11-05-2008, 10:25 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india
Member: 588837 Status: Offline Thanks Meter: 146 | spice s570 successfull formated module v2.64 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot disabled chip: 0011:670F:000C high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: C623_SPICE_PCB01_GPRS_MT6223_S00.KAA623FM_INA_EN_1 _00_C20.BIN ver. sw2: KAA623FM_INA_En_1.00.C20, 00000000 ffs offset/size: 00800000/00800000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: 01227E22202200:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00800000 detecting eeprom/ffs size... eeprom/ffs size: 00800000 ffs chip: 00 eeprom/ffs area: 00000000:00800000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:2AEA0000000000 Finalization Done Finished, time used: 104 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! THIS IS THE COMP. LOGS FOR SPICE S-570. I RECEIVED DEAD SETT FROM CUSTMORE AND TRY WITH CHINESE MIRACELE...BCAZ I CANT SEE THIS MODEL IN SUPPORT LIST...SO I TRIED ...AFTER FORMATTING SETT IS ON AND WORKING PERFECT. ....more stars 4 infinity |
The Following User Says Thank You to neetika99 For This Useful Post: |
11-05-2008, 18:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, post here what is S570 pinout. Also please, read full flash and send it to [email protected] |
03-05-2009, 16:05 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
03-10-2009, 15:47 | #6 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hello, If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
03-12-2009, 20:17 | #10 (permalink) |
07-25-2011, 16:07 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell. It's just an example for Alcatel, if you have another model you must select your model ! RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts |
Spice-S570 (Flash File for Infinity Box) by Moiz Khan | Moiz Khan | Various | 0 | 10-20-2009 15:57 |
how to flash spice s570 | ranagaurav | Infinity-Box | 1 | 06-03-2009 05:01 |
Help Me, Where is Spice S570 Flash File? | gsm_surya | Infinity-Box | 1 | 03-31-2009 14:42 |
Spice S404 can't format | rajumobile | Infinity-Box | 2 | 01-18-2008 06:14 |
Successfull FORMAT n83 nokia | ketan.d.chauhan | Infinity-Box | 1 | 10-26-2007 12:59 |
