Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 09-15-2002, 03:53   #16 (permalink)
Member: 12319
I already updated the file (usimload.zip) in both link above.
Just download it again. It's the new one. ^_^
Old 09-15-2002, 04:01   #17 (permalink)
Member: 12319
edmond:
To make sure the Loader works, wait for 10 seconds AFTER the UniSiemens window has appeared.
There will be an error message from the Loader if it can not patch UniSiemens correctly.
The flashing box only indicates that it is ready to receive input from the user. This is a feature which comes from the UniSiemens, not the Loader.
Old 09-15-2002, 13:45   #18 (permalink)
Member: 15485
Siemens C45 / unisiemens
When i want read flash .. scanning scanning ligth red .. nothing nothing
Old 09-15-2002, 19:37   #19 (permalink)
Member: 12319
edmond:
Make sure your cellphone is TURNED OFF before using UniSiemens.
When "scanning..." with red light flashing, push the power button ONCE.
You may need to press it again, but don't hold the button as you usually do to turn on the phone.
Old 09-19-2002, 14:20   #20 (permalink)
ken
Member: 5472
Yes, it's perfect for me. No more boring -take batt out - take batt in- anymore.
Thank so much...
Old 09-20-2002, 16:34   #21 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
Good Work Jay !!!
Old 09-22-2002, 17:16   #22 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
Works for me under Win2k without problems.
Old 09-22-2002, 21:53   #23 (permalink)
Member: 7690
Thanks Meter: 4
GOOD tested by me on
C45 v06 0089 88C4
Read Flash 1-----100% passed
Read Eeprom 1-----100% passed
Good job
THx!
-=G3=-
Old 10-08-2002, 20:46   #24 (permalink)
Member: 15485
C45
You have luck !!!
I have now my C45 repair by SAV .. now I can't read flash and eeprom .. no nothing
c45 tool no
unisiemens not ok
winswup error connect bootstraploader !
Battery is emtpy
Data cable ok .. ( only i can read general infos imei with cable and soft s35expl .. without read flash !)
Help me
Old 10-08-2002, 21:21   #25 (permalink)
Member: 6265
flash with all34 2.0.5 if it isnt CE20 flash type or with all34 2.0.9 if it is. then a log + a map (bontek dongle) and done
Old 10-09-2002, 11:41   #26 (permalink)
Member: 14395
I have also tried it and it does work. I used WinXP sp1
in compatibility mode.
Read flash 100% ... no problems. did not have to remove battery.
Read eeprom 100% ... but I had to remove the battery.
Still, great work done.
Now I have a backup of my phone, ... eeprom and flash.
very cool!
Old 10-14-2002, 23:43   #27 (permalink)
Location: Jl.Mawar merah 5 Blok D30 No.15 Bekasi Indonesia
Member: 16434
Where I can download the full flash for cm 35 new verions suport indonesia language because i wan to try Unisiemens pls... give me ok!
R26111VL_U_96A00ER not supported on the Boot-Loader V2 s@lwos Smart-Clip 15 03-22-2010 18:23
I at the download firmware of the www.boot-loader.com speed very slow ttlin5188 Smart-Clip 3 05-26-2008 15:52
HELP! LG7100 can not power on after running the photo loader. southriver LG 0 12-27-2003 16:32
Question on UniSiemens loader code? kxn x1x to x45/x50 0 07-06-2003 06:33
Page generated in 0.18519 seconds with 9 queries
