Get All Your Problems Solved in 12 hours.... :) Hai Mates, I m gonna start a new thread ..you can post ur all problem like Hardware and Softwares (6600,7610.6630 Specially) etc.. and all the softwares related to S60..Lets make this thread help other members also.. Regards.. Adampur Hawks..:) |
I am new here. Nice place to discuss, lots of help for juniors ;) |
Nokia 7610 No Display.. Hi Guys, Regards. Hope U Can Help Me.. My 7610 No Images Or Words Can Be Seen But Only Hv Backlight On, And Still Can Receive Calls But Nothing On The Screen. Pls Help Me. |
Hi Mate Steps for 7610 White Display 1) First of All Check ur display 2) Check the Display Connectors on PCB,Bat be Shorting or damaged. 3) Reheat display IC 4) Full format your phone with JAF or with UFS 5) Reflash with higher version... Regards. Adampur Hawks.. |
hello! 7610 problem... phone startup failed! reballing of flashes gave no result also erasing and flashing with formatting. problem in RAM? |
hi ENGR. on line i say good morning as it here now in nigeria |
Engr. ADAMPURHAWRKS RESPOND TO ME |
nokia 6020 i have nokia 6020 inserts sim i have change the ic but still it is not working so plz give me solution |
7610 dead set. Flash with tornado give result like this: 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ETA Fl1: 0x02000000-0x02FFFFFF,00EC22F8,Sam K8S2815ETA Fl2: 0x04000000-0x047FFFFF,00EC22FA,Sam K8S6415ETA Algorithm: w3_amd_b.fia, Ver: 4.52.0 Alg Boot Error: 2 Error Data1: 00000000: 9F 04 04 00 EC 00 F8 22 00 00 11 00 10 00 02 EC ......."........ 00000010: 00 F8 22 00 00 11 00 10 00 04 EC 00 FA 22 00 00 .."..........".. 00000020: 11 00 10 00 06 00 00 01 00 00 00 00 00 00 00 FF ................ 00000030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 83 ................ Error Data2: 00000000: F3 72 00 F8 22 00 00 11 00 10 00 02 EC 00 F8 22 .r..".........." 00000010: 00 00 11 00 10 00 04 EC 00 FA 22 00 00 11 00 10 .........."..... 00000020: 00 06 00 00 01 00 00 00 00 00 00 00 FF FF FF FF ................ 00000030: FF FF FF FF FF FF FF FF FF FF FF FF 83 D3 72 00 ..............r. Before taking screenshot, expand this window ! Process Failed, Repowering Mobile Can you give idea which part give error like this? |
6600 camera hi i am having 6600 it has problem of camer when i cilk camera it take photo but after that display show temporary overload continue plz tell how to solve this problem |
1) Try to format your phone manualy with * + 3 + Green + Power on 2) If not Ok..Format User Area with UFS of with JAf 3) If still not OK Flash your phone with higher version .. Regards Adampur Hawks |
[quote=pradeep agrawal;1954878]hi plz give me solution for sumsung v 200 no network found[/quot] Hi Mate.. First of all Reset your phone with 1)*2767*2875# or with *2767*3855# 2) If not Ok Full Flash your phone... Evrythng wll b ok Regards Adampur Hawks |
6600 cam temporarilly overload galery not open and bluthooth not work flash is not the solution must be heat with hot gun the BT module if not ok so change it be carefull:D |
heat with hot gun BT mobule then try |
My problem not solved after 12 hours Thanks. BR. |
