Useful Post: |
10-27-2010, 17:10 | #5920 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | COM10 ready Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 500039174745698 verification Ok Finished, time used: 7 sec Remove/Install battery now ! |
10-27-2010, 17:14 | #5921 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | Nokia 1661 sp-unlock done. Read phone info... Product - Mcu SW - V 03.70 14-04-09 RH-122 (c) Nokia Ppm SW - V 03.70 14-04-09 RH-122 (c) Nokia AD Prd.Code - 0584523 Bpr.Code - 0568809 Prod.Sn - HMD739703 Hw Vers - 1002 Uem - 1328 Upp - 8851 Rfic Ver - 0700 Dsp Vers - ICPR81_09w10_UPP Lcd Type - WIN:BOHAIv91 NT39121 Cam Prim - Imei - 356916033132843 Sl Conf - 262-07-00000000000 Sl Prof - 800000000003000-2 Sl Aux - 000B0000 Hw Sig - 6928BE6C78A31E6A Provider - O2 Deutschland (DCT3 Contract);Germany Lock info: Blok 1 L1 - Close; L2 - Close; L3 - Close; L4 - Open; L5 - Open; Blok 2 L1 - Open; L2 - Open; L3 - Open; L4 - Open; L5 - Open; Check phone mode... Phone already in Test mode, skip change... Read Lock Info Locked to O2 Deutschland (DCT3 Contract);Germany Connect to server... Unlocking... All done ! Phone disconnected Port COM4 close |
The Following User Says Thank You to shuric For This Useful Post: |
10-27-2010, 17:15 | #5922 (permalink) |
Member: 570093 Status: Offline Thanks Meter: 1,067 | Loading file v.02... C261_6.6.61_Main.34M.bin loaded Loading file v.02... C261_6.6.61_LPNA_En_Es_Pt.34P.bin loaded Loading file v.02... V176_6.6.61_Flex_90_63_NB09_10Net.34F.bin loaded Loading file v.02... C261_0.1.66_Main_E58S.34M.bin loaded Loading file v.02... C261_0[1].1.66_LP11_Arabic_Farsi_Urdu_Fr.34P.bin loaded COM4 [VCP1] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Skip: Flex Skip: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.1.66 HW version: MOTOROLA_E58S LP ver: LP11_0166 Flex ver: FLEX_90_64_3906 cpu id: 08B6 imei eeprom: 3594160039801352 required SW version: 0.1.66 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35941600398013_20100913-160502.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Write Done Finished, time used: 467 sec Remove/Install battery now ! |
10-27-2010, 17:19 | #5923 (permalink) |
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | Vodafone 225 phone lock reset done. COM3 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -DE-P108A2V1.0.0B03 12 27 46 VDF-P108A2B07-De-DE03 g3dBV2.0 04.1 Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20101007-173548.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20101007-173549.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20101007-173550.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 19 sec Remove/Install battery now ! |
10-27-2010, 17:19 | #5924 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 449281087134743 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 363297002407669 verification Ok Finished, time used: 5 sec Remove/Install battery now ! |
10-27-2010, 17:20 | #5925 (permalink) |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | chinese phone code COM9 [VCP0] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8B03:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: S7700_TS70_ROHM_1IMEI_V013 Version: S7700_V2.0_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35260403057712 connection Ok detecting structure #1... 1 5 8 9 10 12 13 14 done 178 byte(s) read 166 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 2842 Finished, time used: 11 sec Remove/Install battery now ! |
