Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 08-02-2016, 20:32   #76 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by Todizara View Post
Do you know any qualcomm unbricker that uses hex prommare ? I wanna convert this ALTO45_NPRG7627_sec.bin to hex !!!!! Please upload the sahara.xml of 5042x so I can understand which prommamer it is using . Please
That file is not available. Anyway, it's generic file. It just carries programmer name,
but since we know it's msm8916, that could be good starting point.
You can try with QPST, put programmer files in same folder where qpst exe is
C:\Program Files (x86)\Qualcomm\QPST\bin (64bit windows)
or
C:\Program Files\Qualcomm\QPST\bin (32bit windows)
there is just one thing i noticed ...
must be used alcatel loaders, and "trusted mode" in QPST, because loader (booting) is SIGNED.
and ... use 32-bit windows, best solution is WinXP if you can get hands on.
p.s. QPST accepts both HEX and BIN loaders.
b.r.
Alex
File Type: rar 5042x_sahara.rar (214 Bytes, 198 views)
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 08-02-2016, 23:15   #77 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Hi guys.
Just few cents here
This phone use firehose protocol, but alcatel maked own loader format what differ from generic qualcom format.
Most posible QPST will not help here, because commands used by qualcom loader what know QPST and alcatel loader differ.
The Following 4 Users Say Thank You to orbita For This Useful Post:
Old 08-02-2016, 23:46   #78 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by orbita View Post
Hi guys.
Just few cents here
I thought it was using firehose, but was way tooo lazy to check ...
anyway, using QFIL, may be some chances it will work or not ?
Only one way to find out ... attached is firehose loader ... test.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 08-05-2016, 14:31   #79 (permalink)
Member: 2178386
Thanks Meter: 10
Hi guys.
Just few cents here
I didn't had time to test the firehorse from Sir BRKA yet.... Please
wich commercial box is able to flash it or to unlock the bootloader using firehorse qdloader 9008 please ? wich jtag in case of no box ?
Old 09-05-2016, 13:44   #80 (permalink)
Member: 2178386
Thanks Meter: 10
I have tried everything I could try but unsuccesful... I'm about to throw it away so I'll try hardware methode even if I am not sure if it is not the rpm.mbn which is corrupted but phone is showing exlamation mark inside of a triangle while charging and battery is 0%
Old 10-25-2016, 22:50   #81 (permalink)
djfran10's Avatar
Member: 1914674
Sonork: 100.1652329
Thanks Meter: 41
Need firmware Alcatel 5042a
Hello.
I need firmware for Alcatel 5042a
5042A-ABPSAR1
If possible without logo operator.
Thanks in advance.
Old 10-26-2016, 08:34   #82 (permalink)
wafi95's Avatar
Member: 2621055
Sonork: 100.1675233
Thanks Meter: 144
5042D Firmware here
https://drive.google.com/file/d/0BzD...kwSXJsSGs/view try it
or this online Download firmware for Alcatel POP 2 5042X - free on your device.
edit by admin: Posted firmware is for 5042D model.
Old 10-28-2016, 11:23   #83 (permalink)
Member: 2629882
Hey there folks. I have an Alcatel One Touch 5042x (POP 2/4.5) and I need a stock rom for it in order to reflash it.
I have tried finding a proper rom for it but I couldn't find any readily available on any of my boxes support/Google.
Any help would be greatly appreciated.
The rom i'm looking for is for the european region, preferabily with english/romanian languages.
I have a cwm backup that I have found, but I can't install cwm on it, because the flash is completely messed up.
Thanks in advance.
Regards,
Myiu
Pid: 5013x - 2srgro3
Old 01-18-2017, 14:22   #84 (permalink)
Member: 2178386
Thanks Meter: 10
need help
b.r.
Alex
My 5042x after flash 5042d-2salru1 battery not charge and is low and phone doesn't start. Is there a way to get back fastboot again
Old 01-18-2017, 20:18   #85 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
At least two commercial boxes supports flashing of 5042 model,
use search to see which ones.
b.r
Alex.
__________________
Old 09-04-2017, 07:57   #86 (permalink)
Member: 2178386
Thanks Meter: 10
I need working firehose programmer .mbn for 5042d
Old 09-05-2017, 21:03   #87 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Try with these, from attached archive.
b.r.
Alex
__________________
The Following 3 Users Say Thank You to Brka For This Useful Post:
Old 09-26-2017, 19:10   #88 (permalink)
Member: 2178386
Thanks Meter: 10
I need flashable qfil rom please. I really want my phone working again
Old 10-09-2017, 08:32   #89 (permalink)
Member: 2178386
Thanks Meter: 10
I finnaly have unbricked my ot-5042X. With the help of flash programmer from Brka and rawprogram.xml and patch0.xml and sahara. and aboot.img from deadlink (4PDA) that I modified I was able to enable fastboot again with QFIL.
fastboot fix qfil by Todizara
PHONE is on but no network. I need help
Old 10-09-2017, 17:45   #90 (permalink)
Member: 2178386
Thanks Meter: 10
Originally Posted by Nicogalan View Post
no....
there is no way...
always 9008...
I am fried hehehehehe
also, driver freezes my pc, I tried win xp, win 7 64 and its always the same.
even after phone is disconnected, it's still recognized as com port O_O
chrome is hung, taskmanager too, so I need to reboot pc to try again
do you know where could I ask for help??
for fure, hex + mbn file needed to get fastboot again
thanks
I also happened to me. Computer freezes everytime I plug the phone but I disabled driver signature verification then I could back to stock using factory flasher 5042d
Page generated in 0.22737 seconds with 9 queries
