Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 05-14-2015, 21:27   #31 (permalink)
Member: 242451
Thanks Meter: 63
Originally Posted by Brka View Post
put twrp in phone and use provided backup, it should fix imei too.
b.r
Alex
alcatel 5042a
bro, can i fix (change) imei, erasing some partitions and writting qcn newimei?
i tried and got imei null, erasing modemst and fsg, but restoring qcn (whit new imei) i get restore original imei. Do you know wich partitions store imei?
thanks
check this
ls -al /dev/block/platform/7824900.sdhci/by-name
lrwxrwxrwx root root 1969-12-31 18:23 DDR -> /dev/block/mmcblk0p21
lrwxrwxrwx root root 1969-12-31 18:23 aboot -> /dev/block/mmcblk0p6
lrwxrwxrwx root root 1969-12-31 18:23 abootbak -> /dev/block/mmcblk0p7
lrwxrwxrwx root root 1969-12-31 18:23 boot -> /dev/block/mmcblk0p24
lrwxrwxrwx root root 1969-12-31 18:23 cache -> /dev/block/mmcblk0p31
lrwxrwxrwx root root 1969-12-31 18:23 custpack -> /dev/block/mmcblk0p30
lrwxrwxrwx root root 1969-12-31 18:23 fota -> /dev/block/mmcblk0p20
lrwxrwxrwx root root 1969-12-31 18:23 fsc -> /dev/block/mmcblk0p18
lrwxrwxrwx root root 1969-12-31 18:23 fsg -> /dev/block/mmcblk0p23
lrwxrwxrwx root root 1969-12-31 18:23 hdcp -> /dev/block/mmcblk0p28
lrwxrwxrwx root root 1969-12-31 18:23 hyp -> /dev/block/mmcblk0p12
lrwxrwxrwx root root 1969-12-31 18:23 hypbak -> /dev/block/mmcblk0p13
lrwxrwxrwx root root 1969-12-31 18:23 misc -> /dev/block/mmcblk0p17
lrwxrwxrwx root root 1969-12-31 18:23 modem -> /dev/block/mmcblk0p1
lrwxrwxrwx root root 1969-12-31 18:23 modemst1 -> /dev/block/mmcblk0p15
lrwxrwxrwx root root 1969-12-31 18:23 modemst2 -> /dev/block/mmcblk0p16
lrwxrwxrwx root root 1969-12-31 18:23 pad -> /dev/block/mmcblk0p14
lrwxrwxrwx root root 1969-12-31 18:23 persist -> /dev/block/mmcblk0p25
lrwxrwxrwx root root 1969-12-31 18:23 recovery -> /dev/block/mmcblk0p32
lrwxrwxrwx root root 1969-12-31 18:23 rpm -> /dev/block/mmcblk0p8
lrwxrwxrwx root root 1969-12-31 18:23 rpmbak -> /dev/block/mmcblk0p9
lrwxrwxrwx root root 1969-12-31 18:23 sbl1 -> /dev/block/mmcblk0p4
lrwxrwxrwx root root 1969-12-31 18:23 sbl1bak -> /dev/block/mmcblk0p5
lrwxrwxrwx root root 1969-12-31 18:23 sec -> /dev/block/mmcblk0p22
lrwxrwxrwx root root 1969-12-31 18:23 splash -> /dev/block/mmcblk0p26
lrwxrwxrwx root root 1969-12-31 18:23 ssd -> /dev/block/mmcblk0p19
lrwxrwxrwx root root 1969-12-31 18:23 system -> /dev/block/mmcblk0p29
lrwxrwxrwx root root 1969-12-31 18:23 tctpersist -> /dev/block/mmcblk0p27
lrwxrwxrwx root root 1969-12-31 18:23 traceability -> /dev/block/mmcblk0p3
lrwxrwxrwx root root 1969-12-31 18:23 tunning -> /dev/block/mmcblk0p2
lrwxrwxrwx root root 1969-12-31 18:23 tz -> /dev/block/mmcblk0p10
lrwxrwxrwx root root 1969-12-31 18:23 tzbak -> /dev/block/mmcblk0p11
lrwxrwxrwx root root 1969-12-31 18:23 userdata -> /dev/block/mmcblk0p33
Old 05-14-2015, 22:07   #32 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,786
Originally Posted by pulian View Post
alcatel 5042a
thanks
check this
IMEI is stored in EFS, which is probably not accessible in "user" mode.
(Probably accessible via RAW, eMMC mode).
Also, without patching modem, not to check OTP imei,
phone will always use (read every time upon creating NVM), original imei.
So ... hard work
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 06-29-2015, 07:52   #33 (permalink)
Member: 2381896
Thanks Meter: 13
Hey guys, I need your help.
I was not paying attention and did a direct unlock (counter was reset to 0) for an Orange Roya / Alcatel OT-5042X which had been previously flashed with an OT-5042D firmware + Cyanogen by the client. Now when I insert any SIM card and dial a number it says "Not Registered on Network".
Any advice is appreciated.
Old 06-29-2015, 16:22   #34 (permalink)
Member: 565786
Thanks Meter: 11
return to stock check imei
Old 06-29-2015, 17:27   #35 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
This phone have signed modem.
Pathing modem without factory rsa key is not posible.
@stricimacko
Use factory alcatel flasher.
Untill flashing in this phones EFS will be restored to factory state.
If proinfo partition not destroyed when was flashed wrong firmware, this must solve problem.
In this phone some partitions are hidden and not accesible directly even on rooted phone.
Most posible some partitions remain from old firmware and some from new firmware.
And this create problems.
If you are ********* user, is recomened to post in ******** section to get corect help
The Following User Says Thank You to orbita For This Useful Post:
Old 06-29-2015, 18:57   #36 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,786
As supporter said, next time write in correct section.
Anyway - Here's a quick fix, to return phone to stock (locked) and working state :
- Download eMMC RAW tool - HERE
- Put Phone to Download mode with OTU Updater (when start reading phone info, OTU will switch it to DL state), or use key combo vol up + power on, etc.
- Open Raw EMMC tool, read "traceability" partition (pro_info), edit with some hex editor, put desired PID
- Write partition back to phone
- Restart phone with holding power on button longer, will reboot
- Use OTU updater to update phone
that's it.
PID List :
5042A-2[X=D,S]TLMX1
5042A-2[X=D,S,B]TLCL1
5042A-2[X=B,D,S]TLPE3
5042A-2[X=B,D,S]TLCO1
5042A-2[X=D,S,B]TLUY1
5042A-2[X=S]TLGT1
5042A-2[X=D,S]TLBR1
5042A-J[X=D,S]TLBR1
5042A-2[X=B]TLAR1
5042A-H[X=B]TLAR1
5042A-2[X=B]AVUY3
5042A-2[X=B]AVAR1
5042A-H[X=B]AVAR1
5042A-2[X=B]PSAR1
5042A-H[X=B]PSAR1
5042A-A[X=B]PSAR1
5042A-2[X=D,S]TLNI1
5042A-2[X=D,S]AVDO3
5042A-2[X=D,S]TLEC1
5042A-2[X=B,D,S]TLEC5
5042A-2[X=B,D,S]TLPE5
5042A-2[X=S]LDBO1
p.s. try with original PID first, check in readed file if same as on sticker
b.r.
Alex
__________________
Old 07-20-2015, 00:23   #37 (permalink)
Member: 2430876
Exclamation
power off your phone, and hold both volume keys
Nothing hapend when y hold both volume keys!!!
Old 07-20-2015, 05:32   #38 (permalink)
Member: 975562
Thanks Meter: 46
Change imei is posible?
Old 07-20-2015, 18:51   #39 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,786
Use OTU updater to put it to download mode,
when it starts reading information, unplug cable, and kill process via task manager.
Two things :
1st : changing imei is against the law, so any discussion about it will be deleted.
2nd: imei is in OTP zone, and without patching modem, it will be almost impossible to fake it.
b.r.
Alex
__________________
Old 09-23-2015, 18:11   #40 (permalink)
Member: 2450214
Thanks Meter: 106
OT-5042T (tmobile) scatter file please?
mine is bricked ..
Old 09-23-2015, 19:41   #41 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,786
mine is bricked ..
Read thread from beginning. no scatter/rom files for this model,
it's QUALCOMM platform.
b.r,
Alex
__________________
Old 10-07-2015, 17:12   #42 (permalink)
Member: 921325
Thanks Meter: 20
For bricked devices:
1. use this link
2. run exe file
3. connect pop2 to usb with vol up + vol down pressed
4. wait for com port
5. press download and wait to finish
that's all, you'll have a russian firmware with english language and android 4.4.4 .
credits to seryioo
Old 10-07-2015, 18:59   #43 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,786
1. use this link
2. run exe file
credits to seryioo
First, method works ONLY for devices which have software issues,
it cant help when boot is erased.
Second, provided "auto-restorer" is FOR 5042D (Dual Sim) model, Russian region.
Third, all credits for updater goes to 4pda Russian forum.
b.r.
Alex
__________________
Old 10-08-2015, 08:50   #44 (permalink)
Member: 921325
Thanks Meter: 20
I used this with 5042X single sim and worked fine.
Old 10-08-2015, 15:54   #45 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,786
I didn't say it does not work.
After using it, did you get 2 signal bars on your phone ?
b.r.
Alex
__________________
Page generated in 0.24791 seconds with 9 queries
