10-31-2004, 07:03 | #166 (permalink) |
Insane Poster Join Date: May 2004 Location: India Age: 52
Member: 67256 Status: Offline Thanks Meter: 0 | ;© Matr!x - 29/04/2004' ;Ported to V91 by Spool 0E637E: DA2E6485 CC00CC00 0E639C: DA220841 CC00CC00 |
11-01-2004, 20:37 | #167 (permalink) |
Junior Member Join Date: Oct 2004 Age: 40
Member: 89088 Status: Offline Thanks Meter: 0 | ; deletes the softkeys from mainscreen ; Author: SiNgle, ACiD [mrp] ; Phone: M55v11 ; Loader: V-Klay 2.4+ / M55 0D5824: 3D05 CC00 0D5746: 2D04 0D04 ; press right_key to start the menu |
11-04-2004, 07:59 | #168 (permalink) |
Member: 67256 Status: Offline Thanks Meter: 0 | Originally Posted by Spool ;*** DevMenu without any special number in SIM *** ;M55 v91 ;Author: Spool ;Based in a patch for C55 0BD9F4: 2D 0D ;Mark the next line if you have already applied the DevMenu activation patch 80177A: 2D 0D Last edited by zdob; 11-07-2004 at 16:45. |
11-07-2004, 08:03 | #169 (permalink) |
Member: 67256 Status: Offline Thanks Meter: 0 | ; SlowLightUp ; (c) SiNgle ; 28.11.03 ; ver 1.0 ; Ported to M55v91 by Spool 80D632: DAA0E6D5 DA5540B0 ; Keyb,sms... 35b040: FFFFFFFFFFFFFFFFFFFF E6FE0004DAA0E6D5DB00 ; Patch 80D71C: DA9F7475 DA5540B0 ; After Phone ON |
11-07-2004, 19:08 | #170 (permalink) |
Member: 67256 Status: Offline Thanks Meter: 0 | ;Short vibra in outgoing call, when other side is picking up the phone v1.4 ; © Matr!x ;Ported to M55v91 by Spool 01B6DE: DAA2CE41 CC00CC00 01F1B0: DA2116F7 DA5522DB 35DB00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400D00F2FF202348F02D01DB00E01F 35DB10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400D00F6FF2023E6FC2F00FAA2CE41 35DB22: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CD7400D00F6FC2023E6FC2F00FAA2 35DB32: FFFF AA39 768E7E: F2FD02FE DA5500DB ;35DB23: 0C 1C ;Sostituire la vibrazione in un suono ;35DB2E: 2F 01 ;Sostituire con un valore della lista suoni |
11-16-2004, 13:58 | #171 (permalink) |
Junior Member Join Date: Oct 2004 Age: 34
Member: 88849 Status: Offline Thanks Meter: 0 | ; M55V91: Flash lights + other type of sound when some keys pressed ; M55V91: Flash lights + other type of sound when some keys pressed ; © Def ; ; Plz set the Key tone as described below: ; Menu > Setup > Keys > Key tones > Click 823F30: E048EA00A43F DA5570D2CC00 #pragma enable old_equal_ff 35D270: DA55B0D2E03CE6FD6400E00EDA9F7475 35D280: E03CE00DE6FE0004DA9F7475E01CE02C 35D290: E6FD6400E00EDA9F7475E02CE00DE6FE 35D2A0: 0004FA9F7475E01C 35D2B0: E6FC0400 ;#0004h = tone 35D2B4: FAA2AA39 #pragma disable old_equal_ff ; enable these lines if you need another tone ;35D2B2: 04 18 ;35D2B4: FA DA ;#pragma enable old_equal_ff ;35D2B8: E6FC1300FAA2AA39 ;#pragma disable old_equal_ff ;enable this line to turn off tone ;35D270: DA55B0D2 CC00CC00 ;enable this line to turn off dyn. light ;35D274: E03C DB00 |
01-17-2005, 18:15 | #174 (permalink) |
No Life Poster Join Date: Nov 2002 Location: INDONESIA
Member: 17360 Status: Offline Thanks Meter: 1 | M55v11: Unhide All Provider Pictures (fixed!) ; M55V11: UNHIDE ALL PROVIDER PICTURES (FIXED!) ; © KoTsK, based on SiNgle & AlexSid patch + move all PITs to PIT2. previously it was PIT1. + no more pic corrupt + remove PIT1, 3 and 4. apply the BIN files first, then the VKP/TXT patch. |
01-29-2005, 16:42 | #175 (permalink) |
Junior Member Join Date: Jan 2005 Age: 49
Member: 110833 Status: Offline Thanks Meter: 0 | Replace Sim Application Toolkit Menu, M55 FW91 ;REPLACE SIM APPLICATION TOOLKIT MENU ; ;Firmware: M55 FW91 ;Author: LittleBro ;Release: 2005-01-29 ;Description: substitutes SAT menu with menu item to change phone code ; ; ;entry points, SAT menu -> change phone code ; 0x3685CE: 529C 56B0 0x3685D2: 5A9C 56B0 ; ;rename menu item ; 0x36861F: 273A27 06F305 |
01-29-2005, 16:52 | #176 (permalink) |
Member: 110833 Status: Offline Thanks Meter: 0 | Date on MainScreen as Di 09 Dez ver 0.1b, German ; Date on MainScreen as Di 09 Dez ver 0.1b, German ;! patch will only work with DATE FORMAT = MM/DD/YYYY ;! Go to Menu: 9-6-3-2 then Select. ; (c) SiNgle ; 09.12.03 ; M55 v91 ;converted & tested for v91 by nagual ;converted into German version by LittleBro's Bro 0D5862: E077 E0D7 9FD7AA: DABFB2D3 DA5580B2 0035B280: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 889088808860D460060046F60D003D56 0035B290: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F09FF08E8880889088C088D0DABF90CB 0035B2A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 68475C14D7405601D414403398D098C0 0035B2B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98909880DC49B8180882E7F22000DC49 0035B2C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B9285044DC4DF48C0300E0A5F6F40EFE 0035B2D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D1004B55CC00F2F50EFE06F53000F015 0035B2E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F50CFE06F530005C857015DC59E428 0035B2F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0100E4380200E7F22000DC49E4280300 0035B300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 08845044DC4DF48C020028415C2406F4 0035B310: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4E33D7405601A8140842D7405601A944 0035B320: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E105DC79B928E4380100E4480200E458 0035B330: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 03000884986098809890DB00FABFB8D3 0035B340: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4D6F44694D69446F46725361536F4A61 0035B350: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6E00466562004D617200417072004D61 0035B360: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 69004A756E004A756C00417567005365 0035B370: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 70004F6B74004E6F760044657A00 |
02-01-2005, 01:11 | #177 (permalink) |
Member: 110833 Status: Offline Thanks Meter: 0 | Hide Sim Application Toolkit Menu ;HIDE SIM APPLICATION TOOLKIT MENU ; ;Firmware: M55 FW91 ;Author: LittleBro ;Release: 2005-02-01 ;Description: removes SAT menu ; ; 0x36862A: 5F05 0502 0x36863C: 5F05 0502 |
02-02-2005, 11:48 | #178 (permalink) |
No Life Poster Join Date: Dec 2000 Age: 44
Member: 2911 Status: Offline Thanks Meter: 3 | [GLOW=red]This is topic for patch only. Other reply 'll be deleted. Use other topics for discussing.. [/GLOW] P.S. If you not so silly then do not do it again.........because i see a lot of people which don't respected our work and still post stupid messages in this section ...... Thread for discussing: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! RESPECT THE AUTHORS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! The list of the members which are not respecting the authors: waiting ...... |
02-02-2005, 19:40 | #179 (permalink) |
Member: 17360 Status: Offline Thanks Meter: 1 | *** PIT MOD *** nothing new ... i dont know yet what need to mod next i'm just want to share my pics KOTSK_20.BIN (attached) The BIN file is a partial part of my M55V11 fubu that contains all 769 default pictures (most of them are modded). Btw this BIN file also contains the character graphics, which are usually can be modded by SiemensCE™. # all pics are written outside of FFS areas. yes, i'm using Disk_A_3.5MB patch. and of course it will work on either non-patched disk or any 3.xMB patched disk, but not on any 4MB patched disk. # changes some 2 colors (1 bit) and 4 colors (2 bits) pictures into colorfull (8 up to 16 [actually 12] bits) pictures. # replacing the duck faces into cool smiley icons. # replacing analog clock background into fullscreen pic that's usefull for backgrounding the digital clock patch in screensaver mode. # ST55 main menu icons (no animated yet!). # added 8 bits digital clock patch pictures (332..334). # added 8 bits advanced net indicator in keylock mode patch pictures (620..626). # added 8 bits profile logo patch pictures (323..329). # added 8 bits vibra logo patch pictures (330..331). # added 8 bits numeric pictures, usually used for Indicator patches (e.g. Battery Percent Level, Net Peak level, etc.). * [0]..[9] -> digits -> @ 601..610 * [°C] -> celcius degree -> @ 392 * [dB] -> decible -> @ 419 * [K] -> kilo -> @ 420 * [M] -> mega -> @ 421 * [V] -> volt -> @ 422 * [%] -> percent -> @ 618 * [.] -> dot -> @ 619 * [-] -> minus -> @ 646 # many, many more ... To use this file, after applying the PIC_MOD patch, then you need to apply this patch below: Code: ;M55V11 - Modify the Total Pic Numbers 0x362A9A: 5503 0103 0x362AAE: 5503 0103 0x362AC2: 5503 0103 0x362AD6: 5503 0103 Or, if you are not apply the PIC_MOD patch yet, then use this patch below: Code: ;M55V11 - Modify the PIT Addresses 0x362A96: 00004201 40195501 0x362ABE: 00005601 40195501 0x362AD2: 08185601 40195501 Note that some numbers are using the same picture, e.g. melody manager pictures (755..760). So, when you try to replace the picture, that's mean you will change the whole desired numbers. : : i'm not too smart in graphics painting i made a few of them, and the rest are taken on the net. You can change the pics as you like. rrrr, i think that you may able to use this patch for another firmware version since they are all using the same PIT and pic addresses. The only things you need to changes are these following values below. Open your fubu file with a Hex Editor and do search + mod for these four values: Code: ;the first of 4 bytes is the PIT-address ;the last of 2 bytes is the total of pic numbers 00 00 42 01 01 03 ;1 40 19 55 01 01 03 ;2 00 00 56 01 01 03 ;3 08 18 56 01 01 03 ;4 great pictures, patches, ideas, etc. Enjoy! Oo, well, one more think ... sorry for my English And i'm waiting your nice pics, lol |
08-01-2005, 14:08 | #180 (permalink) |
Junior Member Join Date: May 2005 Age: 53
Member: 144761 Status: Offline Thanks Meter: 0 | My remaked patches - at http://d-n-n.narod.ru: system and graphic. DNN_Alerts_1-2.vkp - Alerts about missed events DNN_CallsLog2+.vkp - Log of calls DNN_CorrBattProcToPicNo.vkp - Battery icon No correction DNN_DefLangAddrBook.vkp - Default language at AddressBook selection DNN_Digi.vkp - Digital Clock at SS DNN_HourBeep.vkp - Beep every hour DNN_MinTimerExt.vkp - SystemExtensionForPatches: every minute timer DNN_OwnMel.vkp - Own Melody + AutoAnswer for every; +AutoAnswer for all DNN_Provider.vkp - Provider name substitution DNN_StartupInit.vkp - SystemExtensionForPatches: Startup procs DNN_Translit.vkp - For Russian only: Расширенный (авто-)транслит DNN_VibraConnect.vkp - Vibra at connection. Site is periodically refreshed. |
m55 v10 patches (some new, some old) | |FeRRaRi| | E-Gold Based Phones | 11 | 12-12-2004 03:41 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
M55 Graphic Patches | iccume | x4x, x5x Flashpatching | 17 | 03-06-2004 18:24 |
m55 v11 patches (some new, some old) | |FeRRaRi| | E-Gold Based Phones | 4 | 02-27-2004 03:17 |
dead m55 after freia m55 AMD patch | lypen17 | E-Gold Based Phones | 3 | 02-27-2004 00:30 |
