02-23-2011, 06:31 | #9106 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Peshawar,Pakistan
Member: 1251758 Status: Offline Sonork: 100.1614930 Thanks Meter: 94 | Huawei-G7002 unlock by infinity.. module v3.73 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7002 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4103:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: G5.2EG01V02.11 Version: P2 67 byte(s) read imei: 356456031***** connection Ok 178 byte(s) read reading data... reading data #2... building new data... writing data... 166 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now |
The Following 2 Users Say Thank You to star1989 For This Useful Post: |
02-23-2011, 06:39 | #9107 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | Lg Gb 102 unlock Done With infinity box COM5 [VCP0] selected module v1.78 Device: LG-GB102 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20110222-055728.B1E.bin loading data... data loaded imei: 35347704449668800 reading eeprom-security_35347704449668800... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35347704449668800_20110222-055729.B1E.bin reading eeprom-complete_35347704449668800... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35347704449668800_20110222-055730.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 19 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to rafi_5217705 For This Useful Post: |
02-23-2011, 08:03 | #9108 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | vodafone 345 unlock done !! Code: COM63 [VCP1] selected module v3.75 Device: Vodafone-345 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5477:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 863 provider: V345X-2AVDGB1 customization: CM86FE21 customization: XM86FE21 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM86FE21 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00009921747205 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_20110223-122251.B0X.bin Finished, time used: 1 min 28 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Kmaxmax |
The Following 3 Users Say Thank You to kmaxmax For This Useful Post: |
02-23-2011, 08:14 | #9109 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Punjab INDIA
Member: 1021573 Status: Offline Sonork: 100.1622854 Thanks Meter: 55 | .....::::::successfully unlock vjazzc5589 with best cdma tool thanks a lot:::...... TODAY I GOT SUCCES AFTER A LOT TIME THANX INFINTY CDMA BEST TOOL THANX A LOTTTTTTTTTTTT HERE IS LOG ==== [2/23/2011 12:37:47 PM] ==== COM2 [VCP1] selected module v1.44 Device: Huawei-C5589 operation: SP-unlock Phone should be Switched ON ! connecting... downloading mode... wait conecting... sending command... patch in progress 20%... patch in progress 30%... patch in progress 40%... patch in progress 50%... patch in progress 60%... patch in progress 70%... patch in progress 80%... patch in progress 90%... patch in progress 100%... done... Finished, time used: 1 min 11 sec |
The Following 3 Users Say Thank You to themobileguy1 For This Useful Post: |
02-23-2011, 09:30 | #9110 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 6300 flashing done card found: S/N 0390:0118 registered to: jindalgsm4255 Connect phone on selected interface... Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm217__07.30.mcusw PPM : rm217__07.30.ppm_r CNT : rm217__07.30.image_ctv_cn Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 1060000F7B867A568B32B5DAF86878A3135CF796 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm217__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:08 Write : Processing rm217__07.30.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:20 MCU Write done ===Flashing [PPM]=== Erase : Processing rm217__07.30.ppm_r Found 1 areas to erase Erasing area 0x01080000 - 0x015FFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:21 Write : Processing rm217__07.30.ppm_r Total 329 [329/0/0] blocks to write, writing... TIME : Write time : 00:00:28 PPM Write done ===Flashing [CNT]=== Erase : Processing rm217__07.30.image_ctv_cn Found 1 areas to erase Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:44 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm217__07.30.image_ctv_cn ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Loader len: 248320, CHK: 36E3 ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Write : Processing rm217__07.30.image_ctv_cn_128 Total 296 [296/0/0] blocks to write, writing... TIME : Write time : 00:00:25 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6300 Software Info: V 07.30 07-05-09 RM-217 (c) Nokia. IMEI: 355714021018475 PPM version : V 07.30 07-05-09 RM-217 (c) Nokia. R Product code: 0515596 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:05:37 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to JINDALGSM™ For This Useful Post: |
02-23-2011, 09:37 | #9111 (permalink) |
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | nokia 5130 flashing done via f-bus cable Core version : 1.16 , Rev : 2.1 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1290010F8E2D7F56314FDFD9FD36B887F5EFEEF8 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 3552320************ CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\BB5 Dongle\BEST_v1.16\Backup\Cert\355232030*****.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1290010F8E2D7F56314FDFD9FD36B887F5EFEEF8 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 917F11196FDB7378C18EF7260698CA4489DCA02700 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:31 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.97.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1169 blocks TIME : Write time : 00:02:27 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.97.ppm_mena_a1 Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:36 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.97.ppm_mena_a1 Total writen 388 blocks TIME : Write time : 00:00:47 ConvertImage: Processing rm495__07.97.image_mena_a1_red ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm495__07.97.image_mena_a1_red Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:03:48 Transmission mode : Dual (Ddr, TX2) Write : Processing rm495__07.97.image_mena_a1_red Total writen 656 blocks TIME : Write time : 00:01:30 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5130 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 3552320******* Product code: 0571907 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Error write : Baltimore CyberTrust Mobile Root Writen 20 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... |
The Following 3 Users Say Thank You to rafi_5217705 For This Useful Post: |
02-23-2011, 09:40 | #9112 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | COM59 [VCP0] selected module v3.74 Device: Spice-S404N Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00300000/00100000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S404N__ffs... file saved: C:\Program Files\InfinityBox\MModule\Spice-S404N__ffs_20110223-140637.B0E.bin flash: EC22A000000000:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................ error: area 1 can not apply patch detecting parameters to apply patch area 2... ................ error: area 2 can not apply patch detecting parameters to apply patch area 3... ................ error: area 3 can not apply patch detecting parameters to apply patch area 4... ..... required data found flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: area 4 (pass 1) ........... area 4 patch applied Ok Special operation Done ====> Write ... flash: EC22A000000000:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 44 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post: |
02-23-2011, 09:43 | #9113 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 3110 c\s repair successfully card found: S/N 0390:0118 registered to: jindalgsm4255 Connect phone on selected interface... UFS S/N 103870 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 3110c Software ver : V 07.30 07-05-09 RM-237 (c) Nokia. IMEI : 356815025872962 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR61_08w10 APE Test: PPM : V 07.30 07-05-09 RM-237 (c) Nokia. C CNT : Content: c_tr_blue V 07.30 07-05-09 RM-237 (c) Nokia. Product SN : Product code : Base Prd.code: Module code : Long Prod.SN : Hardware info======= HWID : Retu : 32 Tahvo : 53 Batery: 4756 mV Camera: CMT BT: Error APE BT: APE HW: Error LCDVer: Error RF ic : Error Lock info =========== IMEI : 356815025872962 IMEI spNet : IMEI svNet : Conf key : 05FFFFFF02A80000 Provider key : 05FFFFFF00000000 Provider : Unknown Provider Counters : Key 7 [3] , Fbus 0 [10] Blocks : 111 LOCK STATUS : ============================= Error collect lock info, try again User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Local SX4 procedure started... Phone Imei: 356815025872962 Use custom key... Step 1... Step 2... SX4 Auth fail... Local SX4 procedure started... Phone Imei: 356815025872962 Use custom key... Step 1... Step 2... SX4 Auth fail... Local SX4 procedure started... Phone Imei: 356815025872962 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 0BB0001664937C56E9E800BD27DFC76C2E36B88E CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok Init Service mode... Wait... Key file updated... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Read Uniq key data started... Phone Imei: 356815025872962 Key file exists, no need to read... Done! Uploading RF/Battery tune to phone... Using : RM-237.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 25 write - Ok Record 29 write - Ok Record 34 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Record 22 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:05 Reading Phone Info.... Connected phone - Nokia 3110c Software ver : V 07.30 07-05-09 RM-237 (c) Nokia. IMEI : 356815025872962 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR61_08w10 APE Test: PPM : V 07.30 07-05-09 RM-237 (c) Nokia. C CNT : Content: c_tr_blue V 07.30 07-05-09 RM-237 (c) Nokia. Product SN : Product code : Base Prd.code: Module code : Long Prod.SN : Hardware info======= HWID : Retu : 32 Tahvo : 53 Batery: 4765 mV Camera: CMT BT: Error APE BT: APE HW: Error LCDVer: Error RF ic : Error Lock info =========== IMEI : 356815025872962 IMEI spNet : IMEI svNet : Conf key : 05FFFFFF02A80000 Provider key : 05FFFFFF00000000 Provider : Unknown Provider Counters : Key 7 [3] , Fbus 0 [10] Blocks : 111 LOCK STATUS : ============================= Error collect lock info, try again User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Backup Certificates now... Backup CRT308 CRT308 Backup Created... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 0BB0001664937C56E9E800BD27DFC76C2E36B88E CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 356815025872962 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\Documents and Settings\jindal\Desktop\best\Backup\Cert\356815025 872962.rpl Connect phone on selected interface... Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 0BB0001664937C56E9E800BD27DFC76C2E36B88E CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL phone detected Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 3110c Software ver : V 07.30 07-05-09 RM-237 (c) Nokia. IMEI : 356815025872962 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR61_08w10 APE Test: PPM : V 07.30 07-05-09 RM-237 (c) Nokia. C CNT : Content: c_tr_blue V 07.30 07-05-09 RM-237 (c) Nokia. Product SN : Product code : Base Prd.code: Module code : Long Prod.SN : Hardware info======= HWID : Retu : 32 Tahvo : 53 Batery: 4759 mV Camera: CMT BT: Error APE BT: APE HW: Error LCDVer: Error RF ic : Error Lock info =========== IMEI : 356815025872962 IMEI spNet : IMEI svNet : Conf key : 05FFFFFF02A80000 Provider key : 05FFFFFF00000000 Provider : Unknown Provider Counters : Key 7 [3] , Fbus 0 [10] Blocks : 111 LOCK STATUS : ============================= Error collect lock info, try again User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Operating mode is OK, no need change... Field 1 Record 0 write - Error Record 2 write - Error Record 4 write - Error Record 6 write - Error Record 8 write - Error Record 13 write - Error Record 16 write - Error Record 18 write - Error Record 20 write - Error Record 25 write - Error Record 29 write - Error Record 34 write - Error Field 309 Record 0 write - Error Record 1 write - Error Record 2 write - Error Record 4 write - Error Record 5 write - Error Record 7 write - Error Record 8 write - Error Record 17 write - Error Record 22 write - Error Done! Elapsed: 00:00:00 Local SX4 procedure started... Phone Imei: 356815025872962 Key file exists, no need to read... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 25 write - Ok Record 29 write - Ok Record 34 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Record 22 write - Ok Done! Elapsed: 00:00:01 Reading Phone Info.... Connected phone - Nokia 3110c Software ver : V 07.30 07-05-09 RM-237 (c) Nokia. IMEI : 356815025872962 Ape Ver : Error APE Var : APE ADSP: DSP Ver : ICPR61_08w10 APE Test: PPM : V 07.30 07-05-09 RM-237 (c) Nokia. C CNT : Content: c_tr_blue V 07.30 07-05-09 RM-237 (c) Nokia. Product SN : Product code : Base Prd.code: Module code : Long Prod.SN : Hardware info======= HWID : Retu : 32 Tahvo : 53 Batery: 4759 mV Camera: CMT BT: 06cc-P9.1 APE BT: APE HW: LCDVer: RF ic : 17211721 Lock info =========== IMEI : 356815025872962 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! |
02-23-2011, 09:46 | #9114 (permalink) |
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | Nokia 3120c Flash via usb Connect phone on selected interface... Core version : 1.16 , Rev : 2.1 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm364__10.00.mcusw PPM : rm364__10.00.ppm_i CNT : rm365__10.00_ISM_012.image_i_ru_deep_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 16A0000B86900254AD12D2C69A6B8786AF0A43E0 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm364__10.00.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:16 Write : Processing rm364__10.00.mcusw Total 112 [112/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:33 MCU Write done ===Flashing [PPM]=== Erase : Processing rm364__10.00.ppm_i Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:20 Write : Processing rm364__10.00.ppm_i Total 25 [25/0/0] blocks to write, writing... TIME : Write time : 00:00:30 PPM Write done ===Flashing [CNT]=== Erase : Processing rm365__10.00_ISM_012.image_i_ru_deep_red Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:33 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm365__10.00_ISM_012.image_i_ru_deep_red Total 38 [38/0/0] blocks to write, writing... TIME : Write time : 00:00:42 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:56 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3120 classic Software Info: V 10.00 06-03-09 RM-364 (c) Nokia IMEI: 353101*********** PPM version : V 10.00 06-03-09 RM-364 (c) Nokia I Product code: 0560889 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:07:33 |
02-23-2011, 10:19 | #9115 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | 7210s successfull card found: S/N 000000:000000 registered to: PAUL-TELECOME Connect phone on selected interface... UFS S/N 000000 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 147000070F997D56205790AFF20F8E857C91EB7C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... Init Service Mode Failed, can't proceed checking... Connect phone on selected interface... Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_c CNT : rm436__07.23.image_c_de Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 147000070F997D56205790AFF20F8E857C91EB7C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 0 byte(s) CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) No any CRT data (MCU damaged/CERT erased), skip saving Init Service mode... Wait... Init Service Mode Failed! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 147000070F997D56205790AFF20F8E857C91EB7C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0119FFFF CMT , NOR , Area : 0x011A0000 - 0x0133FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:04 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1161 blocks TIME : Write time : 00:02:11 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01340000 - 0x01BDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:02 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.ppm_c Total writen 448 blocks TIME : Write time : 00:00:49 ConvertImage: Processing rm436__07.23.image_c_de ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.image_c_de Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01BE0000 - 0x01F7FFFF CMT , NOR , Area : 0x01F80000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:08 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.image_c_de Total writen 1424 blocks TIME : Write time : 00:02:37 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 12345610654321? Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... NPC Data found! CCC Data found! HWC Data found! SimLock Data found! SimLock key found! SuperDongle Key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 147000070F997D56205790AFF20F8E857C91EB7C CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... CMT : NPC erase Ok Writing NPC... Ok CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Init Service mode... Wait... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Data... Ok Writing SimLock Key... Ok Writing Super Dongle Key... Ok SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software ver : V 07.23 17-07-09 RM-436 (c) Nokia IMEI : 351962039604000 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w17 APE Test: PPM : V 07.23 17-07-09 RM-436 (c) Nokia C CNT : Content: c_de V 07.23 17-07-09 RM-436 (c) Nokia Product SN : 0 Product code : Base Prd.code: Module code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 15 Tahvo : 22 Batery: 4733 mV Camera: CMT BT: 2222-143C APE BT: APE HW: LCDVer: SHARP RF ic : 064c0601 Lock info =========== IMEI : 351962039604000 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : not set MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
The Following 3 Users Say Thank You to niloy2007 For This Useful Post: |
02-23-2011, 10:36 | #9116 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | 7210s successfull by best again..... card found: S/N 00000:00000 registered to: PAUL-TELECOME Connect phone on selected interface... UFS S/N 000000 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 157002033FEF7D563F1D2A89FC68D1B49F15E31D CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... Init Service Mode Failed, can't proceed checking... Connect phone on selected interface... Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_c CNT : rm436__07.23.image_c_de Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 157002033FEF7D563F1D2A89FC68D1B49F15E31D CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 0 byte(s) CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) No any CRT data (MCU damaged/CERT erased), skip saving Init Service mode... Wait... Init Service Mode Failed! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 157002033FEF7D563F1D2A89FC68D1B49F15E31D CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0119FFFF CMT , NOR , Area : 0x011A0000 - 0x0133FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:04 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.mcusw Error, 03, DataMissMatch, Check Cable, FlashPack, Firmware Error write block at : 1 ERR : C7012D0103CD000010000000 Error on Flashing Phone! Error... Connect phone on selected interface... Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_c CNT : rm436__07.23.image_c_de Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 157002033FEF7D563F1D2A89FC68D1B49F15E31D CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 0 byte(s) CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) No any CRT data (MCU damaged/CERT erased), skip saving Init Service mode... Wait... Init Service Mode Failed! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 157002033FEF7D563F1D2A89FC68D1B49F15E31D CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0119FFFF CMT , NOR , Area : 0x011A0000 - 0x0133FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:05 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1161 blocks TIME : Write time : 00:02:12 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01340000 - 0x01BDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:02 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.ppm_c Total writen 448 blocks TIME : Write time : 00:00:49 ConvertImage: Processing rm436__07.23.image_c_de ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.image_c_de Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01BE0000 - 0x01F7FFFF CMT , NOR , Area : 0x01F80000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:08 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.image_c_de Total writen 1424 blocks TIME : Write time : 00:02:39 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 12345610654321? Product code: 0572571 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... NPC Data found! CCC Data found! HWC Data found! SimLock Data found! SimLock key found! SuperDongle Key found! CMLA key found! WMDRM key found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 157002033FEF7D563F1D2A89FC68D1B49F15E31D CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... CMT : NPC erase Ok Writing NPC... Ok CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Init Service mode... Wait... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Data... Ok Writing SimLock Key... Ok Writing Super Dongle Key... Ok SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software ver : V 07.23 17-07-09 RM-436 (c) Nokia IMEI : 353180039807592 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w17 APE Test: PPM : V 07.23 17-07-09 RM-436 (c) Nokia C CNT : Content: c_de V 07.23 17-07-09 RM-436 (c) Nokia Product SN : DAQ208372 Product code : 0572571 Base Prd.code: 0563951 Module code : 0203868 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : 15 Tahvo : 22 Batery: 4852 mV Camera: CMT BT: 2222-143C APE BT: APE HW: LCDVer: SHARP RF ic : 06540601 Lock info =========== IMEI : 353180039807592 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : not set MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
02-23-2011, 10:38 | #9117 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM25 [VCP4] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F16EDE3 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E553_XZY4ARVTFPA.00.0_26S01 Version: M500Z_05C_HW detecting structure #2... done 60 byte(s) read imei: 35711100006226 connection Ok building list... done items to clear: 221 warning: wrong packet cs items cleared: 221 of 221 items remains: 0 Finished, time used: 1 min 20 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to cel_phon For This Useful Post: |
02-23-2011, 10:43 | #9118 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Nokia 6303i classic Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm638__09.83.mcusw PPM : rm638__09.83.ppm_meac CNT : rm638__09.83.image_meac_0594513_008 Flashing phone now... Check files done... -> Check SW version... FlashFile version : 09.83 Phone version : 09.83 21-09-10 RM-638 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created... Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600000001020C192102054100 EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 2120031617085640A5A22D1615534A0DD16F001F ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 10.50.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 10.50.0 Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 356235042273393 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\BEST-INFINITY\Backup\Cert\356235042273393.rpl ===Flashing [MCU]=== Erase : Processing rm638__09.83.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__09.83.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 126 blocks TIME : Write time : 00:00:37 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm638__09.83.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__09.83.ppm_meac Total writen 23 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm638__09.83.image_meac_0594513_008 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm638__09.83.image_meac_0594513_008 Total writen 99 blocks TIME : Write time : 00:00:34 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:22 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303i classic Software Info: V 09.83 21-09-10 RM-638 (c) Nokia IMEI: 356235042273393 PPM version : V 09.83 21-09-10 RM-638 (c) Nokia MEC Product code: 0594518 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:01:52 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! |
The Following 3 Users Say Thank You to sirnavid2010 For This Useful Post: |
02-23-2011, 10:49 | #9119 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Lg-ts3520-mts -successfull ==== [2/23/2011 3:14:23 PM] ==== COM25 [LGSIDIAG1] selected module v1.45 Device: LG-3520 operation: SP-unlock Phone should be Switched ON ! connecting... TS352F09Jul 23 2010 LG RD-3520 version 9 selected.. offline.. downloading mode.. sending boot.. patching in progress.. patching in progress 50%.. patching in progress 100%.. Done.. Finished, time used: 33 sec |
The Following 2 Users Say Thank You to niloy2007 For This Useful Post: |
02-23-2011, 10:49 | #9120 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Nokia 5700 RM-230 (c) Nokia flash done by best Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm230_04.21_prd_core.fpsx PPM : rm230_04.21_prd_v21_01_mea_b.fpsx CNT : rm230_04.21_prd_uda_erase.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 04.21 Phone version : 03.27 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created... Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101011103 EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0F0002114E4E0058CC6DCD40555FF9CC413DA73D ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: F2C6EBADC86E6189 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing UPDAPP... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm230_04.21_prd_core.fpsx Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x052FFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing rm230_04.21_prd_core.fpsx Total 400 [400/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:00:59 MCU Write done ===Flashing [PPM]=== Erase : Processing rm230_04.21_prd_v21_01_mea_b.fpsx Found 1 areas to erase Erasing area 0x03500000 - 0x052FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm230_04.21_prd_v21_01_mea_b.fpsx Total 222 [222/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:38 PPM Write done ===Flashing [CNT]=== Erase : Processing rm230_04.21_prd_uda_erase.fpsx Found 1 areas to erase Erasing area 0x05300000 - 0x07B3FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm230_04.21_prd_uda_erase.fpsx No any data for write, skip write CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:38 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5700 Software Info: V 04.21 04-10-07 RM-230 (c) Nokia IMEI: 353964010975266 Ape Version: 04.21 Product code: 0515736 Checking... SimLock status : Can't get status Security status : Security is Ok Read Info Done! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:02:09 Connect phone on selected interface... |
