08-09-2011, 14:19 | #13726 (permalink) |
Junior Member Join Date: Aug 2011 Location: saigonmobile/ zopo/ hoianclub
Member: 1631784 Status: Offline Sonork: 12345 Thanks Meter: 12 | COM2 [Serial0] selected module v1.27 Device: Huawei-C2806 Action: "sp-unlock" Phone should be Switched ON ! connecting... checking version... C2806C02B103 C2806C02B103 Huawei C2806 version B103 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 25%... patching in progress 50%... patching in progress 75%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 53 sec |
The Following User Says Thank You to GIALAI_GSM For This Useful Post: |
08-09-2011, 14:19 | #13727 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Marocunlocking™
Member: 248858 Status: Offline Sonork: 100.1608346 Thanks Meter: 216 | COM17 [VCP0] selected module v3.62 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2FY01V01.09 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003560194 connection Ok 189 byte(s) read reading data... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 42 sec Remove/Install battery now ! |
The Following User Says Thank You to pikiche For This Useful Post: |
08-09-2011, 15:45 | #13728 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Bangladesh
Member: 715924 Status: Offline Sonork: 100.1662616 Thanks Meter: 83 | card found: S/N 44444444444 registered to: muktadirma Connect phone on selected interface... UFS S/N 93206 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 3952D3D6A73DA5B9988E82F3525BEFF9F2926340 APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 07600006557146512C93ACD6151EEF85F5A79B6C CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC1 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00360098 , APE , APE Flash ID : 00360098 < UNKNOW [NOT IN BASE] ReqAlgo : APE , OMAP1610 GBBM-1.8.1 ALG FLCNT : 01010000020000000600000000000000000000 Sending ALGO.... Use : h3_sam_nand_gbbm.fg , Rev : 0.0 Ver : 1.33.0 APE Algo sent APE PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC0 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 353125022078396 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) APE : Read NPC certificate... Cert size : 0 byte(s) APE : Read CCC certificate... Cert size : 0 byte(s) APE : Read HWC certificate... Cert size : 0 byte(s) APE : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... VARIANT Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\353125022078396_CR T.rpl Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok BackUp UserData : [PhoneBook] Generation mode : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... FS run fail, please, remove SD card first Change phone mode manualy to local/test and try again If still no luck - phone have damaged FS/SD-MMC part.. BackUp UserData : [PhoneBook] Generation mode : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... Fsrun OK... Detect Symbian OS Generation... Detected: [Symbian OS 8.X] Phone! Running : APE_TEST_SERVER,w31_05,(c)NMP Found! Will read 30 blocks... csv file save to C:\InfinityBox\BEST\RM-84 Nokia N70_353125022078396.csv 62 vcf files saved to c:\InfinityBox\BEST\Phones_Data\353125022078396\VC F\ File saved to : C:\InfinityBox\BEST\RM-84 Nokia N70_353125022078396.Bs60pb Read done Done... Core version : 1.25 Rev : 1.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : RM84_51003301.C0 PPM : RM84_51003301.V25 Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 3952D3D6A73DA5B9988E82F3525BEFF9F2926340 APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 07600006557146512C93ACD6151EEF85F5A79B6C CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC1 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00360098 , APE , APE Flash ID : 00360098 < UNKNOW [NOT IN BASE] ReqAlgo : APE , OMAP1610 GBBM-1.8.1 ALG LăąFLCNT : 01010000020000000600000000000000000000 Sending ALGO.... Use : h3_sam_nand_gbbm.fg , Rev : 0.0 Ver : 1.33.0 APE Algo sent APE PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC0 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_51003301.C0 Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0052B60D CMT , NOR , Area : 0x006A0000 - 0x006BFFFF CMT , NOR , Area : 0x006DF000 - 0x006EFFFF CMT , NOR , Area : 0x00700000 - 0x007EFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0000FFFF APE , NAND , Area : 0x00010000 - 0x0001FFFF APE , NAND , Area : 0x00020000 - 0x000203FF APE , NAND , Area : 0x00050000 - 0x03ECFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:45 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_51003301.C0 CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [SOS*CORE] Total writen 1122 blocks TIME : Write time : 00:03:17 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_51003301.V25 Found 2 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x01AE0000 - 0x02AFFFFF APE , NAND , Area : 0x02B00000 - 0x03ECFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_51003301.V25 Total writen 1583 blocks TIME : Write time : 00:02:05 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia N70 Software Info: V 05wk07v48.6 19-01-10 RM-84 (c) Nokia. IMEI: 353125022078396 Product code: 0547341 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! Error When resetting SW upgrade Default ... AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:09 Restoring UserData : [PhoneBook] Generation mode : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... Fsrun OK... Detect Symbian OS Generation... Detected: [Symbian OS 8.X] Phone! Running : APE_TEST_SERVER,w31_05,(c)NMP Searching for phonebook Not found Old phonebook not found, skip earase... File size is : 29949 bytes Will write 30 blocks... Patch header... Writing data... HDR:[Ok] Write done! Please, start phone in normal mode, And after that enter in phonebook - phone can once time Going to reboot - it is normally Done... Phone disconected! Connect phone on selected interface... |
08-09-2011, 15:47 | #13729 (permalink) |
Member: 715924 Status: Offline Sonork: 100.1662616 Thanks Meter: 83 | card found: S/N 444444444444 registered to: muktadirma Connect phone on selected interface... UFS S/N 93206 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 0FF5F1327C4ADE0759C8B384756E97638751072B APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 25D00002412A5451906651D82B7A373C386A7F27 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC1 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00360098 , APE , APE Flash ID : 00360098 < UNKNOW [NOT IN BASE] ReqAlgo : APE , OMAP1610 GBBM-1.8.1 ALG 4 FLCNT : 01010000020000000600000000000000000000 Sending ALGO.... Use : h3_sam_nand_gbbm.fg , Rev : 0.0 Ver : 1.33.0 APE Algo sent APE PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC0 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 351863013445834 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) APE : Read NPC certificate... Cert size : 0 byte(s) APE : Read CCC certificate... Cert size : 0 byte(s) APE : Read HWC certificate... Cert size : 0 byte(s) APE : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... VARIANT Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\351863013445834_CR T.rpl Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok User ACCEPTED FULL ERASE Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 0FF5F1327C4ADE0759C8B384756E97638751072B APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 25D00002412A5451906651D82B7A373C386A7F27 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC1 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00360098 , APE , APE Flash ID : 00360098 < UNKNOW [NOT IN BASE] ReqAlgo : APE , OMAP1610 GBBM-1.8.1 ALG 4 FLCNT : 01010000020000000600000000000000000000 Sending ALGO.... Use : h3_sam_nand_gbbm.fg , Rev : 0.0 Ver : 1.33.0 APE Algo sent APE PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC0 Transmission mode : Dual (Ddr, TX2) Boot Done! Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x007FFFFF Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... CMT : Erase Ok Done Phone disconected! Connect phone on selected interface... Core version : 1.25 Rev : 1.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : RM84_51003301.C0 PPM : RM84_51003301.V25 Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 0FF5F1327C4ADE0759C8B384756E97638751072B APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 25D00002412A5451906651D82B7A373C386A7F27 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 00360098 , APE , APE Flash ID : 00360098 < UNKNOW [NOT IN BASE] ReqAlgo : APE , OMAP1610 GBBM-1.8.1 ALG 4 FLCNT : 01010000020000000600000000000000000000 Sending ALGO.... Use : h3_sam_nand_gbbm.fg , Rev : 0.0 Ver : 1.33.0 APE Algo sent APE PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC0 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_51003301.C0 Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0052B60D CMT , NOR , Area : 0x006A0000 - 0x006BFFFF CMT , NOR , Area : 0x006DF000 - 0x006EFFFF CMT , NOR , Area : 0x00700000 - 0x007EFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0000FFFF APE , NAND , Area : 0x00010000 - 0x0001FFFF APE , NAND , Area : 0x00020000 - 0x000203FF APE , NAND , Area : 0x00050000 - 0x03ECFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:06 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_51003301.C0 CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [SOS*CORE] Total writen 1122 blocks TIME : Write time : 00:03:01 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing RM84_51003301.V25 Found 2 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x01AE0000 - 0x02AFFFFF APE , NAND , Area : 0x02B00000 - 0x03ECFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Transmission mode : Dual (Ddr, TX2) Write : Processing RM84_51003301.V25 Total writen 1583 blocks TIME : Write time : 00:01:43 PrReq : NOR , 00 PrReq : NAND , 010100009DE5D6001B3B1100EBCAB5 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia N70 Software Info: V 05wk07v48.6 19-01-10 RM-84 (c) Nokia. IMEI: 12345610654321? Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... card found: S/N 0AA6:0118 registered to: muktadirma Connect phone on selected interface... UFS S/N 93206 boot - Ok Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) Variant Data found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 0FF5F1327C4ADE0759C8B384756E97638751072B APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 25D00002412A5451906651D82B7A373C386A7F27 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... Use : RAP3Gv2_2nd.fg , Rev : 0.0 Ver : 1.21.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 225000EC , CMT , NOR CMT Flash ID : 225000EC < SAMSUNG [SEC] => K8S6415ETB FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78DC1 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : VARIANT erase Ok Writing VARIANT... Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 351863013445834 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100701 APE MODE ID : 00 APE PUB ID : 0FF5F1327C4ADE0759C8B384756E97638751072B APE R_HASH : 2C05369F57CC3C4CF9E783E83D9B512B APE ROM ID : AB5E4ADB27A06946 CMT part info : CMT ASICID : 000000010000022600010006000C192101002200 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 25D00002412A5451906651D82B7A373C386A7F27 CMT MODE ID : 00 CMT R_HASH : E9EFF4BFAA5393217CA6B17755FC3E14 CMT ROM ID : F28A211FCEA7B19D CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 25D00002412A5451906651D82B7A373C386A7F27 hash= E9EFF4BFAA5393217CA6B17755FC3E14 key= C395D7D30AAE652228F72BAFCE3DD1ADCCD4ABE6 Init Service mode... Wait... Key file updated... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing Super Dongle Key... Ok Done! Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! ----------------------- PA_SimLock Version : PA_SL phone detected Done! Local SX4 procedure started... Phone Imei: 351863013445834 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-84.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 15 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 29 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Upload done Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to muktadirma For This Useful Post: |
08-09-2011, 18:10 | #13730 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Core version : 1.25 Rev : 1.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm614__07.25_007.image_l_claro_ca_golden_white_v2_ 9c1z4 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBCRT, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000D744B21FDF2BFB95F284928C92B91B ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 11.24.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 11.24.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 355933041761571 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\InfinityBox_install_BEST_v1.25\Backup\Cert\3559 33041761571_CRT.rpl ===Flashing [CNT]=== Erase : Processing rm614__07.25_007.image_l_claro_ca_golden_white_v2_ 9c1z4 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm614__07.25_007.image_l_claro_ca_golden_white_v2_ 9c1z4 Total writen 234 blocks TIME : Write time : 00:00:02 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:00:03 Reboot phone now... Reading Phone Info.... Connected phone - C3-00 Software Info: V 04.60 31-08-10 RM-614 (c) Nokia IMEI: 355933041761571 PPM version : V 04.60 31-08-10 RM-614 (c) Nokia MC1 Product code: 0594149 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:01:01 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
08-09-2011, 19:32 | #13731 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Core version : 1.25 Rev : 1.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm689_002.600 PPM : rm689_002.60ia CNT : rm6890_nai02.60ia Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 0020000000C08800 FLASH ID : ST, M58WR064 Boot Done! ===Flashing [MCU]=== File : rm689_002.600 Image : hw_s01_rm689_r02.600.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00204780 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : AF9A ===Flashing [PPM]=== File : rm689_002.60ia Image : hw_s01_rm689_002.60ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x00204A80 Flashing , wait ... Region flash done Check : 90E0 ===Flashing [CNT]=== File : rm6890_nai02.60ia Image : hw_s01_rm6890_nai02.60ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000510C0 Flashing , wait ... Region flash done Check : 24CB Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 02.60 06-08-10 RM-689 (c) Nokia IMEI : 354324046589640 PCode : 059B340 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
08-10-2011, 04:15 | #13732 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Shadow Clone
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 126 | Vodafone 340 unlock done.. COM8 [VCP0] selected module v3.75 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:CE03:A00D status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.44 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203448608 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 32 sec Remove/Install battery now ! |
The Following User Says Thank You to TestCard17 For This Useful Post: |
08-10-2011, 05:47 | #13733 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | E6 LBF create Code: Connect phone on selected interface... Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 0890010B67ED5840054BEA884FA269357D588D42 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B Fetching data, wait... Reinsert cable and battery, press powerOn button again Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 0890010B67ED5840054BEA884FA269357D588D42 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.24.0 Processing RAWLOADER... FLIC : 00680020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.24.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Wait, reconneting... rap= 0890010B67ED5840054BEA884FA269357D588D42 hash= 916F75217F32081248B15C38DFC8E81B key= 958CB236A149C9A5BDB1C54619359618780806AA Key file updated... Connect phone on selected interface... Done! Phone found! Series 60 Device detected! read info... - Ok Phone Imei: 354875041173565 Checking locks... Checking locks... Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= PA_SL3 (15 digit) phone detected... Key file exists, no need to read... Create Log file for local calculation... File C:\InfinityBox\BEST\Local_calc\354875041173565.bcl created - Ok File C:\InfinityBox\BEST\Local_calc\ighashgpu_354875041173565.bat created - Ok File C:\InfinityBox\BEST\Local_calc\oclHashcat_354875041173565.bat created - Ok Done! Set phone in Normal mode... Restarting... Done! |
The Following User Says Thank You to Dzirt For This Useful Post: |
08-10-2011, 05:48 | #13734 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | X3-02 SD repair Code: Connect phone on selected interface... Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 1410020B9B6C514033C8F1B4062898D23854E8C1 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B Fetching data, wait... Reinsert cable and battery, press powerOn button again Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 1410020B9B6C514033C8F1B4062898D23854E8C1 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.24.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.24.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: Close_Session Content: 000300000000040000000400000000 ADL: Reboot Wait, reconneting... rap= 1410020B9B6C514033C8F1B4062898D23854E8C1 hash= 916F75217F32081248B15C38DFC8E81B key= D96D929B15C6D71660E9467CA5FB8377F4349E15 Key file updated... Connect phone on selected interface... Done! Phone found! Series 40 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 355380041945715 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Local SX4 procedure started... Phone Imei: 355380041945715 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Read and Check phone data... ---------------------- RAP_BOOT: 0D01010303010000 RAP_PUB: 1410020B9B6C514033C8F1B4062898D23854E8C1 CMT_ROOT: 916F75217F32081248B15C38DFC8E81B RAP_PAPUB: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C ---------------------- Live Test Ok! ---------------------- CMT Flash ID : 003000EC < SAMSUNG [SEC] => K5W1G13ACB CNT sector : 128 kb ------------------------ SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok PA_SimLock Version : PA_SL30 phone detected , SP_CODE_LEN : 20 Done! Set phone in Normal mode... Restarting... Done! |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
08-10-2011, 05:50 | #13735 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | http://server1.infinity-best.com/dow...9_log_read.rar E6 log read ( video how to ) |
08-10-2011, 08:54 | #13736 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm443__10.12.image_f_chestnut Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected -> Custom flashing in dead mode active! -> Phone will boot in normal mode after flash! Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1E500015237C7D56951660C39B79226E6C33866C CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:08 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_f_chestnut Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:20 Write : Processing rm443__10.12.image_f_chestnut Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:27 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:48 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 356036030081776 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia F Product code: 0569480 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... FS damaged, or minor error AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:15 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-10-2011, 08:54 | #13737 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading User code... User Code is: Error! Crypted user code! Done! Resetting selected items... Check phone mode... Phone in Normal mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:15 Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm645_062.001_prd.core.fpsx PPM : rm645_062.001_11.01_MEA_C_prd.rofs2.fpsx PPM2 : rm645_062.001_C00.01_DEFAULT_prd.rofs3.fpsx CNT : RM645_ENO_10wk48v0.001.fpsx APE : rm645_062.001_U000.000_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 08100213898F574091C118C1FEA2A519C55521EC ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.24.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.24.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 356989045325473 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.26\Backup\Cert\3569 89045325473.rpl ===Flashing [MCU]=== Erase : Processing rm645_062.001_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_062.001_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 394 blocks TIME : Write time : 00:01:56 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm645_062.001_11.01_MEA_C_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_062.001_11.01_MEA_C_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 159 blocks TIME : Write time : 00:00:49 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm645_062.001_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_062.001_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing RM645_ENO_10wk48v0.001.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM645_ENO_10wk48v0.001.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 10 blocks TIME : Write time : 00:00:02 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [APE]=== Erase : Processing rm645_062.001_U000.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_062.001_U000.000_prd.uda.fpsx Total writen 6 blocks TIME : Write time : 00:00:02 APE Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:02:53 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C5-00 Software Info: V ICPR82_10w34.4 09-12-10 RM-645 (c) Nokia IMEI: 356989045325473 Ape Version: 062.001 Product code: 0597838 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:03:16 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
08-10-2011, 10:55 | #13738 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | COM9 selected module v1.78 Device: SFR-227 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: VDF-P108B1B03-FrRoBgElHu-BG05 g3xAV3.0 May 27 2008 15 40 46 04.1 Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\SFR-227_eeprom-static_20110810-005304.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\SFR-227_eeprom-security_20110810-005305.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\SFR-227_eeprom-complete_20110810-005312.B1E.bin reading additional data... file saved: c:\InfinityBox\Pana01\SFR-227_lock-area_20110810-005324.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 23 sec Remove/Install battery now ! |
The Following User Says Thank You to delchoni For This Useful Post: |
08-10-2011, 11:21 | #13739 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Nokia 1616 flash to new 6.51 FW Code: Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : rh125_006.510 PPM : rh125_006.51ej CNT : rh1250_nai06.51ej Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 0020000000C08800 FLASH ID : ST, M58WR064 Boot Done! ===Flashing [MCU]=== File : rh125_006.510 Image : hw_f11_rh125_r06.510.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00212C80 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 31F6 ===Flashing [PPM]=== File : rh125_006.51ej Image : hw_f11_rh125_006.51ej.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x00202580 Flashing , wait ... Region flash done Check : 4A49 ===Flashing [CNT]=== File : rh1250_nai06.51ej Image : hw_f11_rh1250_nai06.51ej.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x0004F4C0 Flashing , wait ... Region flash done Check : 95BE Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 06.51 13-05-11 RH-125 (c) Nokia IMEI : 354302040852545 PCode : 0587446 All done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 06.51 13-05-11 RH-125 (c) Nokia IMEI : 354302040852545 PPM : V 06.51 13-05-11 RH-125 (c) Nokia EJ PCode : 0587446 BPCode : 059B9S2 HWID : 1002 LCDVer : UNKWN: IDs: 00:00:00 IMEI : 354302040852545 Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : 2320FE0FD76D8AFC Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! |
08-10-2011, 11:22 | #13740 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Nokia 6720 via ufs Code: Phone found! Series 40 Device detected! read info... - Ok Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm56b5003.90.mcusw.bin PPM : rm56b5003.90.ppm_k CNT : rm56b5003.90.image_k Check FlashFiles, Please, wait... -> Check SW version... FlashFile version : 03.90 Phone version : 03.90 09-02-07 RM-56 (c) Nokia. -> Check SW version : Reflash Backup enabled, Will read Certificates now... CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 26300113FD9A5056788200E75A4165DE2A81A278 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22FE00EC , CMT , NOR CMT Flash ID : 22FE00EC < SAMSUNG [SEC] => K8S5615ETA FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 543D4EB3D80EB900F842AE957BC9AC364E7E653F7B Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 357579004137123 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... VARIANT Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357579004137123_CRT.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 26300113FD9A5056788200E75A4165DE2A81A278 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22FE00EC , CMT , NOR CMT Flash ID : 22FE00EC < SAMSUNG [SEC] => K8S5615ETA FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 543D4EB3D80EB900F842AE957BC9AC364E7E653F7B Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm56b5003.90.mcusw.bin Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00180000 - 0x00B69DB5 CMT , NOR , Area : 0x00000000 - 0x000FFFFF CMT , NOR , Area : 0x00120000 - 0x0017FFFF CMT , NOR , Area : 0x00C00000 - 0x0117FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:35 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm56b5003.90.mcusw.bin CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [MCUSW] Total writen 728 blocks TIME : Write time : 00:01:15 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm56b5003.90.ppm_k Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00C00000 - 0x0117FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:01 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm56b5003.90.ppm_k Total writen 277 blocks TIME : Write time : 00:00:29 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm56b5003.90.image_k Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01180000 - 0x01FDFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:22 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm56b5003.90.image_k Total writen 300 blocks TIME : Write time : 00:00:32 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 6270 Software Info: V 03.90 09-02-07 RM-56 (c) Nokia. IMEI: 357579004137123 Product code: 0529944 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Repair user cert failed :( AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
