04-30-2011, 11:32 | #11521 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | registered to: xerraco Connect phone on selected interface... Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_t CNT : rm495__07.97.image_t_ph_blu Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 19B000095CBC7E5634BDFED7328F2D0F833709CF CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:26 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:03 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_t Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:55 Write : Processing rm495__07.97.ppm_t Total 475 [475/0/0] blocks to write, writing... TIME : Write time : 00:00:24 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97.image_t_ph_blu Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:04 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.97.image_t_ph_blu Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:34 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 355212032889463 PPM version : V 07.97 13-09-10 RM-495 (c) Nokia T Product code: 0571943 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:11:08 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone already in Test mode, skip change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:01 Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to xerraco For This Useful Post: |
04-30-2011, 12:11 | #11522 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM6 [VCP0] selected module v1.38 Device: LG-F2250 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 356560000168396 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356560000168396_LG-F2250_20110430-160941.B1E.bin .. Check flash Done Check space ... current eeprom imei: 356560000168396 ........................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 42 sec Remove/Install battery now ! |
The Following User Says Thank You to abdulwajid147 For This Useful Post: |
04-30-2011, 12:25 | #11523 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Zambia
Member: 703394 Status: Offline Thanks Meter: 47 | Nokia 6300 Restarting Successfully Flashed card found: S/N xxxxxxx registered to: dkaluba74 Connect phone on selected interface... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm217__07.21.mcusw PPM : rm217__07.21.ppm_a CNT : rm217__07.21.image_a Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 08000110DE510058DCECC80D7DF04E8B4AACC694 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm217__07.21.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:41 Write : Processing rm217__07.21.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:52 MCU Write done ===Flashing [PPM]=== Erase : Processing rm217__07.21.ppm_a Found 1 areas to erase Erasing area 0x01080000 - 0x015FFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:27 Write : Processing rm217__07.21.ppm_a Total 273 [273/0/0] blocks to write, writing... TIME : Write time : 00:00:33 PPM Write done ADL : End flashing Flashing done! Total flash time : 00:04:35 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6300 Software Info: V 07.21 05-11-08 RM-217 (c) Nokia. IMEI: 356401017419284 PPM version : V 07.21 05-11-08 RM-217 (c) Nokia. A Product code: 0547951 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 10 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:05:51 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok BackUp UserData : [PhoneBook] Generation mode : [S40] Phonebook not found or clear... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm217__07.21.image_a Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created... -> MMC pass Record found, saving... Getting product info... RAP_BOOT: 0901010002010000 RAP_PUBLIC: 08000110DE510058DCECC80D7DF04E8B4AACC694 CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Checking CNT sector PN<>FL PN CNT sector : 64 kb Loader len: 248320, CHK: 3714 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm217__07.21.image_a Found 1 areas to erase Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:04 Write : Processing rm217__07.21.image_a Total 220 [220/0/0] blocks to write, writing... TIME : Write time : 00:00:25 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:01:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6300 Software Info: V 07.21 05-11-08 RM-217 (c) Nokia. IMEI: 356401017419284 PPM version : V 07.21 05-11-08 RM-217 (c) Nokia. A Product code: 0547951 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:01:57 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Last edited by dkaluba74; 04-30-2011 at 12:27. Reason: Removing serial number |
The Following User Says Thank You to dkaluba74 For This Useful Post: |
04-30-2011, 12:30 | #11524 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | huwaei g3610 unlock done Quote:
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
04-30-2011, 12:31 | #11525 (permalink) | |
04-30-2011, 12:32 | #11526 (permalink) | |
Member: 171512 Status: Offline Thanks Meter: 1,034 | g3610 agian unlock thanks Quote:
04-30-2011, 12:41 | #11527 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM16 [Serial2] selected Action: unlock Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 2.5.78.N. HW version: _E88 imei otp: 358612006697734 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_35 8612006697734_20110430-171107.18E.bin imei eeprom: 358612006697734 extra method pass-1... reading ... extra method pass-2... Check Flash-2 Done Write... Write Done Finished, time used: 30 sec Remove/Install battery now ! |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
04-30-2011, 13:43 | #11528 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 3600s flashing done card found: S/N 0390:0118 registered to: jindalgsm4255 Connect phone on selected interface... Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM223_22.0.002_prd.C00 PPM : RM223_22.0.002_prd_1401.V14 CNT : RM223_22.0.002_004_000_U03_uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101021103 CPU ID : RAPIDO v11 , Features : Dead-Test EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 20100112E87D0058B161311378D11B8B961F3051 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: A8C1D6713E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! TIME : Boot time : 00:00:30 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM223_22.0.002_prd.C00 Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x05F7FFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partition erase not allowed by loader Partitioning : Ok [6] TIME : Erase time : 00:00:01 Write : Processing RM223_22.0.002_prd.C00 Total 421 [421/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:01 MCU Write done ===Flashing [PPM]=== Erase : Processing RM223_22.0.002_prd_1401.V14 Found 1 areas to erase Erasing area 0x03730000 - 0x05F7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM223_22.0.002_prd_1401.V14 Total 273 [273/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:46 PPM Write done ===Flashing [CNT]=== Erase : Processing RM223_22.0.002_004_000_U03_uda.fpsx Found 1 areas to erase Erasing area 0x05F80000 - 0x079DFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM223_22.0.002_004_000_U03_uda.fpsx Total 1 [1/0/0] blocks to write, writing... TIME : Write time : 00:00:00 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:50 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N81 Software Info: V 06wk41v62.5 11-05-09 RM-223 (c) Nokia IMEI: 356994011578618 Ape Version: 22.0.002 Product code: 0558082 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:02:51 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post: |
04-30-2011, 13:55 | #11529 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Code: Files Set for Flashing : MCU : rm240__10.00.mcusw PPM : rm240__10.00.ppm_i CNT : rm240__10.00_ISM_006.image_i_ru_brown Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006010C192101003000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 22F0010F747E0254DE59EAB2EE2714B8463CEAEF CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! ===Flashing [MCU]=== Erase : Processing rm240__10.00.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:54 Write : Processing rm240__10.00.mcusw Total 1316 [1316/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:02:06 MCU Write done ===Flashing [PPM]=== Erase : Processing rm240__10.00.ppm_i Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:38 Write : Processing rm240__10.00.ppm_i Total 404 [404/0/0] blocks to write, writing... TIME : Write time : 00:00:41 PPM Write done ===Flashing [CNT]=== Erase : Processing rm240__10.00_ISM_006.image_i_ru_brown Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:32 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm240__10.00_ISM_006.image_i_ru_brown Total 728 [728/0/0] blocks to write, writing... TIME : Write time : 00:01:04 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:59 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6500s-1 Software Info: V 10.00 06-03-09 RM-240 (c) Nokia IMEI: 353076029077503 PPM version : V 10.00 06-03-09 RM-240 (c) Nokia I Product code: 0556236 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:11:42 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to nadirghazi For This Useful Post: |
04-30-2011, 14:32 | #11530 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm561__09.95.mcusw PPM : rm561__09.95.ppm_mena_b CNT : rm561__09.95.image_mena_b_red Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.20\BEST\Backup\Cert\358241032779918_S IM.rpl -> MMC pass Record found, saving... Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1680010AA6A36350EC4448FBA79840CD4A23FB08 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 3EA22A1DDA660002E56108DB5072A10F8709443F Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm561__09.95.image_mena_b_red ConvertImage: Page Size is 128K, no need convert Loader len: 308032, CHK: FFA3 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm561__09.95.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:00 Write : Processing rm561__09.95.mcusw Total 1256 [1256/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:01 MCU Write done ===Flashing [PPM]=== Erase : Processing rm561__09.95.ppm_mena_b Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:54 Write : Processing rm561__09.95.ppm_mena_b Total 353 [353/0/0] blocks to write, writing... TIME : Write time : 00:00:17 PPM Write done ===Flashing [CNT]=== Erase : Processing rm561__09.95.image_mena_b_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:51 Write : Processing rm561__09.95.image_mena_b_red Total 528 [528/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:33 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.95 02-04-10 RM-561 (c) Nokia IMEI: 358241032779918 PPM version : V 09.95 02-04-10 RM-561 (c) Nokia MEN Product code: 0589277 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:10:16 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! |
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post: |
04-30-2011, 15:15 | #11531 (permalink) |
No Life Poster Join Date: Oct 2005 Location: QQ id 2593032292
Member: 189673 Status: Offline Sonork: 100.1592062 Thanks Meter: 351 | registered to: wc2sime Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Format File System... Check phone mode... Phone in RfInactive mode Seting Local mode... wait... Local mode set Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! Reading LifeTimer data... LifeTime is: 1624979 seconds Phone works: 451 Hours; 22 minutes; 59 seconds Done Resetting life Timer... Reset Done! Done Reading User code... User Code is: 12345 Done! Resetting User Code to default (12345)... Clear data : Ok Result: 12345 Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:17 Set phone in Normal mode... Restarting... Done! Phone disconected! |
The Following 2 Users Say Thank You to sameera For This Useful Post: |
04-30-2011, 15:15 | #11532 (permalink) |
Member: 189673 Status: Offline Sonork: 100.1592062 Thanks Meter: 351 | Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0B90001134B14950C36B0F53E713C8820C01BED6 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:00 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:20 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mena_a1 Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:49 Write : Processing rm495__07.97.ppm_mena_a1 Total 388 [388/0/0] blocks to write, writing... TIME : Write time : 00:00:27 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:24 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:44 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:08:46 Reboot phone now... Afterflash not selected, skip Done! Elapsed: 00:09:07 Connect phone on selected interface... |
04-30-2011, 15:47 | #11533 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Connect phone on selected interface... Read and Check phone data... Infineon checking... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 PBL : SE0_091125 F11 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC000000542200 FLASH ID : Samsung, K8S6415E Boot Done! Done! Connect phone on selected interface... Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Manual Files Set for Flashing : PPM : rh125_003.61ia Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 PBL : SE0_091125 F11 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC000000542200 FLASH ID : Samsung, K8S6415E Boot Done! ===Flashing [PPM]=== File : rh125_003.61ia Image : hw_f11_rh125_003.61ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x001FA700 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001FA700 Flashing , wait ... Region flash done Check : 5586 Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 03.61 29-01-10 RH-125 (c) Nokia IMEI : 352017044772703 PCode : 0588617 All done! Connect phone on selected interface... |
04-30-2011, 15:50 | #11534 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | c5 revive again , report ok Code: Core version : 1.20 , Rev : 4.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm645_062.001_prd.core.fpsx PPM : rm645_062.001_11.01_MEA_C_prd.rofs2.fpsx PPM2 : rm645_062.001_C00.01_DEFAULT_prd.rofs3.fpsx CNT : RM645_ENO_10wk48v0.001.fpsx APE : rm645_062.001_U000.000_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0850010929A00344B757F88BDF4E3E13225E23BB ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.10.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.10.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 35379204151***** Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\3537920415*****CRT_2nd.rpl ===Flashing [MCU]=== Erase : Processing rm645_062.001_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_062.001_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 394 blocks TIME : Write time : 00:00:13 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm645_062.001_11.01_MEA_C_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_062.001_11.01_MEA_C_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 159 blocks TIME : Write time : 00:00:05 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm645_062.001_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_062.001_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing RM645_ENO_10wk48v0.001.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM645_ENO_10wk48v0.001.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 10 blocks TIME : Write time : 00:00:00 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000001 / 00000000 ===Flashing [APE]=== Erase : Processing rm645_062.001_U000.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_062.001_U000.000_prd.uda.fpsx Total writen 6 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000002 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000020000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:22 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C5-00 Software Info: V ICPR82_10w34.4 09-12-10 RM-645 (c) Nokia IMEI: 3537920415***** Ape Version: 062.001 Product code: 0592677 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:00:37 Connect phone on selected interface... |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
04-30-2011, 16:42 | #11535 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm495__06.65.image_em_red Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.20\BEST\Backup\Cert\355232035794403_S IM.rpl Batery valtage : 3793 mV -> Batery voltage less, than 3,8V (3793mV). Continue at user risk Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1DD00003F6B17D56D20E55FB8D81514E27912562 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm495__06.65.image_em_red ConvertImage: Page Size is 128K, no need convert Loader len: 302784, CHK: F334 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm495__06.65.image_em_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:44 Write : Processing rm495__06.65.image_em_red Total 696 [696/0/0] blocks to write, writing... TIME : Write time : 00:00:36 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:21 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 06.65 01-04-09 RM-495 (c) Nokia IMEI: 355232035794403 PPM version : V 06.65 01-04-09 RM-495 (c) Nokia MEN Product code: 0571593 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:05:11 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
