09-20-2004, 22:00 | #106 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | Long time ago you have explained me how to put a dinamic text in a MessageBox, but still I don't understand well to insert a variable number in that string. I want to write "x inbox SMS", where x is a variable number stored in a RAM word, and "inbox SMS" is string ID A5 "inbox" + string ID 1AD "SMS" , how can I make the string to be used by string2ID function??? (Please for S45i if you can) Thanks |
09-21-2004, 00:19 | #107 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | @lalo: 1/ Use this list : 138Fh, 00A5h, 01ADh, 7FFFh in your MessageBox stringlist parameter 2/ Convert x to the digit, and convert the result using string2ID using ID 138F 3/ Call the MessageBox with that string list. rizapn |
09-21-2004, 10:02 | #108 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | @MASTER: Ok, now I begin to undersand, but: I don't know word2string () function, can you tell me (at least for SL45)? And how to insert it in the beginning of my string? Thanks |
09-21-2004, 15:46 | #109 (permalink) |
Insane Poster Join Date: Feb 2003
Member: 22759 Status: Offline Thanks Meter: 0 | Can I try to answer ? Function 0CCCE9Ah (S45i, "DrawChargemonitorScreen") is used function 0FF41E8h ("Word_2_Str") which translates numbers to string . Parameters (for 0FF41E8h): r15 - number of symbols of a string (fill "0"), r14:r13 - destination address, r12 - number (word). If I am not mistaken |
09-22-2004, 09:49 | #111 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | @teachers: Thanks all, but still unable. Could you tell me a patch where this "string with variable numbers" is used? Morover, I don't need to put it into a MesgBox but to show it as a string. So string content should be stored as text (no string IDs) in a (RAM?) location and pointed by r15:r14... possible? Last edited by lalo.lerry; 09-22-2004 at 10:03. |
09-29-2004, 17:41 | #113 (permalink) |
Junior Member Join Date: Sep 2004 Age: 39
Member: 81758 Status: Offline Thanks Meter: 0 | Hello I'm trying to create my own menu ItemHandler, but it doesn't work Please correct me if i tell something wrong: I got those from analizing Currency converter 0xE76450 - menuReserveTextSpace 0xE7620E - menuPrepare 0xE75884 - setMenuButtons 0xE7058E - setMenuEntry Entry creation sequence: menuReserveTextSpace . give: R13:R12=entry_pointer R14=max_text_len . get: R5:R4=place_for_text menuPrepare . give: R13:R12=entry_pointer . get: R5:R4=some_saved_pointer pGetStringByID . give: R12=StringID R14:R13=place_for_text setMenuButtons . give: R13:R12=entry_pointer R15:R14=soft_buttons_pointer setMenuEntry: . give_stack: stack[3:2]=entry_number stack[1:0]=menu_text . give_regs: R13:R12=entry_pointer R15:R14=some_saved_pointer return I save i registers, reserve only 16 bytes on stack and clean everything up before return. It just hangs. Am i missing something, or i just messed up the handler code? PS. I don't create new menu, only change ItemHandler in Currency converter to sequence i've described. Nothing more. I use #20h for max_text_len and "Setup" text from strings table for every entry. |
10-13-2004, 14:51 | #114 (permalink) |
Freak Poster Join Date: May 2003 Location: Russia, Ekaterinburg Age: 44
Member: 29316 Status: Offline Thanks Meter: 0 | About use my LPE patch, in address C42Ah stored offset and in C42C stored page of address were parameters placed for use parameters use this hint (see my example from RBL) Code: paramplace EQU 0C42Ah rxord EQU 0 batVord EQU 2 ;---loading addres where place parameters-- extp #pag(paramplace),#2 mov r12,pof(paramplace) ;in r12-offset mov r13,pof(paramplace)+2 ;in r13-page ;----loading parameters----- extp r13,#2 movb rl6,[r12+#batVord] movb rl7,[r12+#batVord+1] mov r13,r6 mov r12,r7 |
11-08-2004, 19:15 | #115 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Slovakia Age: 41
Member: 89407 Status: Offline Thanks Meter: 0 | hi all! I got an idea: new patch, combined with patch "only show java in surf fun". I was create new directory JAVA in disk A: on my mobile. don't you may create a patch, which opens this directory throught this Java in menu (its a little fake, i know, but i think its a good idea ) Antoine[KNet] patch creator beginner |
11-09-2004, 17:16 | #117 (permalink) |
Junior Member Join Date: Oct 2004 Age: 54
Member: 89010 Status: Offline Thanks Meter: 0 | Where does the phone starts? Hi all I need to create a patch that is called as soon as possible. The problem is, I don't know which is the first routine that is executed. I have seen some code that sets CP, SP, STKOV, but I have no idea who calls this. I also found some code that sets up the Interrupt table, but this is too late. Regards |
11-15-2004, 09:27 | #119 (permalink) |
Member: 89010 Status: Offline Thanks Meter: 0 | COM port To send the value of rl3 to port serial 0 (COM1), do: mov S0TBUF, rl3 bclr S0TIR another_loop: jnb S0TIR, another_loop Be carefull not to send too much data. 1000 bytes is fine, but 1000*1000 is too much. |
11-23-2004, 20:55 | #120 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | This is a tutorial how I solved my "problem" with the nice NSM_Selectable Patch: Original patch sfe d test.bin,27d2e0,28 a00000,p Code: org 0C7D2E0h mov [-r0], r12 extp #36h, #1 mov r12, 96Ch jnb r12.3, loc_C7D2F4 mov r12, [r0+] jmps 0C7h, 0D300h loc_C7D2F4: mov r12, [r0+] jmps 0C7h, 0D2FAh loc_C7D2FA: calls 0C1h, 4A4Ch rets loc_C7D300: calls 0C7h, 0D2D0h rets 0x27D2E0: 88C0D7403600F2FC 0x27D2E8: 6C099AFC033098C0 0x27D2F0: FAC700D398C0FAC7 0x27D2F8: FAD2DAC14C4ADB00 0x27D300: DAC7D0D2DB00 "My Patch" : (with jb instead of jnb) jnb= jump if bit not set / jb = jump if bit set Code: org 0C7D2E0h mov [-r0], r12 extp #36h, #1 mov r12, 96Ch jb r12.3, loc_C7D2F4 mov r12, [r0+] jmps 0C7h, 0D300h loc_C7D2F4: mov r12, [r0+] jmps 0C7h, 0D2FAh loc_C7D2FA: calls 0C1h, 4A4Ch rets loc_C7D300: calls 0C7h, 0D2D0h rets 0x27D2E8: 6C098AFC033098C0 0x27D2F0: FAC700D398C0FAC7 0x27D2F8: FAD2DAC14C4ADB00 0x27D300: DAC7D0D2DB00 What I dont understand is this: jmps 0C7h, 0D2FAh loc_C7D2FA: because itīs useless (?) |
BB5 - Technical Discussion | adihack | Nokia Base Band 5 ( BB-5 ) | 220 | 10-14-2011 05:31 |
x65 patching technical discussion | Acidmrp | x6x and x7x Flashpatching | 42 | 10-10-2009 07:06 |
Iphone 3G Technical Discussion and SP Unlocking theory | GraveSlayer | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 11-15-2008 06:04 |
Technical discussion sharp705sh | celluniversal | Sharp | 0 | 05-17-2007 17:26 |
Technical discussion BB5 unlocking | twisterfan | Nokia Base Band 5 ( BB-5 ) | 0 | 05-16-2007 19:36 |
