Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 01-10-2005, 13:18   #946 (permalink)
Member: 100979
Remove Patches - Merge more languages
1. It's always possible to remove a patch that was applied BEFORE other patches? Obviously, if no specific notes are written ...
Because sometimes the patch code goes "over" other patches -e.g. showing temp and different date "Mo 10 Jan".
In this case I have to remove the last one, than remove what I want and the re-apply the last one or exists a SHORTCUT that I don't know??
2. I'd like to choose between Italian-English-Spanish menu languages. SIEMENS said me that I can't do it because no "language region packet" include all three langs. It's possible to "merge" a choosen language instead of one other -e.g. put Spanish over Arabian o Turke- ?
And what did you say about T9 languages?
Thanks a lot
Old 01-10-2005, 14:39   #947 (permalink)
KTL
Member: 40736
Hi
i have problem
with this patch ***SHT 1.0 ScreenShot*** it colidates with some other patches from this forum? when i aplly it the phone bzzz and turn off after start some ideas?
Old 01-10-2005, 14:43   #948 (permalink)
Member: 101058
If you have access to the language data in question (i.e. a FuBu from a phone with the necessary lg/t9 language installed), you can indeed build your own combination(s) using, e.g. Siemens Language Editor and T9 Base Creator.
Best regards,
Chris.
Old 01-10-2005, 23:36   #949 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
@fcortina:
Great work!
But please relocate it, it collides with Hourly Beep (7C8A0-7C8FC), Riza's Digital Clock (7C900-7C977), and Any Number Own Ringtone (7C980-7C9C8) and New Application Menu (7C9D0-7CB04).
space at 07xxxx is full untill 7DE50, but please don't use free space form there because I'm going to put there my next patches routines.
So please don't use the 07xxxx block.
I really don't kwon other free areas situations, they are other patchers areas.
Please add also old fw values to your patches, for easy deletion and avoid V-Klay prompts.
Anyway, still best compliment!
Lalo
@El Possa:
Sorry, but you are wrong.
That 2 patches of mine don't overlap, and if you want to have them both read carefull customization options (I have both applied).
WBR
Lalo
Old 01-11-2005, 09:43   #950 (permalink)
Member: 89010
Thanks to all that pointed me that
-my patch collides with other patches
-there is no undo information.
I plan to do a new version including those changes.
@lalo.lerry
I must say that, for me, you are the master of S45i. I have an idea to use AT commands from patches. Can you give me any hints?
For example, I would like to make a patch that calls 112 every day at 12:00 (this is a stupid example).
For this, all I need is
ATDT112
Do you know which routine I need to call to process an AT command?
Thanks
Old 01-11-2005, 12:55   #951 (permalink)
misko903's Avatar
Member: 89407
@Lalo
OK, i understand, you're right, it's on me to disasm my patches and making better experiences and knowledges of patching sorry
BTW, where you study?
Old 01-11-2005, 12:58   #952 (permalink)
Member: 100979
Sensor tool settings
Hi,
I've found on the web these settings for my S45i battery-tune-up:
0000:4183
0002:4221
0004:63461
0006:1011
0008:79
000A:62490
000C:106
000E:65233
0010:100
0012:0
The cell works quite fine, but I've found different parameters on another web page (thnks to Giro):
0000:3592
0002:4185
0004:62723
0006:1001
0008:78
000A:62450
000C:105
000E:65195
0010:100
0012:0
What do you think about these two settings? Which one works better?
Or ... someone could tell me where I can find other *.blk Sensor Tool files for my Wonderful (thnks to ALL ) S45i?
Old 01-11-2005, 13:06   #953 (permalink)
misko903's Avatar
Member: 89407
@ElPossa:
what i am readed about these setting - it's other for every battery. it's something like calibrating for it - better is to have a exact voltmeter and measure these values directly and compare it with phone voltages.
Old 01-12-2005, 09:15   #954 (permalink)
Member: 76708
Thanks
Look for a table near address ATHandleTable equ 84422Ch in my idb. It is a table of handlers of various AT commands.
E.g. OriginalATHandle EQU 0EDD5B2h is an original handler of AT+CGSN command (get IMEI).
Old 01-12-2005, 09:31   #955 (permalink)
Member: 76708
I don't know how you can send AT commands from patches, but this can be emulated by filling the AT command line and calling a handler of that command.
GetATCmdLine EQU 0EF00ACh
ATArgs EQU 0054007h
Old 01-12-2005, 09:50   #956 (permalink)
Member: 89010
@redkin
Thanks a lot. I was using that, but it seems that those routines are called _after_ the command is processed. Anyway it is a good starting point, because I can trace it back and see which is the initial routine that calls that.
Let's see how far I get.
Old 01-12-2005, 19:18   #957 (permalink)
genetic1's Avatar
Member: 70990
RFS. Read FlashSMS Shortcut in idle
@Lalo:
Could it be, that there is a little bug in patch above?
Yesterday I get my 1st flash sms, since applying RFS and it was arrived as normal ones!
Do you have any idea?
genetic
(have you ever read my answer(s) of your post?) http://forum.gsmhosting.com/vbb/show...&postcount=945
Old 01-13-2005, 02:19   #958 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
@genetic:
yes, I read it but didn't have time to answer.
Screensaver patch is ready but still unpublished because I wanted to finish BLR v2, to avoid overlapping them.
Tonight should pubblish both.
Then I'll publish "missing events string in idle-screensaver", last patch before break (2 months).
In that period no patch request will be accomplished, and even if I'll read the forum each day, could not have time to answer (sorry).
BTW, RFS cannot be in any way responsable of not recieving a FlashSMS as normal.
It uses normal fw routine to process FlashSMS...
@fcortina:
Redkin has answered you better than I could have done.
Sorry, I've haven't studied ATcommand routines
@misko:
OK, no problem, mate!
Sorry if in my break sometime I will not answer you immediately...
I study in Italy of course, in Verona (north Italy, between Milan and Venice),
and I'm studing.... you could not guess what!
@all:
"S45i MASTER or NOT MASTER"?
"to be or not to be? that is the question!"
Really, I don't consider myself THE S45i MASTER.
I consider myself a very good S45i patcher, one of the best 5th, but I'm not THE master, simply because there isn't a S45i overall master, like Riza in SL45i.
I mean, I know and probably use better than other patchers some S45i functions and routines, but cannot use or use in a worst way other less studied ones.
So, for some things I consider MASTER Redkin, or Ntcn...
I have to improuve myself on some aspects before you could call me "MASTER"
Lalo
Old 01-13-2005, 09:45   #959 (permalink)
Member: 89010
@Lalo:
I know you have made many patches and I am always learning from them. I suppose
you have a bag full of information, probably a bit messy. Is there any possibility that
you pack all your secret files so that pupils, like me, use them? Italian is OK for me.
@all:
And same request to all of you patchers. The info that Redkin is providing me is
very usefull and saves me plenty of time, so maybe we all can also share our tricks.
This is why I release the source code and comments for my patches.
Old 01-15-2005, 03:39   #960 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
@fcortina:
I suppose you have a bag full of information, probably a bit messy.
You suppose it right, I have it... but not a little mess, a really big mess.
My patching "bag" is so made:
1.S45i IDA decompiled fw: all in Italian, really messy, not complete and with some errors inside (of course my disasm undersanding grown day after day, my first attempts are poor and not complitely correct).
I consider it unpubblishable because is mess and faulty in some parts.
If I'll have time to translate it to English, and so recheck it, I'll pubblish.
2.S45i APIs, EQUs and fw understanding (fonts, RAM location, sk handlers, fw routines...): all in Italian, also this very messy.
I consider it unpubblishable and have no time to make it pubblishable, now.
3.(Almonst all) my patches explained disasms: again, in Italian.
I consider it pubblishable with not a big work (if not translate them).
So, if you want it I can attach them here, as soon as I've time.
Sorry, I know it's not the best part but this is the best I can offer now...
I hope other patch masters will share their "secrets" with the community, or at least their patches sources (or better patch explained disasms)
@Misko:
Yesterday digging in fw I found something for you:
OPEN A SPECIFIC FLEX MEM FOLDER:
mov r12, #n ;n:0=when exit return in prevous folder 1=... in calling routine
mov r13, #Offset
mov r14, #Page ;r14:r13= P:Off of folder name string in ASCII, with ending byte 00
calls 0F5h, loc_F51DB0 ;open Flex Mem, in A:\ if r14:r13=0, otherwise in A:\folder_name
Now you can finish your improuved java menu patch.
Bye
Lalo
S/Me45i-v04: Flash Patches patch_me x4x, x5x Flashpatching 329 05-30-2010 10:49
821sc flash patch cid3 dead after flash cetech Z3X-Team Products 26 07-17-2009 12:12
L760 flashing patched flash problem Steph NSPRO 4 12-05-2008 11:04
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Need flash patched with Spanish lang for Neptune ! Kilowat Mitsubishi 4 05-21-2002 07:24
Page generated in 0.31485 seconds with 10 queries
