09-12-2004, 05:46 | #152 (permalink) |
Freak Poster Join Date: May 2004 Age: 61
Member: 66180 Status: Offline Thanks Meter: 0 | Profil pod zasięgiem, status wibracji pod baterią, temperatura i napięcie naprzemian na baterii: M55 V10 Kod: 0DCCF1: 2DCCC4 3700F5 17F500: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2DCCC4DA8CF8BBC08CF0ECE6FC4301 17F510: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 00ECE01CE08DDA2DCCC4FA9F0009 7F0900: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CC00CC00D7400C00F2F100009AF14C00 7F0910: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7401100F2F1E020F6F10EFEE6FFE803 7F0920: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5BFFF2FE0EFEF2FF0CFEE02DE6FC4F00 7F0930: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FE190088F0DA2DCCC4E6FE2300E02D 7F0940: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC5200DA2DCCC498F0F6FF0EFEE6FF 7F0950: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 64005BFFF2FE0EFEF2FF0CFEE02DE6FC 7F0960: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 550006FE190088F0DA2DCCC498F0F6FF 7F0970: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFEE0AF5BFFF2FE0EFEF2FF0CFEE02D 7F0980: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC590006FE190088F0DA2DCCC498F0 7F0990: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FF0EFEF2FE0EFEE02DE6FC5D0006FE 7F09A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1900DA2DCCC40D44D7401100F2F1E220 7F09B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 26F1AA0AF6F10EFEE6F164005B11F2FE 7F09C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFEF2FF0CFEE02DE6FC4F0006FE1900 7F09D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88F0DA2DCCC498F0F6FF0EFEE0AF5BFF 7F09E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE0EFEF2FF0CFEE02DE6FC530006FE 7F09F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 190088F0DA2DCCC4E6FC5600E02DE6FE 7F0A00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2300DA2DCCC498E0E02DE6FC5A0006FE 7F0A10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1900DA2DCCC4E6FE2400E02DE6FC5E00 7F0A20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2DCCC40FF1D7400C00F6F100000D05 7F0A30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EF1D7400C00F6F10000D7400D00F2FF 7F0A40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF EE1C9AFF03F0E6FE4A010D02E6FE4B01 7F0A50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC4A00E08DDA2DCCC4DB00FFFFFFFF for GFX pls click here http://www.siemensinfo.pl/patch/Bo$s...i%20cyfry.rar: password :www.forum.siemensinfo.pl |
09-21-2004, 08:31 | #154 (permalink) |
Junior Member Join Date: Jul 2003 Location: SPb Age: 40
Member: 32993 Status: Offline Thanks Meter: 0 | 4.08MB v2 ;***Increase discA to 4,278,191bytes (4.08MB) v2*** ;M55v10 download Full T9base with length up to 192kb. (En T9 ~30kb). It's possible to use place of standart rings for pics (~100kb). EEFS moved to DF and now backuped with standart settings of V_Klay when backuping EEPROM (fromC0000 len:40000). Compatible with all patches FW10, but need to install to clear FF. Uncompatible with graphic patches and patches that change string in original langpack. If graphic patch was installed - it will be saved. Change pictures after install this patch you can by PicPac using included free.ini. There only one PIT left in phone. You'll need a PicPac to install this patch. FF with patch you can download here. Last edited by Sep.; 09-23-2004 at 07:13. Reason: some improvements |
09-23-2004, 09:39 | #155 (permalink) |
Freak Poster Join Date: Jan 2004 Location: www.SiemensXP.com Age: 45
Member: 49922 Status: Offline Thanks Meter: 0 | ; A melody for everyone in a directory. (C) ZH-Soft ; M55 v91 ; Play only mid ; to put a melody - a name of a file it is necessary to enter in field Email2 ; if to leave his empty - will play standard for the given group ; a name of a file no more than 14 symbols, not important even or odd кол-in ; to enter together with expansion ; melodies should be in folder A:\Sounds\ 11C3F0: E6FE3E37 DA9F503F 11C3F8: DAA4A44C cc00cc00 007F3F50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0D7400D00F2FC5C1948C02D46 007F3F60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700D00F2FC5C19F2FD5E19F2FE6019 007F3F70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF6219D7700A00F6FC4837F6FD4A37 007F3F80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE4C37F6FF4E37D7700D00F2FC6419 007F3F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FD6619F2FE6819F2FF6A19D7700A00 007F3FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC5037F6FD5237F6FE5437F6FF5637 007F3FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC413AE6FD5C53E6FE6F75D7600A00 007F3FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC3E37F6FD4037F6FE4237E6FC6E64 007F3FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD735CD7500A00F6FC4437F6FD4637 007F3FE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE3E37E0AF98D098C0DB00E6FE3E37 007F3FF0: FFFFFFFFFFFFFFFFFFFF E0AF98D098C0FAA4A44C |
09-24-2004, 03:29 | #156 (permalink) |
Member: 49922 Status: Offline Thanks Meter: 0 | ; A melody for everyone in a directory. (C) ZH-Soft ; M55 v11 ; Play only mid ; to put a melody - a name of a file it is necessary to enter in field Email2 ; if to leave his empty - will play standard for the given group ; a name of a file no more than 14 symbols, not important even or odd кол-in ; to enter together with expansion ; melodies should be in folder A:\Sounds\ 11C3F0: E6FE3E37 DA9F503F 11C3F8: DAA4CA4B cc00cc00 007F3F50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0D7400D00F2FC5C1948C02D46 007F3F60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700D00F2FC5C19F2FD5E19F2FE6019 007F3F70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF6219D7700A00F6FC4837F6FD4A37 007F3F80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE4C37F6FF4E37D7700D00F2FC6419 007F3F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FD6619F2FE6819F2FF6A19D7700A00 007F3FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC5037F6FD5237F6FE5437F6FF5637 007F3FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC413AE6FD5C53E6FE6F75D7600A00 007F3FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC3E37F6FD4037F6FE4237E6FC6E64 007F3FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD735CD7500A00F6FC4437F6FD4637 007F3FE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE3E37E0AF98D098C0DB00E6FE3E37 007F3FF0: FFFFFFFFFFFFFFFFFFFF E0AF98D098C0FAA4CA4B @ M55us3r : You're posting in the wrong section! this thread for patch ONLY! |
09-25-2004, 06:02 | #157 (permalink) |
Member: 32993 Status: Offline Thanks Meter: 0 | Archive with pics from patch ***menu in XPstyle 24BPP*** Menu repainted to 4096colors. You can see it on picture. In archive color scheme, file with zones for Photoshop and 2 dirs with different versions of patch: 1st - big pics of menu aren't cross border, 2nd - big pics are cross over border. download |
09-26-2004, 04:50 | #158 (permalink) |
Member: 66180 Status: Offline Thanks Meter: 0 | ; M55V10: MULTI-INDICATOR ;REMAKED BY Anuroj_007 fROM ; M55V11/V91: MULTI-INDICATOR ; (C)ZH-Soft, ACiD (P)AlexSid, !Freeman!, lalo.lerry (I)KoTsK ; + NETWORK PEAK LEVEL (dB) ; + BATTERY LEVEL (%) ; + ENVIRONMENT TEMPERATURE (°C) ; + VIBRA INDICATOR ; + PROFILE INDICATOR ; !!! Need patch: GFX KOTSK.VKP( in POST#126) 0DCCF0: DA2DCCC4 DA9F9008 7F0890: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2DCCC4D7400900F2F1663AE103F6F1 7F08A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFEE6FF64005BFFF2FE0EFEF2FF0CFE 7F08B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E04CE0AD06FE190088F0DA2DCCC498F0 7F08C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FF0EFEE0AF5BFFF2FE0EFEF2FF0CFE 7F08D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E08CE0AD06FE190088F0DA2DCCC498E0 7F08E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0CCE0AD06FE1900DA2DCCC4E00CE0AD 7F08F0: FFFFFFFFFFFFFFFFFFFFFFFF E6FE2500DA2DCCC4FA9F0009 #pragma enable old_equal_ff 7F0900: DA2DCCC4D7401300F2F1EA27F6F10EFE 7F0910: E6FF64005BFFF2FE0EFEF2FF0CFEE6FC 7F0920: 4A00E6FD000006FE290088F0DA2DCCC4 7F0930: 98F0F6FF0EFEE0AF5BFFF2FE0EFEF2FF 7F0940: 0CFEE6FC5000E6FD000006FE290088F0 7F0950: DA2DCCC498F0F0EFE6FC5600E6FD0000 7F0960: 06FE2900DA2DCCC4FA9F9209 7F0992: DA2DCCC4D7401100F2F1E22026F1 7F09A0: AA0AF6F10EFEE6F164005B11F2FE0EFE 7F09B0: F2FF0CFEE0ADE6FC500006FE190088F0 7F09C0: DA2DCCC498F0F6FF0EFEE0AF5BFFF2FE 7F09D0: 0EFEF2FF0CFEE0ADE6FC540006FE1900 7F09E0: 88F0DA2DCCC4E6FC5800E0ADE6FE2300 7F09F0: DA2DCCC498E0E0ADE6FC5A0006FE1900 7F0A00: DA2DCCC4E6FE2400E0ADE6FC5E00DA2D 7F0A10: CCC4FA9F200A 7F0A20: DA2DCCC40FF1D7400C00F6F100000D05 7F0A30: 0EF1D7400C00F6F10000D7400D00F2FF 7F0A40: EE1C9AFF03F0 7F0A46: E6FEAF01 ;#1AFh ---> FirstPictureNumber.VibraOn 7F0A4A: 0D02 7F0A4C: E6FEB001 ;#1B0h ---> FirstPictureNumber.VibraOff 7F0A50: E6FC3600 ;#036h ---> Xpos.Vibra 7F0A54: E0AD ;#00Ah ---> Ypos.Vibra 7F0A56: DA2DCCC4FA9F800A 7F0A80: DA2DCCC4DA8CF8BBC08CF0EC 7F0A8C: E6FC3300 ;#33h ---> FirstPictureNumber.Profile 7F0A90: 00EC 7F0A92: E6FC1600 ;#16h ---> Xpos.Profile 7F0A96: E0AD ;#0Ah ---> Ypos.Profile 7F0A98: DA2DCCC4DB00 #pragma disable old_equal_ff /* 23/08/2004 - !!! gfx kotsk.vkp is updated !!! - 025..040 = small font 0..9, ., °C, -, K, M, % - 041..050 = battery digit 0..9 - 051..057 = profile indicators - 058..070 = digital clock 2-bit - 228 = full screen blank-in-black analog clock - 323..329 = profile indicators 2-bit - 332..344 = digital clock 1-bit - 351..356 = net signal 1 (numeric) - 357..362 = net signal 2 (numeric) - 364..379 = battery icons (charging pictures fixed!) - 431..432 = vibra indicators - 448..453 = net signal (numeric) - PIT-tables fixed! |
09-27-2004, 02:19 | #159 (permalink) |
Member: 49922 Status: Offline Thanks Meter: 0 | ; Melody for everyone in a directory. v1.1 (C) ZH-Soft ; M55 v91 ; Пофиксен a bug with recurrence of a melody. ; to put a melody - a name of a file it is necessary to enter in field Email2 ; if to leave his empty - will play standard for the given group ; a name of a file no more than 15 symbols together with expansion. ; to enter together with expansion ; to put on the person mid - it (чел) should be in group ; on which it is put by default mid. ; and to put wav - in group on which by default costs wav. ; melodies should be in folder A:\Sounds\ 11C3F0: E6FE3E37 DA9F503F 11C3F8: DAA4A44C cc00cc00 007F3F50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0D7700D00F2FC5C19F2FD5E19 007F3F60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE6019F2FF621948C02D40D7700A00 007F3F70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC4837F6FD4A37F6FE4C37F6FF4E37 007F3F80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700D00F2FC6419F2FD6619F2FE6819 007F3F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF6A19D7700A00F6FC5037F6FD5237 007F3FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE5437F6FF5637E6FC413AE6FD5C53 007F3FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE6F75D7600A00F6FC3E37F6FD4037 007F3FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE4237E6FC6E64E6FD735CD7500A00 007F3FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC4437F6FD4637D7400D00F68E5C19 007F3FE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE3E37E0AF98D098C0DB00E6FE3E37 007F3FF0: FFFFFFFFFFFFFFFFFFFF E0AF98D098C0FAA4A44C -------------------------------------------------------------------------- ; Melody for everyone in a directory. v1.1 (C) ZH-Soft ; M55 v11 ; Пофиксен a bug with recurrence of a melody. ; to put a melody - a name of a file it is necessary to enter in field Email2 ; if to leave his empty - will play standard for the given group ; a name of a file no more than 15 symbols together with expansion. ; to enter together with expansion ; to put on the person mid - it (чел) should be in group ; on which it is put by default mid. ; and to put wav - in group on which by default costs wav. ; melodies should be in folder A:\Sounds\ 11C3F0: E6FE3E37 DA9F503F 11C3F8: DAA4CA4B cc00cc00 007F3F50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0D7700D00F2FC5C19F2FD5E19 007F3F60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE6019F2FF621948C02D40D7700A00 007F3F70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC4837F6FD4A37F6FE4C37F6FF4E37 007F3F80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700D00F2FC6419F2FD6619F2FE6819 007F3F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF6A19D7700A00F6FC5037F6FD5237 007F3FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE5437F6FF5637E6FC413AE6FD5C53 007F3FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE6F75D7600A00F6FC3E37F6FD4037 007F3FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE4237E6FC6E64E6FD735CD7500A00 007F3FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC4437F6FD4637D7400D00F68E5C19 007F3FE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE3E37E0AF98D098C0DB00E6FE3E37 007F3FF0: FFFFFFFFFFFFFFFFFFFF E0AF98D098C0FAA4CA4B -------------------------------------------------------------------------- ; Melody for everyone in a directory. v1.1 (C)ZH-Soft (p)Sep. ; M55 v10 ; Пофиксен a bug with recurrence of a melody. ; to put a melody - a name of a file it is necessary to enter in field Email2 ; if to leave his empty - will play standard for the given group ; a name of a file no more than 15 symbols together with expansion. ; to enter together with expansion ; to put on the person mid - it (чел) should be in group ; on which it is put by default mid. ; and to put wav - in group on which by default costs wav. ; melodies should be in folder A:\Sounds\ 11B258: E6FE0E37 DA5560B4 11B260: DAA43C3F cc00cc00 35B460: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0D7700D00F2FC2219F2FD2419 35B470: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE2619F2FF281948C02D40D7700A00 35B480: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC1837F6FD1A37F6FE1C37F6FF1E37 35B490: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700D00F2FC2a19F2FD2c19F2FE2e19 35B4A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF3019D7700A00F6FC2037F6FD2237 35B4B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE2437F6FF2637E6FC413AE6FD5C53 35B4C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE6F75D7600A00F6FC0E37F6FD1037 35B4D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE1237E6FC6E64E6FD735CD7500A00 35B4E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC1437F6FD1637D7400D00F68E2219 35B4F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE0E37E0AF98D098C0DB00E6FE0E37 35B500: FFFFFFFFFFFFFFFFFFFF E0AF98D098C0FAA43C3F |
10-03-2004, 18:43 | #160 (permalink) |
Junior Member Join Date: Aug 2004 Location: Poland Age: 38
Member: 78197 Status: Offline Thanks Meter: 0 | Multi Indicator with new pictures (for v11/91) www.forum.siemensinfo.pl |
10-12-2004, 10:34 | #161 (permalink) |
Junior Member Join Date: Aug 2004 Age: 34
Member: 77887 Status: Offline Thanks Meter: 0 | Style XP M55 STYLE XP M55 Of the of images I have found online her others I have done her everything added and I I would say that the transformation is valid P.S.: the patches are all for the version 11 Animation of start Patch: http://members.xoom.virgilio.it/rikka171/G... rt_xp_style.vkp Images: http://members.xoom.virgilio.it/rikka171/G... / boot_img_1.zip Animation of closing Patch: http://members.xoom.virgilio.it/rikka171/G... ra_xp_style.vkp Images: http://members.xoom.virgilio.it/rikka171/G... hutdown_img.zip Animation PIN Patch: anchor have not done her, cmq under find the images to do her/it from you!!! Images: http://members.xoom.virgilio.it/rikka171/G... Pin/pin_img.zip Animation if don't have the PIN Patch: http://members.xoom.virgilio.it/rikka171/G... _nopin__v11.vkp Images: http://members.xoom.virgilio.it/rikka171/G... n_nopin_img.zip Sounds for lighting and spengimento Start: http://members.xoom.virgilio.it/rikka171/G... ounds/Start.wav Shutdown: http://members.xoom.virgilio.it/rikka171/G... ds/Shutdown.wav Colour scheme This is decidedly from migliorare,ma I don't have a lot of time... if you want to contribute you are the welcome ones http://members.xoom.virgilio.it/rikka171/G... Win%20XP_v2.col Menù Patch: http://members.xoom.virgilio.it/rikka171/G... le_menu_v11.vkp Images: http://members.xoom.virgilio.it/rikka171/G... le_menu_img.zip You play On/Off/Beep Patch: http://members.xoom.virgilio.it/rikka171/G... _on_off_v11.vkp Bloccotasti Patch: http://members.xoom.virgilio.it/rikka171/G... _v11.vkp |
10-12-2004, 10:36 | #162 (permalink) |
Member: 77887 Status: Offline Thanks Meter: 0 | VERY MANY MANY WALLPAPERSS STYLE XP!!! http://notasite.gamersrevolt.it/Host...wallpapers.rar |
10-12-2004, 10:38 | #163 (permalink) |
Member: 77887 Status: Offline Thanks Meter: 0 | Very beautiful Lighting and turning off Scorpio M55!!!! http://barcello.altervista.org/M55/A..._scorpione.zip To unload the file owe to make to save with name Last edited by Barcello; 10-13-2004 at 12:40. |
10-23-2004, 06:08 | #164 (permalink) |
Member: 66180 Status: Offline Thanks Meter: 0 | ; Show Batt Volt Patch ; Multi-Indicator Patch M55 v10 must be patched before!! 7F0A9C: DB00FFFF FA9FA00A 7F0AA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2DCCC4D7401100F2F1E020F6F10EFE 7F0AB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FFE8035BFFF2FE0EFEF2FF0CFEE6FD 7F0AC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1200E6FC500006FE190088F0DA2DCCC4 7F0AD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE2300E6FD1200E6FC5400DA2DCCC4 7F0AE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98F0F6FF0EFEE6FF64005BFFF2FE0EFE 7F0AF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF0CFEE6FD1200E6FC560006FE1900 7F0B00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88F0DA2DCCC498F0F6FF0EFEE0AF5BFF 7F0B10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE0EFEF2FF0CFEE6FD1200E6FC5A00 7F0B20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FE190088F0DA2DCCC498E0E6FD1200 7F0B30: FFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC5E0006FE1900DA2DCCC4DB00 Last edited by anuroj_007; 10-23-2004 at 10:59. |
10-28-2004, 13:21 | #165 (permalink) |
Junior Member Join Date: Oct 2004 Age: 34
Member: 88849 Status: Offline Thanks Meter: 0 | ; Upgrade disk А up to 3,5 mb !!! [B]; Upgrade your disc A up to 3.5 mb ; (с)Def nightmare; M55v11 M55v91 ; 1. Copy full file system from disc A & B to PC ; Disc B - if it opened and if you have cool info there. ; we do not need to move "graphcach " file from it ; 2. unchech "V" from MENU|SETUP|display with logo at On and OFF ; 3. Switch OFF the phone ; 4. READ FULL FLASH (BACKUP) from phone ; 5. WRITE PATCH to phone ; 6. WRITE this file http://alexsid.antex.ru/dn.php?file=...A0000_11_2.rar ; address: 0x5A0000 , size: 0x20000 , offset: 0 ; This is patched lang pack (2 second LG) edited by author. ; You can use other lang pack from 11 version BUT size must be low than ; 0x20000 b ; 7. write this file http://alexsid.antex.ru/dn.php?file=...000_11_rus.rar ; address: 0x680000 , size: 0x20000 , offset: 0 ; THIS file have RUSSIAN T9 ONLY ; you must Use Winrar for files from 5 and 6 item ; 8. SWITCH ON the phone ; It is switch on with blue display- it is O.K. ....it is format the Disc ;(3 minuts) ; Wait ; 9. We must use DES to access disc A (go to disc A) ; 10. go to Address book ; and rename all files *.adr to *.ad_ and .lock to .loc_ ; 11. go to PersistentData\SMS ; and rename SMS.dat to SMS.da_ ; 12. Copy from backuped disc A (4 item )and B to new disc A ; Disc B is 256 kb now ! ; 13. Switch OFF and SWITCH ON the phone ; 14. go to Address book ; and delete all files *.ad_ and .loc_ ; 15. go to PersistentData\SMS ; and delete this file SMS.da_ ; 16. Switch OFF and SWITCH On the phone.. ; Congratulations with worked phones ; BUT!!!!! do not use ANIMATION at switch on /OFF after this patch ; Check Java app. if they not run ; (still "please wait") - we have problems .... ; first try to change Developer Menu|Java|Trace Level (if can be after enable ; NetMonitor (which we have at Developer Menu). ; if Java still not working - write backup from 4 ... ; ;*** PUT "GREY" phones to first (main) PIT-table *** ; © SiNgle (P) AlexSid 362AAA: 40195501 00004201 362AC0: 5601 4201 362AD2: 08185601 00004201 ;*** www.remove_links_to_graphcach_v3 *** © !Freeman! ; transformed for M55v11 by AlexSid ;UNCKECH startup logo/ animation at swith on off and remove file-graphcach from disc B 4574B5: 67726170686361636800 FFFFFFFFFFFFFFFFFFFF 4574E2: 423A5C00 00000000 ; table of blocks from Disc A 4269B4: 200000000100F4288901 1E000000020000127C02 #pragma disable warn_if_new_exist_on_apply ; размер EEFS 427856: 03 01 #pragma enable warn_if_new_exist_on_apply ; Size of dosc B 426A40: 07 01 ; Blocks of new disc B 4269EC: 0000A8004000 0000FF004000 7F1000: FFFFFFFFFFFF 0000D0004000 7F1006: FFFFFFFFFFFF 0000D1004000 7F100C: FFFFFFFFFFFF 0000D2004000 7F1012: FFFFFFFFFFFF 0000D3004000 7F1018: FFFFFFFFFFFF 0000D4004000 7F101E: FFFFFFFFFFFF 0000D5004000 7F1024: FFFFFFFFFFFF 0000D6004000 7F102A: FFFFFFFFFFFF 0000D7004000 7F1030: FFFFFFFFFFFF 0000D8004000 7F1036: FFFFFFFFFFFF 0000D9004000 7F103C: FFFFFFFFFFFF 0000DA004000 7F1042: FFFFFFFFFFFF 0000DB004000 7F1048: FFFFFFFFFFFF 0000DC004000 7F104E: FFFFFFFFFFFF 0000DD004000 7F1054: FFFFFFFFFFFF 0000DE004000 7F105A: FFFFFFFFFFFF 0000DF004000 7F1060: FFFFFFFFFFFF 0000E0004000 7F1066: FFFFFFFFFFFF 0000E1004000 7F106C: FFFFFFFFFFFF 0000E2004000 7F1072: FFFFFFFFFFFF 0000E3004000 7F1078: FFFFFFFFFFFF 0000E4004000 7F107E: FFFFFFFFFFFF 0000E5004000 7F1084: FFFFFFFFFFFF 0000E6004000 7F108A: FFFFFFFFFFFF 0000E7004000 7F1090: FFFFFFFFFFFF 0000E8004000 7F1096: FFFFFFFFFFFF 0000E9004000 7F109C: FFFFFFFFFFFF 0000EA004000 7F10A2: FFFFFFFFFFFF 0000EB004000 7F10A8: FFFFFFFFFFFF 0000EC004000 7F10AE: FFFFFFFFFFFF 0000ED004000 7F10B4: FFFFFFFFFFFF 0000EE004000 7F10BA: FFFFFFFFFFFF 0000EF004000 7F10C0: FFFFFFFFFFFF 000076004000 7F10C6: FFFFFFFFFFFF 000077004000 7F10CC: FFFFFFFFFFFF 000078004000 7F10D2: FFFFFFFFFFFF 000079004000 7F10D8: FFFFFFFFFFFF 00007C004000 7F10DE: FFFFFFFFFFFF 00007D004000 7F10E4: FFFFFFFFFFFF 00007E004000 7F10EA: FFFFFFFFFFFF 00007F004000 7F10F0: FFFFFFFFFFFF 0000F8004000 7F10F6: FFFFFFFFFFFF 0000F9004000 7F10FC: FFFFFFFFFFFF 0000FA004000 7F1102: FFFFFFFFFFFF 0000FB004000 ;T9 7F1108: FFFFFFFFFFFF 00008A004000 7F110E: FFFFFFFFFFFF 00008B004000 ;EE_FS 7F1114: FFFFFFFFFFFF 0000BD004000 7F111A: FFFFFFFFFFFF 0000BE004000 ;Disk_B 7F1120: FFFFFFFFFFFF 0000AB004000 7F1126: FFFFFFFFFFFF 0000AC004000 7F112C: FFFFFFFFFFFF 0000AD004000 7F1132: FFFFFFFFFFFF 0000AE004000 ;PIT 7F1138: FFFFFFFFFFFF 000051004000 7F113E: FFFFFFFFFFFF 000052004000 7F1144: FFFFFFFFFFFF 000053004000 7F114A: FFFFFFFFFFFF 000054004000 ;Disk_B 7F1150: FFFFFFFFFFFF 0000A7004000 7F1156: FFFFFFFFFFFF 0000A8004000 7F115C: FFFFFFFFFFFF 0000A9004000 7F1162: FFFFFFFFFFFF 0000AA004000 7F1200: FFFFFFFFFFFF 020000107C02 7F1206: FFFFFFFFFFFF 02000C107C02 7F120C: FFFFFFFFFFFF 020018107C02 7F1212: FFFFFFFFFFFF 020024107C02 7F1218: FFFFFFFFFFFF 020030107C02 7F121E: FFFFFFFFFFFF 02003C107C02 7F1224: FFFFFFFFFFFF 020048107C02 7F122A: FFFFFFFFFFFF 020054107C02 7F1230: FFFFFFFFFFFF 020060107C02 7F1236: FFFFFFFFFFFF 02006C107C02 7F123C: FFFFFFFFFFFF 020078107C02 7F1242: FFFFFFFFFFFF 020084107C02 7F1248: FFFFFFFFFFFF 020090107C02 7F124E: FFFFFFFFFFFF 02009C107C02 7F1254: FFFFFFFFFFFF 0200A8107C02 7F125A: FFFFFFFFFFFF 0200B4107C02 7F1260: FFFFFFFFFFFF 0200C0107C02 7F1266: FFFFFFFFFFFF 0200CC107C02 7F126C: FFFFFFFFFFFF 0200D8107C02 7F1272: FFFFFFFFFFFF 0200E4107C02 7F1278: FFFFFFFFFFFF 0200F0107C02 7F127E: FFFFFFFFFFFF 0200FC107C02 ;T9 7F1284: FFFFFFFFFFFF 020008117C02 ;EE_FS 7F128A: FFFFFFFFFFFF 020014117C02 ;EE_FS 7F1290: FFFFFFFFFFFF 020020117C02 7F1296: FFFFFFFFFFFF 02002C117C02 ;PIT 7F129C: FFFFFFFFFFFF 020038117C02 7F12A2: FFFFFFFFFFFF 020044117C02 ;Disk_B 7F12A8: FFFFFFFFFFFF 020050117C02 7F12AE: FFFFFFFFFFFF 02005C117C02 #pragma disable warn_no_old_on_apply B00080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B10080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B20080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B30080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B40080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B50080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B60080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B70080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B80080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B90080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BA0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BC0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BD0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BE0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BF0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C00080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C10080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C20080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C30080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C40080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C50080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C60080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C70080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C80080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C90080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CA0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CB0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CC0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CD0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CE0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CF0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 560080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 570080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 580080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 590080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5D0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5F0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D80080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D90080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DB0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ;EE_FS 9C0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ;PIT 310080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 320080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 330080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 340080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ;Disk_B 870080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 880080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 890080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8A0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8B0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8C0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ; Format new Disk_B DF0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF #pragma enable warn_no_old_on_apply edited and translated by zdob Last edited by zdob; 11-04-2004 at 19:46. |
m55 v10 patches (some new, some old) | |FeRRaRi| | E-Gold Based Phones | 11 | 12-12-2004 03:41 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
M55 Graphic Patches | iccume | x4x, x5x Flashpatching | 17 | 03-06-2004 18:24 |
m55 v11 patches (some new, some old) | |FeRRaRi| | E-Gold Based Phones | 4 | 02-27-2004 03:17 |
dead m55 after freia m55 AMD patch | lypen17 | E-Gold Based Phones | 3 | 02-27-2004 00:30 |
