07-04-2007, 08:18 | #1 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 348801 Status: Offline Thanks Meter: 11 | n70 flashing problem with mt... log is here Phone is in: Phone is not responding, power on phone! ============= Set Flash mode for info ============= VBat is 3.98V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... Using Tx2 Data line. rap3gv2_2nd.fg RAP3Gv3_algo.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006000C192101002200 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000352 PUBLIC_ID( RAP ): 0D500008E1C45551AA545484E2B6B2F7E61C5DD7 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): E9EFF4BFAA5393217CA6B17755FC3E14 ROM_ID( RAP ): F28A211FCEA7B19D --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 2250 0000 0121 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= VBat is 4.00V Vpp pin has 0.97V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 VPP is DISABLED. Using Tx2 Data line. Processing File: RM84_50647301.C0 Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. |
07-04-2007, 08:44 | #4 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: S7°1x'xxx" - E112°4x'xxx"
Member: 128035 Status: Offline Thanks Meter: 317 | Quote:
unthick "using tx2line" in "automatic action while flashing" except you have modify your cable using tx2 line. and try press status query again. if APE still not detected, means hardware problem. regards | |
problem flashing 8800 with mt box | lesansan | MT-BOX | 12 | 11-15-2006 17:53 |
charging problem when i flashed phone with mt-box | SHANU | MT-BOX | 2 | 05-20-2006 15:28 |
6630 flash problem with mt-box | qatareye | MT-BOX | 7 | 02-03-2006 08:40 |
flashing problem with mt-box | obioha | MT-BOX | 9 | 12-28-2005 08:09 |
