08-16-2011, 11:29 | #13801 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm443__10.12.image_f_chestnut Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected -> Custom flashing in dead mode active! -> Phone will boot in normal mode after flash! Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0D20000F120D8C56A2A429B4F24BEABC1832AFDF CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:08 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_f_chestnut Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:29 Write : Processing rm443__10.12.image_f_chestnut Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:57 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 08.90 30-06-09 RM-443 (c) Nokia IMEI: 358005038009541 PPM version : V 08.90 30-06-09 RM-443 (c) Nokia S10 Product code: 0568866 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:07:08 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-16-2011, 11:30 | #13802 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : 4BB8AA07_rm495__07.97.ppm_mena_a1 CNT : E24393CE_rm495__07.97.image_mena_a1_red Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B100203641E005601C44B99359BA48743D070C7 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 352003044072179 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.26\Backup\Cert\3520 03044072179_2nd.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 1B100203641E005601C44B99359BA48743D070C7 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 0C917F11196FDB7378C18EF7260698CA4489DCA027 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing C5F02102_rm495__07.97.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:02:03 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing C5F02102_rm495__07.97.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1169 blocks TIME : Write time : 00:02:21 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1 Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:40 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing 4BB8AA07_rm495__07.97.ppm_mena_a1 Total writen 388 blocks TIME : Write time : 00:00:45 PrReq : NOR , 00 CNT : Converted to 128k page data exist Transmission mode : Dual (Ddr, TX2) Erase : Processing E24393CE_rm495__07.97.image_mena_a1_red_128 Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:50 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing E24393CE_rm495__07.97.image_mena_a1_red_128 Total writen 660 blocks TIME : Write time : 00:01:16 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 352003044072179 Product code: 0572166 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Repair user cert failed AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-16-2011, 12:37 | #13803 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM3 [VCP0] selected module v3.30 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 353548005476925 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9E03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: LB0MM06.8.32.1.0T02M0922_M570 Version: LCSH25_08A_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35980403408759 connection Ok detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read verification... verification done: 35354800547692 Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
08-16-2011, 12:37 | #13804 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM3 [VCP0] selected module v3.30 Action: "repair imei" imei write method: mode-2 imei write channel: imei #2 for dual sim/mono CPU new imei: 353615017342617 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9E03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: LB0MM06.8.32.1.0T02M0922_M570 Version: LCSH25_08A_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35354800547692 connection Ok detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read verification... verification done: 35361501734261 Finished, time used: 15 sec Remove/Install battery now ! |
08-16-2011, 15:30 | #13805 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.26 Rev : 2.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_21.1.004_prd.core.C00 PPM : RM-625_21.1.004_prd.rofs2.V05 PPM2 : RM-625_21.1.004_C02_prd.rofs3.fpsx CNT : RM-625_21.1.004_001_000_U001.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 21.1.004 Phone version : V 21.1.004 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\355395042021688_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0BE0010916A400527FC589F94D6EBB86917A069C ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_21.1.004_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.004_prd.core.C00 Total 387 [387/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:28 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_21.1.004_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.004_prd.rofs2.V05 Total 110 [110/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:09 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_21.1.004_C02_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.004_C02_prd.rofs3.fpsx Total 29 [29/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-625_21.1.004_001_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.004_001_000_U001.uda.fpsx Total 23 [23/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:43 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5228 Software Info: V ICPR72_10w21 26-05-10 RM-625 (c) Nokia IMEI: 355395042021688 Ape Version: V 21.1.004 Product code: 059F008 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:01:10 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
08-16-2011, 20:07 | #13806 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm411__07.23.image_mb_b_red Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.26\Backup\Cert\3568 40022342330_SIM.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1250000B18D25850515560974C946CF2791C7F58 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: D93826B23E9B093BE4DD7304FBAA6778996AE60B Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm411__07.23.image_mb_b_red ConvertImage: Page Size is 128K, no need convert Loader len: 307008, CHK: C0CE ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm411__07.23.image_mb_b_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:40 Write : Processing rm411__07.23.image_mb_b_red Total 504 [504/0/0] blocks to write, writing... TIME : Write time : 00:00:27 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:07 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5220 XpressMusic Software Info: V 07.23 17-07-09 RM-411 (c) Nokia IMEI: 356840022342330 PPM version : V 07.23 17-07-09 RM-411 (c) Nokia MB Product code: 0563614 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:07:00 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-16-2011, 20:09 | #13807 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Files Set for Flashing : CNT : rm217__07.30.image_ctv_cn_black Check FlashFiles, Please, wait... -> SWversion check skipped : Custom mode selected Backup enabled, Will read Certificates now... WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 1640000805596D56159BDDED663938E3AC78B127 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 220800EC , CMT , NOR CMT Flash ID : 220800EC < SAMSUNG [SEC] => K8F5615ETM\K5G5629ATD FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 7F7E6491E8D30494B45630BB3A8599F4E1C674C955 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 359537019776895 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.26\Backup\Cert\3595 37019776895.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 1640000805596D56159BDDED663938E3AC78B127 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 220800EC , CMT , NOR CMT Flash ID : 220800EC < SAMSUNG [SEC] => K8F5615ETM\K5G5629ATD FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 7F7E6491E8D30494B45630BB3A8599F4E1C674C955 Transmission mode : Dual (Ddr, TX2) Boot Done! CNT : Converted to 128k page data exist Transmission mode : Dual (Ddr, TX2) Erase : Processing rm217__07.30.image_ctv_cn_black_128 Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01600000 - 0x01FDFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:27 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm217__07.30.image_ctv_cn_black_128 Total writen 296 blocks TIME : Write time : 00:00:32 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Software Info: V 07.30 07-05-09 RM-217 (c) Nokia. IMEI: 359537019776895 Product code: 0521830 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-16-2011, 20:11 | #13808 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading User code... User Code is: 12345 Done! Format File System... Check phone mode... Phone in RfInactive mode Seting Local mode... wait... Local mode set Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 08F00018947B0052E39F56C13129A9C570F66F15 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 11.24.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done Boot error... Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO If RAPIDO - use dead mode for read rpl/force local SimLock Data saved... SimLock Key saved... RPL saved : D:\InfinityBox_install_BEST_v1.26\Backup\Cert\3552 01031388544_SIM.rpl Phone disconected! Connect phone on selected interface... |
08-16-2011, 20:12 | #13809 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm237__07.30.image_c_tr_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected -> Custom flashing in dead mode active! -> Phone will boot in normal mode after flash! Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006010C192101001101 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0B30011546127F566F272B16C9D1E40C2D4B597B CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm237__07.30.image_c_tr_blue Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:49 Write : Processing rm237__07.30.image_c_tr_blue Total 236 [236/0/0] blocks to write, writing... TIME : Write time : 00:00:12 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:02:02 Reboot phone now... -> Flashing Failed! Maybee HW error, or Downgrade try???! Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:04:06 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading User code... User Code is: 62747 Done! Resetting User Code to default (12345)... Clear data : Ok Result: 12345 Done! Resetting selected items... Check phone mode... Phone already in Test mode, skip change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:02 |
08-16-2011, 20:13 | #13810 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : RM-356_52.0.007_026_000_U01.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.26\Backup\Cert\3537 81042001683_SIM.rpl Check communication with phone.... -> Unknow ADL state[FF]... Sorry, continue impossible... Flashing failed... Phone disconected! Connect phone on selected interface... Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : RM-356_52.0.007_026_000_U01.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 19900012289A005256C3EEB2FC671E0BF7F41F8D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:42 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing RM-356_52.0.007_026_000_U01.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_026_000_U01.uda.fpsx Total 29 [29/0/0] blocks to write, writing... TIME : Write time : 00:00:10 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:10 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w04.5 22-03-10 RM-356 (c) Nokia IMEI: 353781042001683 Ape Version: V 50.0.005 Product code: 0578313 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:01:28 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
08-16-2011, 21:07 | #13811 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | 3 hawey unlock wed sucess wed j-tag tespoint here´s log ==== [16-08-2011 12:31:33] ==== COM66 [VCP0] selected module v4.00 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600_128mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2PT02V01.04 Version: BYD35_09A_HW 88 byte(s) read imei: 35634404160131 connection Ok 195 byte(s) read reading data... reading data #2... building new data... writing data... 183 byte(s) read reading data... reading data #2... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! ==== [16-08-2011 12:25:31] ==== COM66 [VCP0] selected module v4.00 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600_128mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2PT02V01.04 Version: BYD35_09A_HW 88 byte(s) read imei: 35634404153744 connection Ok 195 byte(s) read reading data... reading data #2... building new data... writing data... 183 byte(s) read reading data... reading data #2... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 17 sec Remove/Install battery now ! ==== [16-08-2011 12:01:54] ==== COM66 [VCP0] selected module v4.00 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600_128mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2PT02V01.04 Version: BYD35_09A_HW 88 byte(s) read imei: 35634404155090 connection Ok 195 byte(s) read reading data... reading data #2... building new data... writing data... 183 byte(s) read reading data... reading data #2... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! |
The Following User Says Thank You to carlos32 For This Useful Post: |
08-17-2011, 10:43 | #13812 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | COM6 [VCP3] selected module v3.74 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:43CB:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-PK-T9SM-P109A17V1.0.0B02 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403083562 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! |
The Following User Says Thank You to gsmpointhrp For This Useful Post: |
08-17-2011, 11:12 | #13813 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Shadow Clone
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 126 | Vodafone 547 unlock smooth COM39 [VCP1] selected module v3.75 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-547 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: VF_GER_DE_P107A4V1.2.0B03 Version: 09AZTENJ35_09A 83 byte(s) read imei: 35962103094245 connection Ok 189 byte(s) read reading data... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 19 sec Remove/Install battery now ! |
The Following User Says Thank You to TestCard17 For This Useful Post: |
08-17-2011, 13:25 | #13814 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | Code: COM10 [ProlificSerial2] selected Модуль v3.99 Модель: _Autodetect MT6205-6239 NOR Перевірка даних, чекайте ... покращений метод визначення флеші включений Action: repair security area ====> Бут ... Натисніть і тримайте кнопку включення! baud autodetection active 19200 autodetect Підключення, чекайте ... Ініціалізація [6225:8A05:8A00]... CPU: MT6225 висока швидкість завантаження On chip: 0001:D603:0001 status: FF Розмір пакету завантаження: 0400 Відпустіть кнопку включення! Бут Done ====> Ініціалізація ... detecting chip #00 in region #00... Флеш EC257E25082501:18E59F00000000 Флеш Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... Флеш EC257E25082501:18E59F00000000 Флеш Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... Флеш EC257E25082501:18E59F00000000 Флеш Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... Флеш EC257E25082501:18E59F00000000 Флеш Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 визначена кількість флеш / областей: 04/01 Ініціалізація Done ====> Встановлення швидкості ... 921600 Встановлення швидкості Done ====> Ініціалізація додатки ... Ініціалізація додатки Done ====> Перевірка цілісності даних ... device parameters detection in progress... detecting chip #00 in region #00... Флеш EC257E25082501:18E59F00000000 Флеш Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... Флеш EC257E25082501:18E59F00000000 Флеш Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 визначена кількість флеш / областей: 01/01 разом розмір області флеш: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.FF24E206.[X6_X6JT_A_PCB01_GPRS_MT6225_S00.X6JAVA_TV_A_T02_D0123.BIN_36802384].rpl ==================== New firmware found (v.3.99, database date: 04.08.2011): X6_X6JT_A_PCB01_GPRS_MT6225_S00.X6JAVA_TV_A_T02_D0123.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Читати full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: FF24E206 rom info ver: 05 sw version: X6_X6JT_A_PCB01_GPRS_MT6225_S00.X6JAVA_TV_A_T02_D0123.BIN project-id: X6JAVA_TV_A_T02_D0123, 84238036 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent визначення startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... . search sec info#1 finished помилка: incorrect ffs address range збережено: C:\Program Files\InfinityBox\MModule\backup_security\_system_log_FF24E206_36802384_20110817-152318.B0X.bin Закінчено, знадобилося часу: 1 min 46 sec Від'єднайте / підключіть батарею! |
The Following User Says Thank You to Kolumb For This Useful Post: |
08-17-2011, 16:03 | #13815 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | COM3 [VCP0] selected module v3.99 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware A_TEAM_PCB01_GPRS_MT6253_S00.M10AW1108.BIN_FLNPF38 F3040M0Y3DE__fullflash_20110804-152913.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A04:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6253:8A04:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: M10AW1108 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: A_TEAM_PCB01_GPRS_MT6253_S00.M10AW1108.BIN_FLNPF38 F3040M0Y3DE project-id: M10AW1108, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.99, database date: 04.08.2011): A_TEAM_PCB01_GPRS_MT6253_S00.M10AW1108.BIN_FLNPF38 F3040M0Y3DE This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\Arquivos de programas\InfinityBox\MModule\A_TEAM_PCB01_GPRS_MT 6253_S00.M10AW1108.BIN_FLNPF38F3040M0Y3DE__fullfla sh_20110817-104822.B0M.bin startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 16 min 54 sec Remove/Install battery now ! |
