Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
07-16-2016, 20:28 | #62 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,786 | Quote:
it would be slow and painful trial-and-error process. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
07-16-2016, 23:31 | #63 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Take a try with THIS package, lets see what will happen. (It's modified unbricker from 7050/5050 model from some of my other posts.) Result should be Qualcomm/Alcatel Port 9006, in device manager, and phone visible by OTU Updater. Important info : If battery is too low, charge it on external power source first, so it should have 3.75-3.8V min. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
07-17-2016, 00:38 | #64 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Update: Try with TEST2 and TEST3 unbrickers. some of those 3 should work ... test them all please. remember ... procedure is (considering you have fully charged phone and hardware is ok): - unpack unbricker - start go.cmd - connect phone to cable - wait for it to finish (it should do something and report error) - in device manager port should change into 9006 port - new device (under hard drives) eMMC something - start OTU Updater and select model 5042 - update phone, all should pass normal - post report
The Following 2 Users Say Thank You to Brka For This Useful Post: |
07-17-2016, 10:48 | #65 (permalink) |
Freak Poster Join Date: May 2014 Location: Boriziny,Madagascar Age: 32
Member: 2178386 Status: Offline Thanks Meter: 10 | here is log.... all failed [config 0x805] programmer=ALTO45_NPRG7627_sec.bin singleimage=8936_msimage.mbn [diag error.0x0001090D] count=1 message="blank-flash:greet-device:error reading packet" last-seen="Sun Jul 17 11:42:31 2016, Afrique de l’Est" first-seen="Sun Jul 17 11:42:31 2016, Afrique de l’Est" chip= chip.sn=0x0 chip.id=0x0 chip.rev=0 chip.sv-sbl=0 qboot.version=2.4 hostname=DS-PC [diag blank-flash] fail=3 pass=0 yield=0.00% dphu=100.00 [diag error.0x00010207] count=2 message="blank-flash:validate-rdl:could not open file" |
07-17-2016, 10:50 | #66 (permalink) |
Member: 2178386 Status: Offline Thanks Meter: 10 | shoud I continue to try with single image mbn from this http://www.mediafire.com/download/wn...17/Qdl9008.zip if I edit qboot.ini |
07-17-2016, 10:58 | #67 (permalink) |
Member: 2178386 Status: Offline Thanks Meter: 10 | my pop 2 is bricked after flashing russian firmare, it's has no fastboot, stock recovery, adb unothorized and has the pid from backup from Seryo wich refuse update from Otu... Phone is kind of bootloop and says battery 0% but I tested battery ok ! and it were fine before flashing and I tested other battery too ! My phone is 5042x single sim |
07-17-2016, 11:02 | #68 (permalink) |
Member: 2178386 Status: Offline Thanks Meter: 10 | [config 0x805] programmer=ALTO45_NPRG7627_sec.bin singleimage=8916_msimage.mbn [diag error.0x00010207] count=1 message="blank-flash:validate-rdl:could not open file" last-seen="Sun Jul 17 11:55:28 2016, Afrique de l’Est" first-seen="Sun Jul 17 11:55:28 2016, Afrique de l’Est" chip= chip.sn=0x13EDD9 chip.id=0x705 chip.rev=0 chip.sv-sbl=0 qboot.version=2.4 hostname=DS-PC [diag blank-flash] fail=1 pass=0 yield=0.00% dphu=100.00 |
07-17-2016, 20:24 | #70 (permalink) | |
That's obligatory. At least 3.8V steady voltage is required. Phone with low or bad battery will appear as 9008 port in any case, tested. After that, there is a great possibility that you may receive success with unbricking. Phone is MSM8916 / Snapdragon 410. You can try files from corresponding folder, from archive you posted. With charged battery, of course. Either you can try it from QPST or provided unbrick tool. b.r. Alex
07-20-2016, 08:16 | #71 (permalink) |
Member: 2178386 Status: Offline Thanks Meter: 10 | Anyone has the rawprogram.xml and patch0.xml for this device ? I have almost all things to buil a qct_sp firmware for this phone but those file.. |
07-20-2016, 21:29 | #72 (permalink) | |
After loading programmer hex/bin + msimage, phone's eMMC becomes visible in device manager, and you get port 9006, after which you can either, use any hdd cloning utility to write boot / whole image or use OTU Updater which will fully fix the phone. b.r. Alex
08-01-2016, 01:00 | #74 (permalink) | |
ie: program.bin and msimage.bin. or ... download attached archive, try to put those two files in qboot folder, edit ini file, programmer=MPRG8916.mbn , singleimage=8916_msimage.mbn keep open device manager, to be able to see if port 9006 appears, together with eMMC storage device, under hard disks tree. one short note ... qboot error is NORMAL thing. If after finished, go.cmd, new port appears, immediately use OTU Updater, it will recognize phone, and restore it to stock condition. b.r. Alex
08-02-2016, 08:54 | #75 (permalink) |
Member: 2178386 Status: Offline Thanks Meter: 10 | Do you know any qualcomm unbricker that uses hex prommare ? I wanna convert this ALTO45_NPRG7627_sec.bin to hex !!!!! Please upload the sahara.xml of 5042x so I can understand which prommamer it is using . Please |
