Old 11-05-2008, 10:25   #1 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 146
spice s570 successfull formated
COM7 [VCP0] selected
module v2.64
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing[6223:8A04]...
CPU: MT6223
high speed boot disabled
chip: 0011:670F:000C
high speed disabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: C623_SPICE_PCB01_GPRS_MT6223_S00.KAA623FM_INA_EN_1 _00_C20.BIN
ver. sw2: KAA623FM_INA_En_1.00.C20, 00000000
ffs offset/size: 00800000/00800000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00800000
detecting eeprom/ffs size...
eeprom/ffs size: 00800000
ffs chip: 00
eeprom/ffs area: 00000000:00800000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 104 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
THIS IS THE COMP. LOGS FOR SPICE S-570. I RECEIVED DEAD SETT FROM CUSTMORE AND TRY WITH CHINESE MIRACELE...BCAZ I CANT SEE THIS MODEL IN SUPPORT LIST...SO I TRIED ...AFTER FORMATTING SETT IS ON AND WORKING PERFECT. ....more stars 4 infinity
The Following User Says Thank You to neetika99 For This Useful Post:
Old 11-05-2008, 18:57   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, post here what is S570 pinout.
Also please, read full flash and send it to [email protected]
Old 03-05-2009, 07:54   #3 (permalink)
Member: 570724
sir please send me eeprom of spice s570 or flash file
its urgently required
Old 03-05-2009, 16:05   #4 (permalink)
Member: 130995
Hello,
If required file can not be found in support area (please use "search" function in support area first)
it will be good if somebody can read full flash from the same good working phone and send
full flash backup to [email protected] so we will be able to prepare and upload
good working files in support area for all users.
Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-10-2009, 08:13   #5 (permalink)
Member: 570724
i have daily watching infinity box support site but no flash file for spice s570
please sir help me out
The Following User Says Thank You to romeogill For This Useful Post:
Old 03-10-2009, 15:47   #6 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Hello,
Old 03-11-2009, 18:49   #7 (permalink)
Member: 570724
how to search file in support area
Old 03-11-2009, 21:34   #8 (permalink)
Member: 130995
Old 03-12-2009, 12:46   #9 (permalink)
Member: 570724
no file for spice s 570 found
plz help me sir
Old 03-12-2009, 20:17   #10 (permalink)
Member: 130995
plz help me sir
Hello,
Old 03-26-2009, 08:55   #11 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
Spice s570 pin out please send me
The Following User Says Thank You to eswar7983 For This Useful Post:
Old 07-25-2011, 12:06   #12 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
spice S570 pin outs please..........
Old 07-25-2011, 16:07   #13 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell.
It's just an example for Alcatel, if you have another model you must select your model !
RJ45 connector pinout:
Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts
Spice-S570 (Flash File for Infinity Box) by Moiz Khan Moiz Khan Various 0 10-20-2009 15:57
how to flash spice s570 ranagaurav Infinity-Box 1 06-03-2009 05:01
Help Me, Where is Spice S570 Flash File? gsm_surya Infinity-Box 1 03-31-2009 14:42
Spice S404 can't format rajumobile Infinity-Box 2 01-18-2008 06:14
Successfull FORMAT n83 nokia ketan.d.chauhan Infinity-Box 1 10-26-2007 12:59
Page generated in 0.26453 seconds with 9 queries
