Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 08-26-2004, 13:08   #1 (permalink)
Member: 7062
Thanks Meter: 126
After removal of glued UEM and glued uem removal video guide
Hi freinds
It happens to many of us when we remove the UEM. It takes a lot of effort you might have some tracks with no green lacqour ( specially on the light green boards )
What i made, is coating the board with a blue marker, and dry it with cold air (fan). When its dry, we have a small problem ! How do I fit the new or old reballed UEM without using flux ?
I have solved it using the following method :
1 : For new uem
A : Put some flux at the UEM IC balls and heat it with mid heat and the nozzel around 2 inches from the IC
B : Clean the IC and the balls untill all balls are bright and shining
C : Fit the UEM in place and use mid heat and mid air, but here you'll have to use longer time than usual, around 3 to 4 min
Now your done !
2 : For reballing the same UEM it's alot easier since theres still some solder left on the pads. Clean it up and fit the same way as above.
N.B The success of this proccess depends on fitting the UEM exactly in it's place
**Edited and proffread where nessesary for sticky**
The Following 28 Users Say Thank You to Raheeeeb For This Useful Post:
Old 08-26-2004, 23:20   #2 (permalink)
Member: 79374
Thanks Meter: 2
Raheeeb the best hardware worker
Thanks to share your knowledge to us
The Following 2 Users Say Thank You to Mia_II For This Useful Post:
Old 08-26-2004, 23:26   #3 (permalink)
Member: 28653
Thanks Meter: 5
agree also he is the man with good skills in hw filed
king
The Following User Says Thank You to kingofcellulars For This Useful Post:
Old 08-26-2004, 23:30   #4 (permalink)
Member: 7062
Thanks Meter: 126
@mia2
thank you a lot i hope it help any whom need it
@king
its nothing like your experince in samsung problems
The Following User Says Thank You to Raheeeeb For This Useful Post:
Old 08-27-2004, 11:22   #5 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
@Raheeeb
Good work.
Added to sticky's in Hardware repair section.
Regards
Old 08-27-2004, 11:48   #6 (permalink)
visualtech's Avatar
Member: 15333
thanks for the good solution ,
Old 08-27-2004, 12:37   #7 (permalink)
Member: 7062
Thanks Meter: 126
@ gsm coolhawk
thanks a lot and more i ll post
@visualtech
i hope its help and another trick ll post soon
Old 08-27-2004, 16:01   #8 (permalink)
keany's Avatar
Member: 67419
Thanks Meter: 237
@raheeeeb
nice job ....and good luck
best regards
keany
Old 08-27-2004, 16:14   #9 (permalink)
Member: 7468
Thanks Meter: 2
excelent work... photo says everithing!!
Old 09-03-2004, 12:05   #10 (permalink)
DineshDias's Avatar
Member: 77943
Thanks Meter: 56
you are a great person.
Old 09-03-2004, 15:17   #11 (permalink)
MaFiaaa's Avatar
Member: 57930
Thanks Meter: 24
gr8 work raheeb i talk to u be4 about that but on old name
did u still remember amir-cairo
regards
Old 09-03-2004, 19:05   #12 (permalink)
Member: 7062
Thanks Meter: 126
@keany
this comment from profissonal man with bright future in hardware
@infinty
thank you a lot i hope its help and more photo about lost trace ll b implemented
@DineshDias
thank you i hope i can help more
@mafiaaa
sure i remmber you but your a man many people looking for have your name
but you to nick name from others .. this need to explain (mobile maafia belong to wael omar)
sorry but i have to reply whom say good word for me i hope i don't break the forum roles
Old 09-03-2004, 19:08   #13 (permalink)
Member: 7062
Thanks Meter: 126
@all freinds
tested 100% in cobba
tested in samsung cpu but not 100% this my experince may you have better luck than me
Old 09-04-2004, 20:18   #14 (permalink)
Member: 64341
ok. thanks raheeeeb. for us novis, on what instances do we need to change uem other than dct4 imei curruption? what are the risk and are there any other operations necessary to be carried out after changing the uem?
Old 09-05-2004, 16:51   #15 (permalink)
Member: 7062
Thanks Meter: 126
@OKOKO
reason to remove uem
1- water damage uem
2- burnt due to high voltage from the charger
3- 30 seconds autoshut off after repair the imie by griffin log
4- unable to flash the phone due the tx singnal high from phone to flasher
i think in most of these you have to change it ..
br..
The Following 4 Users Say Thank You to Raheeeeb For This Useful Post:
..::i need video guide how to remove glued chip like omap, rap3g, combo flash,uem::.. HUM Nokia Hardware & Hardware Repair 30 01-03-2010 18:33
Tutorial of Remove Glued rap and flash chip by Jovy RE 7500 Raheeeeb RE-7500 Reworking System & iSolder 39 02-26-2009 11:33
removal of glued ics akfrm Nokia Digital Core Technology 4 ( DCT-4 ) 2 03-20-2005 17:29
Page generated in 0.21696 seconds with 10 queries
